Wake from sleep (Well, sorta) 16F88, PICBASIC PRO
Results 1 to 4 of 4
    Oct 2011
    Default Wake from sleep (Well, sorta) 16F88, PICBASIC PRO
    I have written a program which puts the '88 in sleep mode, and it wakes up when the button attached to RB0/INT is pressed. No problem there.
    However, I don't want the device to wake up if the button is pressed by accident. I want there to be a bit of code that, once the device wakes up, will test to see if the button has been held for two seconds, and then put it back to sleep if it hasn't.
    I also use this button for other purposes.
    Thanks in advance for your help.
    Default Re: Wake from sleep (Well, sorta) 16F88, PICBASIC PRO
    this will be done in your ISR... just check how many secondes the button is pressed since in the ISR, if more than 2 secondes, continue normal operation... case not return to sleep mode.
    you need a While loop, a pause, a TimeOut/counter variable, maybe a IF-THEN and that's it... done.
    something around this
            WHILE !_PB  and (TimeOut<MaxTimeout)
                    PAUSE 100
                    Timeout=Timeout +100
                    WEND
            IF Timeout<MaxTimeout THEN
                    ' fail duties goes here
                    ' success duties goes here
    Sep 2010
    Las Vegas, NV
    I'm assuming you haven't disable the WDT and if that's so, why not use NAP instead. You could set it to wake every two seconds and see if the button is pressed. I'd suggest though you set if for 1 second. With a setting of 2 second one might hold what they think would be too long and surmise the unit was inoperative.
    Worked for me on a previouse project.
  1. Replies: 13
    Last Post: - 30th July 2012, 22:11
  2. 16F690... How to wake from sleep?
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 5th July 2011, 23:07
  3. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 05:33
  4. wake up from sleep
    Last Post: - 31st August 2007, 18:09
  5. ? about sleep/wake on pin change and WDT
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 00:25
