Digital input chips, I am looking for any.
+ Reply to Thread
Results 1 to 2 of 2
    Feb 2005
    Holmfirth England
    Question Digital input chips, I am looking for any.
    In the past I have used the good old 2803 octal driver as inputs to a pic where space was too tight for using opto isolators.
    This proved to be problematic, interference wise, due to the darlington inputs needing hardly any current to drive them.
    See the schematic.
    I am looking for chips that will take 8 inputs, at preferably 24V, and turn them into 5V EMI proof outputs.
    I'm not having much success. I have found one that does this but only with serial output, not individual output lines.
    Bob.
    Default Re: Digital input chips, I am looking for any.
    I tend to use opto-isolators because of their ease of use and fairly low price (obviosuly depending on what performance you need). They also require a bit of current which inherntly makes them less sensitive to noise being picked up by long cables etc. TCMT4100/4600, LTV847/844 etc in SO16 package are my usual goto-parts. The PS2841 gives you four channels in a little 12-pin BSOP package - good looking device that - just stumbled across it.
    As I was looking around I found the ISO1I881T which claims to be an Isolated 8 Channel Digital Input with IEC61131-2 Type 1/2/3 Characteristics. I haven't looked at the details but might be worth to take a look at. Not cheap though...
    Let me know if you find anything suitable!
  1. get a sensor digital input to work on a pickit 2 16f690 lpc
    By Jasonstew in forum mel PIC BASIC Pro
    Last Post: - 26th June 2011, 21:26
  2. How do I get 18f452 pin 10 set as digital input?
    Last Post: - 26th May 2007, 18:32
  3. Really slow digital input
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 04:06
  4. 18F4550 digital input
    Last Post: - 29th March 2007, 02:43
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 00:32
