Interrupt not working?
+ Reply to Thread
Results 1 to 13 of 13
    Jun 2011
    Philippines
    Default Interrupt not working?
    Hello everyone,
    I'm trying to build an application that will simply trigger relays using sms on GSM module.
    What I have done so far (basically)..
    1. Get GSM signal and manufacturer
    2. Send sms
    Now I'm trying to read incoming messages but with interrupt (with DT's). but it seems that when I send a message to the GSM the following block of code does not function
    Getbytes:
      HSEROUT ["Went here!!",13]
      i=i+1  ' coubt how many time it pass here
      cntr = 0
           While RCIF = 1     ' clear the buffer
           HSERIN 50,error,[Wait("P")] ' test it
           Hserout ["Got it!!",13]
           Wend
    @INT_return
    The following code is what I'm testing...I strip out the other codes within the main loop just to simply...
    '*  Name    : HACS.BAS                                      *
    '*  Notice  : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/20/2012                                        *
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        ;__CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ' Include if using PBP interrupts
    ; create the transmition interrupt
            INT_Handler   RX_INT,    _Getbytes,    PBP,  no
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    define OSC 48
    TRISA = %00001111
    PortA = %00000000
    TRISC  = %10000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
    ADCON1 = %00001111
    TRISD  = %00000111
    PortD =  %00000000
    PORTD = %00000000               ; set to PORTD low
    LedA var PortD.0                ;assign var LedA to PortD.0
    LedB var PortD.1                ;assign var LedB to PortD.1
    LedC var PortD.2                ;assign var LedC to PortD.2
    Load1 var PortD.3
    Load2 var PortD.4
    Load3 var PortD.5
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    DEFINE HSER_TXSTA 20h ' Enable transmit, BRGH = 1
    DEFINE HSER_BAUD 9600
    ; setup serial port line for transmition
    RCIF       VAR     PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
    TXIF       VAR     PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
    '------------------------------------------------------Transmition-------------
    But0 var PortA.0
    But1 var PortA.1
    But2 var PortA.2
    But3 var PortA.3
    Led1 var PortC.0
    Led2 var PortC.1
    Led3 var PortC.2
    Led1 = 0
    Led2 = 0
    Led3 = 0
    flag1 var bit
    flag1 = 0
    flag2 var bit
    flag2 = 0
    flag3 var bit
    flag3 = 0
    Pswd var byte[5]
    Data @0, 5,"12345"
    ArrayNum var byte[12]
    cntr var byte  'count error occur
    cntr = 0
    i  var byte
    i = 0
    PortB = %00000000
    SerialData var byte[10]
    LCDOUT $Fe,1
    LCDOUT $Fe,ln2 , "System loading.."
    pause 5000
    Gosub ButtOption1
    ;----Initialize text mode--------
    HSEROUT ["AT+CMGF=",49,13,10]
    HSERIN 5000, GSM_CHECK_ERR, [WAIT("OK")]
    LCDOUT $Fe,1 , "HASMS-CMS"
    LCDOUT $Fe,192, "Init Text MODE"
    LCDOUT $Fe,ln2, "                " ' clear second line
    Lcdout $FE, ln2,"system ready..."
