pic16f88 Serial questions (hserin/hserout, etc.)
Results 1 to 8 of 8
    Oct 2012
    Default pic16f88 Serial questions (hserin/hserout, etc.)
    I'm trying to send a decimal number (0-999) from an arduino (mega2560, not important) to a pic 16f88 via serial.
    I'm new to this, but the pic doesn't seem to be receiving and/or processing the data. I've already looked around the forums for details on this, but I can't find what I'm looking for.
    Here's my pic code:
    DEFINE OSC 8
    OSCCON.4 = 1
    OSCCON.5 = 1
    OSCCON.6 = 1
    ANSEL = 0
    DEFINE hser_rcsta 90h 'set receive register to receiver enabled
    define hser_txsta 20h 'set transmit register to transmitter enabled
    define hser_baud 9600 'set baud rate
    portb.0 = 0
    portb.1 = 0
    portb.3 = 0
    portb.4 = 0
    portb.6 = 0
    portb.7 = 0
    porta.0 = 0
    porta.1 = 0
    motor1 var portb.0 'assign main motor 1 to pin 6
    motor2 var portb.1 'assign main motor 2 to pin 7
    thr1 var portb.3 'assign thruster motor 1 to pin 9
    thr2 var portb.4 'assign thruster motor 2 to pin 10
    thr3 var portb.6 'assign thruster motor 3 to pin 12
    thr4 var portb.7 'assign thruster motor 4 to pin 13
    tempout var porta.0 'assign temperature sensor output to pin 17
    voltout var porta.1 'assign control battery (not flight batteries) voltage sense output to pin 18
    joy1v var word
    joy1h var word
    joy2v var word
    joy2h var word
    serial:
    hserin [wait ("A"), dec joy1v]
    hserin [wait ("B"), dec joy1h]
    hserin [wait ("C"), dec joy2v]
    hserin [wait ("D"), dec joy2h]
    thrusters:
    if (joy1v>600) then
    high thr1
    'Pauseus 500
    'Low thr1
    'Pauseus 1500
    if (joy1v<400) then
    low thr1
    if (joy1v<400) then
    high thr2
    'Pauseus 500
    'Low thr2
    'Pauseus 1500
    if (joy1v>600) then
    low thr2
    gosub serial
    The serial data being sent to the pic looks like: A123B12C945D3. Am I using HSERIN correctly?
    Thanks in advance.
    Default Re: pic16f88 Serial questions (hserin/hserout, etc.)
    Have you checked out Mister E's Multicalc "free" utility?
    I get these DEFINES for 9600 baud at 8 MHz.
    DEFINE HSER_SPBRG 12  ' 9600 Baud @ 8MHz, 0,16%
    There is a slight difference with your defines.
    Mister E's Multi-calc utillity: http://www.picbasic.co.uk/forum/showthread.php?t=4994
    Oct 2012
    Thanks for the reply. I made the changes, but unfortunately it still doesn't look like it's working.
    Does the RX pin (pin 8) need to be shorted to INT (pin 6)? I've seen schematics where the pins are shorted, but nothing in the documentation I've seen says this needs to be the case for what I'm doing.
    Hello harralk,
    put all this code in UPPERCASE letters
    make sure your arduino is sending data TRUE not inverted, you CAN invert it with a single transistor, be sure to pull up the Rx input with about 4.7k resistor. I know there PICs in the family which are not so fussy, but don't know which ones they are.
    No that's a different interrupt, & on the subject of interrupts, I suggest you get some, try ON_INTERRUPT goto serial then set your intcon register . . . or use Darrel's instant interrupts and let them do all that brain damage for you and get free use of mighty fast assembly interrupts (THANKS DARREL) !.
