A (possibly) odd way to access a port
Results 1 to 4 of 4
    Jan 2012
    Grid EN19MV
    Default A (possibly) odd way to access a port
    I'm using the lower 6 bits of PORTC (16F886) as select lines for other chips. These bits would be set as outputs.
    Can I use the following to access individual bits of PORTC? (I suspect not - but I've searched the manual and the forum and can't seem to find the answer)
    COUNTER VAR BYTE
    FOR COUNTER = 0 TO 5
            PORTC.COUNTER = 0 'SET THE PORTC PIN LOW
    NEXT COUNTER
    My other idea was to use an array.
    EN_ARRAY VAR BYTE[6]
    COUNTER VAR BYTE
    EN_ARRAY[0] VAR PORTC.0
    EN_ARRAY[1] VAR PORTC.1
    EN_ARRAY[2] VAR PORTC.2
    EN_ARRAY[3] VAR PORTC.3
    EN_ARRAY[4] VAR PORTC.4
    EN_ARRAY[5] VAR PORTC.5
          EN_ARRAY[COUNTER] = 0  'SET PORTC PIN TO 0
    NEXT COUNTER
    If neither of these would work, any other ideas - it would simplify this project a lot if I can use an index of some sort to access those pins.
    Andy
    Default Re: A (possibly) odd way to access a port
    it doesn't always work but give this a try
    COUNTER VAR BYTE
            PORTC.0[COUNTER] = 0 'SET THE PORTC PIN LOW
    NEXT COUNTER
    Jan 2012
    Grid EN19MV
    COUNTER VAR BYTE
    NEXT COUNTER
    Ok, I get it - an offset from bit 0.
    Thanks! I'll try that!
    Sep 2005
    Campbell, CA
    Although I have posted it before, the code below can be used as an example of referring to a port bit as a variable.
    I use this code (or a variant) all the time to test new hardware.
    Note that it was written for the 18F8720/18F8722/18F8723 family.
    PORT OFFSETS
    '"A.0",0
    '"A.1",1
    '"A.2",2
    '"A.3",3
    '"A.4",4
    '"A.5",5
    '"A.6",6
    '"A.7",7
    '"B.0",8
    '"B.1",9
    '"B.2",10
    '"B.3",11
    '"B.4",12
    '"B.5",13
    '"B.6",14
    '"B.7",15
    '"C.0",16
    '"C.1",17
    '"C.2",18
    '"C.3",19
    '"C.4",20
    '"C.5",21
    '"C.6",22
    '"C.7",23
    '"D.0",24
    '"D.1",25
    '"D.2",26
    '"D.3",27
    '"D.4",28
    '"D.5",29
    '"D.6",30
    '"D.7",31
    '"E.0",32
    '"E.1",33
    '"E.2",34
    '"E.3",35
    '"E.4",36
    '"E.5",37
    '"E.6",38
    '"E.7",39
    '"F.0",40
    '"F.1",41
    '"F.2",42
    '"F.3",43
    '"F.4",44
    '"F.5",45
    '"F.6",46
    '"F.7",47
    '"G.0",48
    '"G.1",49
    '"G.2",50
    '"G.3",51
    '"G.4",52
    '"G.5",53
    '"G.6",54
    '"G.7",55
    '"H.0",56
    '"H.1",57
    '"H.2",58
    '"H.3",59
    '"H.4",60
    '"H.5",61
    '"H.6",62
    '"H.7",63
    '"J.0",64
    '"J.1",65
    '"J.2",66
    '"J.3",67
    '"J.4",68
    '"J.5",69
    '"J.6",70
    '"J.7",71
           DEFINE OSC 20                                                           '
           DEFINE NO_CLRWDT 1
            DEFINE HSER_RCSTA 90H
            DEFINE HSER_TXSTA 20H
            DEFINE HSER_BAUD 9600
            DEFINE HSER_CLROERR 1
            DEFINE LOADER_USED 1                                                    ' Bootloader
            Define USE_LFSR 1
            DEFINE ADC_BITS 10
            DEFINE ADC_SAMPLEUS 50
            DEFINE ADC_CLOCK 6
             Break        VAR BIT
            X            VAR BYTE
            Dummy        VAR BYTE
            ReadValue    VAR BYTE
            SelectedPort VAR BYTE
            Position     VAR BYTE
            PortValue    VAR BYTE
            WholeVolts   VAR WORD
            Array1       VAR BYTE[3]
            ADequiv      VAR BYTE[74]
            Invalids     VAR BYTE[21]
            ADResult     VAR WORD
            Counts       VAR WORD
            PartialVolts VAR WORD
            TRISA  = %11111111
            TRISB  = %11111111
            TRISC  = %10111111
            TRISD  = %11111111
            TRISE  = %11111111
            TRISF  = %11111111
            TRISG  = %11111111
            TRISH  = %11111111
            TRISJ  = %11111111
            ADCON1 = $FF
            PSPCON = %00000000              ' No PSP
            MEMCON = %10000000              ' No External Memory
            CMCON  = %00000111              ' No Comparator used, turn it off
            ADCON2 = %10000010              ' Right Justify, /32
            T0CON =$86                      ' Set up TMR0 prescaler to /128  for 1sec timer
            For X = 1 to 73
            ADequiv[X] = 255
            Next X
            ADequiv[0]= 0
            ADequiv[1]= 1
            ADequiv[2]= 2
            ADequiv[3]= 3
            ADequiv[5]= 4
            ADequiv[40]= 5
            ADequiv[41]= 6
            ADequiv[42]= 7
            ADequiv[43]= 8
            ADequiv[44] =9
            ADequiv[45] =10
            Adequiv[46] = 11
            ADequiv[60] = 12
            ADequiv[61] = 13
            ADequiv[62] = 14
            ADequiv[63] = 15
            TRISD = 0
            For X = 1 to 20
              Invalids[X] = 255
            Next X
            Invalids[0] = 22
            Invalids[1] = 23
            HSEROUT ["Port Tester",13,10,10]
    Begin:
           HSEROUT [13,10,10,10,"Port (ex: A.1)   X.X",8,8,8]
           Position = 0
    Enter:
            HSERIN [SelectedPort]
                   IF SelectedPort = 46 THEN GOTO ENTER
                   If Position = 0 THEN
                     SelectedPort = SelectedPort & %11011111
                     If SelectedPort <65 or SelectedPort > 74 THEN GOTO InvalidEntry
                     HSEROUT [SelectedPort,"."]