    cntr = 0
    PAUSE 2000
    @   INT_ENABLE  RX_INT     ; enable RX_INT interrupts
    '--------------Main program start here--------------
    Main
    LCDOUT $Fe, ln1, "HASMS-CMS", Dec3 i
    LCDOUT $Fe,ln2 , "Listening...", DEC3 cntr
    if cntr < 254  then
    cntr = cntr + 1
    cntr = 0
    Endif
    pause 2000
    GOTO Main
    '--------------Main program end here--------------
    GSM_CHECK_ERR:
        cntr = cntr + 1
        LCDOUT $Fe, ln2, "GSM Error   #", DEC3 cntr
     Getbytes:
      HSEROUT ["Went here",13]
      i=i+1  ' count how many time it pass here
      cntr = 0
           HSERIN 50,error,[Wait("P")] 'test it
           Wend
    @INT_return
     error:
          Hserout ["Error",13]
    goto Main
    ButtOption1:
        LCDOUT $Fe,1 , "GSM Info"
        LCDOUT $Fe, ln2, "processing... "
        pause 1200
        High PortD.4
        pause 1200
        Low PortD.4
        '------------------- Determine Signal
        HSEROUT ["AT+CSQ",13,10]
        HSERIN 1000, GSM_CHECK_ERR, [WAIT("+CSQ: "),STR Serialdata\4]
        LCDOUT $Fe,ln2, "SIGNAL:",STR Serialdata\4
        cntr = 0
        '------------------- Determine Manufacturer
        PAUSE 3000
        HSEROUT ["AT+CGMI",13,10]                           'Ask model name
        HSERIN 5000, GSM_CHECK_ERR, [WAIT("SIMCOM"),STR Serialdata\4]
        LCDOUT $Fe,ln2, "MANUF:SIMCOM",STR Serialdata\4
        cntr = 0
        pause 3000
        LCDOUT $Fe,1    ' Clear LCD
    I think the GetBytes sub program triggers on boot up because it displays Hserout ["Went here",13]...after that when it enters to the main loop and try to send sms to the device it never get the interrupt.
    Can anyone spot what I'm missing? I've been going nuts with it the whole week
    tacbanon
    Default Re: Interrupt not working?
    I might not be thinking correctly, but I think the reset flag should be set to "yes".
    Jun 2011
    Philippines
    Hi mackrackit, I tried what you suggested but no luck...thanks for replying.
    /tacbanon
    I have this:
    INT_LIST  macro    ; IntSource,        Label,           Type,   ResetFlag?
            INT_Handler    RX1_INT,    _ReceiveInterrupt,    PBP,    no
        INT_CREATE                              ; Creates the interrupt processor
    and it works fine on 6 slaves.
    PortD =  %00000000
    Are you sure that's enough?
    Seriously, I've seen several comments about both TX and RX pins should be set to input in TRIS. USART then takes control and decides what they should be.
    CCP2MX_ON_3H
    Do you really need that feature enabled?
    Jun 2011
    Philippines
    Hi Robert, thanks for giving the time to look onto the codes...I will try to check on it and see what will happen...
    tacbanon
    Leave the GSM aside for a while and test you program with a terminal.
    Then just type on the keyboard what you expect your PIC to receive and see if that works.
    Jun 2011
    Philippines
    @Ioannis
    I have the following code below that works when sending to the SerialComm...
                         'Hserin with Darryl Taylor's Instant Interrupts
    asm
    endasm
            DEFINE OSC 48
            DEFINE HSER_RCSTA 90h ' enable serial port,
            DEFINE HSER_TXSTA 20h  ' enable transmit,
            DEFINE HSER_CLOERR  1 ' automatic clear overrun error
        '   Serial communication definition
      ADCON1 = %00001111      'Set up ADCON1 register no matter what you're doing!!!!!!
        '   Variable definition
    PortB = %00000000
    TRISB = %00000000
    led        var     PORTC.0
    led1        var     PORTC.1
    holdoff    var     word
    SerialData var     byte
    SerialInput var    byte[50]
    PortB = 0
    c var byte
    i var byte
    c = 0
    clear
                       ' Subroutine to slow loop down some and toggle heartbeat
    Mainloop:
     c = 0
            for holdoff = 1 to 100
            pause 1
            next holdoff
            toggle led           'toggle led every loop for heartbeat
            goto Mainloop
               'ISR for RX_int interrupt
    Getbytes:
           c = c + 1
           'HSEROUT ["Process "]
           HSERIN 100,error,[Serialdata] ' take it
           HSEROUT [Serialdata] ' take it out
           SerialInput[c] = Serialdata
           select case Serialdata          ' What to do with that data???
               case "^"            ' User selection = 1
                    HSEROUT ["Goto Sub Process "] ' take it out
                    gosub displaydata
           End select
           Wend
           toggle led       'led to confirm program went to RX ISR
    @ INT_RETURN
    error:
          Toggle led1
    @ INT_RETURN
     displaydata:
            for i = 1 to c
             Hserout [SerialInput[i]]
            next i
    Then I tried to insert GSM related one block of code at a time but the same result (triggers interrupt only once--upon bootup)..