    I do not have an 16f88 on hand, here is your code with a little bit changed. I do not know what you have for configs as you did not post any
    DEFINE OSC 8
    OSCCON.4 = 1
    OSCCON.5 = 1
    OSCCON.6 = 1
    ANSEL = 0
    DEFINE HSER_RCSTA 90h 'set receive register to receiver enabled
    DEFINE HSER_TXSTA 20h 'set transmit register to transmitter enabled
    DEFINE HSER_BAUD 9600 'set baud rate
    DEFINE HSER_CLROERR   1 ;CLEAR OVERFLOW ERRORS
    ON INTERRUPT GOTO serial
    INTCON = %1100100
    PIE1 = %00100000
    PIR1 = %00000000
    RCIF VAR PIR1.5
    joy1v var word
    joy1h var word
    joy2v var word
    joy2h var word
    portb.0 = 0
    portb.1 = 0
    portb.3 = 0
    portb.4 = 0
    portb.6 = 0
    portb.7 = 0
    porta.0 = 0
    porta.1 = 0
    TRISA = %11111100 ;set PA 0 & 1 as outputs
    TRISB = %00100100 ;set pb.2 & 5 as inputs
    Main:  ; Loop to keep your code from running down and dripping all into your other routines
    while 1
    thrusters:
    if (joy1v>600) then
    high thr1
    'Pauseus 500
    'Low thr1
    'Pauseus 1500
    if (joy1v<400) then
    low thr1
    if (joy1v<400) then
    high thr2
    'Pauseus 500
    'Low thr2
    'Pauseus 1500
    if (joy1v>600) then
    low thr2
    wend
    serial:
    hserin [wait ("A"), dec joy1v] : RCIF = 0
    hserin [wait ("B"), dec joy1h] : RCIF = 0
    hserin [wait ("C"), dec joy2v] : RCIF = 0
    hserin [wait ("D"), dec joy2h] : RCIF = 0
    I have a concern that this code may hang up in the serial routine waiting for an A or B . . . .
    Here is a program I made to control some things via serial port, tested & working on a microchip demo board using a 16F690.No interrupts no hardware serial port hassels, and of course no hardware serial port advantages either. I want to think I might have looked over some of Bruce's code while making this, it's been a while.
    To use this send 3 bytes in hex (esp if using pickit2 to communicate) FF 01 01 turns on relay 1, FF 00 01 turns it off. . . .
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    DEFINE DEBUG_MODE  0    ' Debug sending True serial data
    DEFINE DEBUG_REG_PORTA  ' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUG_BIT 0      ' Debug.bit = PortA.0
    DEFINE DEBUG_BAUD 9600  ' Default baud rate = 9600
    DEFINE DEBUGIN_REG PORTA' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUGIN_BIT 1    ' Debugin bit PortA.1
    DEFINE DEBUGIN_BAUD 9600' Default baud rate = 9600
    DEFINE DEBUGIN_MODE 0   ' Debugin receiving data true = 0 inverted = 1
    relay		var byte     'relay number storage variable
    state		var byte     'relay state of ON/OFF variable
    state = 0
    relay = 0
    PORTC = 0
    ANSEL=0
    ANSELH=0
    ADCON0 = 0
    ADCON1 = 0
    CCP1CON = %10001100 ;Dual PWM 10xx11xx P1A/RC5 P1B/RC4 RC3/AN7 RC2/AN6
    TRISA = %00001110
    TRISB = %00000000
    TrisC = %00000000
    DEBUGIN [WAIT($FF),state,RELAY]
    PAUSE 30
    ON RELAY GOSUB  RELAY0,RELAY1,RELAY2,RELAY3,RELAY4
    DEBUG state,RELAY
    ;TOGGLE PORTC.0
    RELAY0:
    IF state = 1 THEN
    PORTC.0 = 1
    PORTC.0 = 0
    RELAY1:
    IF state = 1 THEN
    PORTC.1 = 1
    PORTC.1 = 0
    RELAY2:
     IF state = 1 THEN
    PORTC.2 = 1
    PORTC.2 = 0
    RELAY3:
    IF state = 1 THEN
    PORTC.3 = 1
    PORTC.3 = 0
    RELAY4:           'controls all ports simultaneously
    IF state = 1 THEN
    PORTC = 15
    PORTC = 0
    Oct 2012
    Thanks for the help, but it still isn't doing anything. I even tried eliminating the joystick input to the arduino and just send a series of 0's and 1's to make an LED blink - nothing.
    Just to double-check my methods, when you say add a pull-up resistor you mean add a resistor in series with the incoming serial line (TX from sender)? Or add a pull-up resistor off the +5V? I have tried both methods, by the way, just making sure I leave it the correct way. Also, elsewhere I see that the data into the pic16f88 should be inverted instead of true.....there was something mentioned in the PBP manual, can't remember off-hand exactly where I saw it.
    I have the serial monitor open for the arduino and it looks like it's sending the correct data. I have also changed the arduino code to just send a 0 or 1 instead of dec. 0-999. Here's the updated (and highly revised) pic code I'm using.
