Hello, I am new to programming and I need help. I wrote the code, but do not know if it's okay. I still have made ​​hardware ....
would that working how did I wrote??
this is the code ...
'*  Name    : SMS_CONTROLER_.BAS                                *
'*  Author  : Pintarić Branko                                   *
'*  Notice  :                                                   *
'*  Date    : xx.xx.2012                                        *
'*  Version : 2.0                                               *
@ DEVICE PIC16F877, HS_OSC, LVP_OFF, WDT_OFF, MCLR_OFF
define OSC 4
DEFINE HSER_SPBRG 25
DEFINE HSER_TXSTA 24h
DEFINE HSER_RCSTA 90h
DEFINE HSER_BAUD 9600
DEFINE HSER_CLROERR 1
DEFINE LCD_BITS 4
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 5
DEFINE LCD_LINES 2
SYMBOL LED_GSM   = PORTC.1          ' Postavi PORTC.1 za GSM_LED
SYMBOL LED_POWER = PORTC.2          ' Postavi PORTC.2 za GSM_POWER
SYMBOL RE1 = PORTB.0                ' RELEJ 1
SYMBOL RE2 = PORTB.1                ' RELEJ 2
SYMBOL RE3 = PORTB.2                ' RELEJ 3
SYMBOL RE4 = PORTB.3                ' RELEJ 4
SYMBOL RE5 = PORTB.4                ' RELEJ 5
SYMBOL RE6 = PORTB.5                ' RELEJ 6
SYMBOL RE7 = PORTB.6                ' RELEJ 7
SYMBOL RE8 = PORTB.7                ' RELEJ 8
SYMBOL SE1 = PORTD.2                ' SENZOR 1
SYMBOL SE2 = PORTD.3                ' SENZOR 2
SYMBOL SE3 = PORTC.4                ' SENZOR 3
SYMBOL SE4 = PORTC.5                ' SENZOR 4
SYMBOL SE5 = PORTD.4                ' SENZOR 5
SYMBOL SE6 = PORTD.5                ' SENZOR 6
SYMBOL SE7 = PORTD.6                ' SENZOR 7
SYMBOL SE8 = PORTD.7                ' SENZOR 8
output LED_GSM
output LED_POWER
OUTPUT RE1                          ' RELEJ 1
OUTPUT RE2                          ' RELEJ 2
OUTPUT RE3                          ' RELEJ 3
OUTPUT RE4                          ' RELEJ 4
OUTPUT RE5                          ' RELEJ 5
OUTPUT RE6                          ' RELEJ 6
OUTPUT RE7                          ' RELEJ 7
OUTPUT RE8                          ' RELEJ 8
INPUT SE1                           ' SENZOR 1
INPUT SE2                           ' SENZOR 2
INPUT SE3                           ' SENZOR 3
INPUT SE4                           ' SENZOR 4
INPUT SE5                           ' SENZOR 5
INPUT SE6                           ' SENZOR 6
INPUT SE7                           ' SENZOR 7
INPUT SE8                           ' SENZOR 8
PORUKA VAR BYTE[5]
TELBR VAR BYTE[12]
TIME VAR BYTE [5]
klima var byte
J VAR BYTE
I VAR BYTE
LOW LED_gsm
low led_power
low re1
low re2
low RE3
low RE4
low RE5
low RE6
low RE7
low RE8
'                   PROVJERA NOVE PORUKE
pocetak:
HSerout ["ATZ",13,10]                   ' pocni komunikaciju
HSERIN 2000,pocetak,[WAIT("OK")]
     LCDoUT $FE,1,"  Provjera"
     LCDoUT $FE,$C0,"  SMS-a  "
textmod:
HSerout ["AT+CMGF=1",13,10]             'postavi text mod
HSERIN 2000,textmod,[WAIT("OK")]
mem:
HSEROUT["AT+CPMS=",34,"SM",34,13,10]    ' ciljana memory lokacija
HSERIN 2000,mem,[WAIT("OK")]
IP:
HSEROUT["AT+CMGL",13,10]                ' filter za query
    LCDOUT $FE,1,"trazi poruke.."
HSERIN 5000,IP,[WAIT("REC UNREAD"),skip 2,str TELBR\12,skip 13,str TIME\5,skip 9,STR PORUKA\5\13]
    LCDOUT $FE,1
I=0
klima[1]="O"
klima[2]="N"
KLIMA[3]=" "
klima[4]="K"
KLIMA[5]="L"
KLIMA[6]="I"
KLIMA[7]="M"
KLIMA[8]="A"
if poruka[i+1]=klima[i+1] and poruka[i+2]=klima[i+2] and poruka[i+3]=klima[i+3] and poruka[I+4]=klima[I+4] AND poruka[I+5]=klima[I+5] AND poruka[I+6]=klima[I+6] AND poruka[I+7]=klima[I+7] AND poruka[I+8]=klima[I+8] then  gosub salji_sms_klima
J=0
klima[1]="O"
klima[2]="F"
klima[3]="F"
klima[4]="K"
klima[5]="L"
klima[6]="I"
klima[7]="M"
klima[8]="A"
'                     brisanje poruke iz memeorije
MEM2:
HSERIN 2000,mem2,[WAIT("OK")]
del2:
HSEROUT["AT+CMGD=1",13,10]
HSERIN 2000,del2,[WAIT("OK")]
        LCDOUT $FE,1,"PORUKA ODBRISANA"
        pause 1500
GOTO IP
'      subrutina za u-i potrosca i obavjest korisnika o poduzetoj akciji
salji_sms_klima:
high re1
HSerout ["AT",13,10]
       Pause 1000
HSerout ["AT+CMGF=1",13,10] 'Postavi Text Mode
       Pause 1000
HSerout ["AT+CMGS=",34,"+38761xxxxxx",34,",129",13,10]
       Pause 1000
HSerout [str poruka,str time,10,13]
HSerout [26]
       Pause 1000