    >>>tacbanon
    Some random thoughts:
    The TX interrupt flag gets cleared by the hardware when the buffer is emptied - which it is by reading it so Reset Flag=NO is correct.
    Perhaps you're overflowing the buffer?
    When you're "emulating" the GSM-module by sending characters manually from the terminal your sending them quite slowly - if you're sendig them one by one as you are typing them. When you then plugin the GSM-module it'll send the same string (hopefully) at the same baudrate as you did manually but the time between each character is a lot shorter so the time the ISR has to process each character is shorter.
    I see that you have a HSEROUT ["Process"] in the ISR, things like that WILL overflow the buffer because your sitting in a loop spitting out the word 'Process' (7 bytes) while more might be comming in. The TX-buffer is only one byte deep so the program will have to put in the 'P' then wait for it to go out, put in the 'r', then wait for it to go out and so. Not untill it has put the last 's' in the Tx-buffer will it continue. In the meantime bytes are still trying to get into the Rx-buffer which is only 2 bytes deep - the buffer will likely overflow.
    Now, I see that you've commented the above line out which is good but it illustrates the issue I'm trying to get at perfectly.
    Also, I'm not sure if it's intentionally but you're resetting the counter (c) each time thru the main loop so if the mainloop startover in the middle of a string it will start overwriting itself. I think that what you want is to reset (c) at the end of DisplayData routine, and possible in the Error routine.
    Finally, at the beginning of the program, try inserting a lengthy pause to allow the PIC and the GSM-module to power up properly then make sure the USART buffer is clear and the interrupt flag reset - then enable the interrupt. If the GSM module has an enable input or something tie that to an output on the PIC so you can keep it disabled untill you're ready.
    Is that too much stuff going on inside ISR?
    What if you simplify usart logic until you get things working as expected?
    Do you really need byte-by-byte reception? Can you get away with a fixed length message?
    My interrupt routine looks like this:
    ReceiveInterrupt:
      HSERIN 50,No232,[DEC5 PicIn.byte1, DEC5 PicIn.byte0, DEC1 CommandIn, _
                       STR DataIn1\24, STR DataIn2\24,                     _
                       DEC5 CheckSumIn.byte1, DEC5 CheckSumIn.byte0]
      RS232Flag = StateTrue
    No232:
    @ INT_RETURN
    I check in main loop if RS232Flag was set, and then do all the processing there.
    Jun 2011
    Philippines
    Thank you Henrik for explaining it well and giving me ideas how to trace the steps the codes is doing.
    and thank you Robert for sharing your code...I will try them out.
    regards,
    tacbanon
    For sending a string of keystrokes instead of typing and having a delay, as Henrik spoted, try this terminal program:
    https://sites.google.com/site/termin...attredirects=0
    It can accept a string of characters and then you hit send to send it as it would your GSM device.
    Jun 2011
    Philippines
    Finally we got the power back today...we've been battered by the typhoon 'OFEL'...
    @Ioannis
    Thanks for the link..I will try and let you know...later.
    tacbanon
  1. SERIN Not Working, SEROUT Working
    By cc1984 in forum Serial
    Last Post: - 26th October 2010, 19:16
  2. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 17:01
  3. ON INTERRUPT not working
    Last Post: - 12th April 2008, 13:41
  4. PIC to PC not working
    By The Master in forum Serial
    Last Post: - 30th October 2007, 04:34
  5. Replies: 0
    Last Post: - 27th August 2004, 07:20