        __CONFIG _CONFIG1, _INTRC_IO & _PWRTE_ON & _MCLR_OFF & _LVP_OFF
    DEFINE OSC 8
    OSCCON.4 = 1
    OSCCON.5 = 1
    OSCCON.6 = 1
    ANSEL = 0
    INTCON = %1100100
    PIE1 = %00100000
    PIR1 = %00000000
    RCIF VAR PIR1.5
    joy1v var word
    joy1h var word
    joy2v var word
    joy2h var word
    portb.0 = 0
    portb.1 = 0
    portb.3 = 0
    portb.4 = 0
    portb.6 = 0
    portb.7 = 0
    porta.0 = 0
    porta.1 = 0
    while 1
    thrusters:
    if (joy1v>600) then
    high thr1
    'Pauseus 500
    'Low thr1
    'Pauseus 1500
    if (joy1v<400) then
    low thr1
    if (joy1v<400) then
    high thr2
    'Pauseus 500
    'Low thr2
    'Pauseus 1500
    if (joy1v>600) then
    low thr2
    wend
    serial:
    And just yesterday I tried using serin instead of hserin, here's that code:
    DEFINE OSC 8
    OSCCON.4 = 1
    OSCCON.5 = 1
    OSCCON.6 = 1
    ANSEL = 0
    CMCON=7
    INCLUDE "modedefs.bas"
    'DEFINE HSER_RCSTA 90h    'set receive register to receiver enabled
    'EFINE HSER_TXSTA 20h    'set transmit register to transmitter enabled
    'DEFINE HSER_BAUD 9600    'set baud rate
    'DEFINE HSER_CLROERR 1  'clear overflow errors
    'INTCON = %1100100
    'PIE1 = %00100000
    'PIR1 = %00000000
    'RCIF VAR PIR1.5
    'motor1 = portb.0 'assign main motor 1 to pin 6
    'motor2 = portb.1 'assign main motor 2 to pin 7
    'thr1 = portb.3 'assign thruster motor 1 to pin 9
    'thr2 = portb.4 'assign thruster motor 2 to pin 10
    'thr3 var portb.6 'assign thruster motor 3 to pin 12
    'thr4 var portb.7 'assign thruster motor 4 to pin 13
    'tempout var porta.0 'assign temperature sensor output to pin 17
    'voltout var porta.1 'assign thruster battery (not main batteries)
                         'voltage sense output to pin 18
    joy1v var word
    joy1h var word
    joy2v var word
    joy2h var word
    mode  con 2
    thr1vin var portb.2
    thr1hin var portb.1
    thr1vout var portb.6
    'portb.0 = 0
    'portb.1 = 0
    'portb.3 = 0
    'portb.4 = 0
    'portb.6 = 0
    'portb.7 = 0
    'porta.0 = 0
    'porta.1 = 0
    TRISA = %11111100 'set RA 0 & 1 as outputs
    TRISB = %00100100 'set RB 2 & 5 as inputs
    Main:  'Loop to keep your code from running down and dripping all into your other routines
    while 1
    thrusters:
    if (joy1v==1) then
    high portb.3
    Pause 250
    Low portb.3
    Pause 250
    if (joy1v==0) then
    low portb.3
    if (joy1h==1) then
    high portb.4
    Pauseus 250
    Low portb.4
    Pauseus 250
    if (joy1h==0) then
    low portb.4
    wend
    serial:
    serin thr1vin, 2, ["A"], joy1v
    serout thr1vout, 2, joy1v
    Could it possibly be that the pic is expecting to see a certain number of bits, and I'm not send them (I'm not using parity or stop bits, I don't think).
    I apologize for my absolute noobieness when it comes to serial, but I've been struggling with this for a couple weeks now and I just have no idea what it could be.
    Thanks again.
    Check this thread:http://www.picbasic.co.uk/forum/cont...rial-backpacks
    PBP does not natively import strings like C does and arduino uses C more or less. In the backpack code hserin is used to load an array and then the array is outputted to an LCD. It is set up to use DTs interrupts and works well.
    edit:
    as I UNDERSTAND ARDUINO: the serial data sent out is inverted, and I don't see a way in code to make it send true. You could use an NPN transistor to invert it back to true, or use debug as I did in my program for switching relays. Or us a another PIC instead of the Arduino. Or use a pic(if one exists) which allows inverted on the usart ( I vaguely remember getting beaten up over this once ;P)
  1. Help understanding HSERIN/HSEROUT
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2021, 08:47
  2. Hserin & Hserout - Trying to blink an LED
    Last Post: - 24th May 2010, 13:25
  3. PIC16F88 HSERIN to LCD Problem
    By robbrownuk in forum mel PIC BASIC Pro
    Last Post: - 6th June 2009, 23:32
  4. Problems with HSERIN HSEROUT
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 20th September 2005, 18:24
  5. Hserin/hserout ?
    By Scott in forum General
    Last Post: - 28th April 2005, 00:46