                     Array1[0]=SelectedPort
                     Position = 1
                     GOTO Enter
                   If SelectedPort <48 or SelectedPort > 55 THEN
                        GOTO InvalidEntry
                   HSEROUT [SelectedPort]
                     Array1[1]=SelectedPort
                  PortValue = ((Array1[0] - 65)*8) + (Array1[1]-48)
                  For X = 0 to 20
                  If PortValue = Invalids[X] Then
                    HSEROUT [13,10,"Disallowed/Invalid Port",13,10]
                    Pause 2000
                    HSEROUT [13,10,10]
                    GOTO Begin
                   Next X
                 Goto GoodEntry
    InvalidEntry:
                  HSEROUT [13,10,"Invalid Entry",13,10]
                  Pause 1000
                  GOTO BEGIN
    GoodEntry:
                 HSEROUT [13,10,10]
                 Hserout ["Output 0 (0), 1 (1), Toggle (T), Input (I), Loop Input (L), Analog (A)  "]
                 HSERIN [Dummy]
                  IF Dummy > 64 THEN
                   HSEROUT [Dummy & %11011111]
                 HSEROUT[Dummy, CR,LF]
                 IF Dummy = "0" THEN                                                ' Ouput a '0'
                    IF PortValue = 4 THEN
                      HSEROUT [10,13,"Port A4 is Open Collector!",13,10]
                    ADCON1 = $FF
                    TRISA.0(PortValue)=0                                            'Make it an output
                    PauseUs 20
                    PORTA.0(PortValue) = 0                                          'Write a '0'
                    GOTO StateCheck
                 IF Dummy = "1" THEN
                    ADCON1 = $FF
                    PauseUs 20
                    PORTA.0(PortValue) = 1
                    GOTO StateCheck
                 IF Dummy = "T" or Dummy = "t" THEN
                   HSEROUT ["Press <ESC> to stop toggle"]
                    ADCON1 = $FF
                    TRISA.0(PortValue) = 0                                          'Make it an ouput
                    PauseUs 20
    Loop1:
                    PAUSE 100
                    PAUSE 100
                    GOSUB CheckForChar
                    IF Break = 0 THEN GOTO Loop1
                    Break = 0
                    TRISA.0(PortValue) = 1                                          'Make it an input again
                 IF Dummy = "I" or Dummy = "i" THEN                                  'INPUT
                    ADCON1 = $FF
                    Pauseus 20
                    ReadValue = PORTA.0(PortValue)
                    HSEROUT [13,10,"Value = ",Dec1 ReadValue,13,10]
                 IF Dummy = "L" or Dummy = "l" THEN                                  'Loop read
                    ADCON1 = $FF
                    TRISA.0(PortValue) = 1                                          'Make an input
                 Pauseus 20
    Loop2:
                    HSEROUT [13,10,"Value = ",Dec1 ReadValue]
                    Pause 200
                    GOSUB CheckForChar
                    IF Break = 0 THEN GOTO Loop2
                    Break = 0
                 IF Dummy = "A" or Dummy = "a" THEN
                     IF ADequiv(PortValue) = 255 THEN
                       HSEROUT[13,10,"Invalid Analog Port",13,10]
                       PAUSE 2000
                       GOTO BEGIN
                     ADCON1 = %00000000
                     ADCIN (ADEquiv(PortValue)),ADResult
                     Counts = ADResult
                     ADRESULT = (ADRESULT *49)
                     WholeVolts = (ADresult/10000)
                     PartialVolts = (ADresult - (WholeVolts*10000))/10
                     HSEROUT [13,10,"AD Result = ",#Counts,"  Counts, ",#WholeVolts,".",DEC3 PartialVolts," Volts",13,10]
                     ADCON1 = %11111111                                             ' Back to all digital
                 PAUSE 500
                 GOTO BEGIN
    StateCheck:
                HSEROUT [13,10,"Leave output in this state (L), or Reset to Input  (R) ?  "]
                HSERIN [Dummy]
                 IF Dummy = "R" or Dummy = "r" THEN
                 GOTO BEGIN
    CheckForChar:
                IF PIR1.5 = 1 THEN
                  HSERIN [Dummy]
                  if Dummy = ESC THEN
                     Break = 1
    Charles Linquist
  1. Is it possibly a Windows XP Pro Problem?
    By Ramius in forum Serial
    Last Post: - 2nd May 2011, 18:26
  2. Access array in PBP and .asm
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 6th September 2008, 00:35
  3. Second serial port access ( Hserin2 )
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 9th October 2007, 18:01
  4. Access and VBasic
    By Ioannis in forum Off Topic
    Last Post: - 24th November 2006, 15:05
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 04:26
