Max31855 Thermocouple Temperature Reading
Results 1 to 6 of 6
    Lefteris's Avatar
    Lefteris Guest
    Smile Max31855 Thermocouple Temperature Reading
    I was looking hard to find a picbasic code for the new MAX31855 from Maxim but I could't find anywhere.
    This is a nice chip to read temperature from -210 up to 1300 C for many types of thermocouples with internal ColdJuction and faults report!!.
    Here is datasheet for details : http://datasheets.maximintegrated.co...s/MAX31855.pdf
    Thermocouples are using for high temperatures, so I am not interesting for negative sign !!!
    I send data to PC using Hyperterminal at 9600 bauds.
    Brown out detect is disable So I can use 3.3 Volts supply on my pic16f877A
    I hope this code is usefull for you as is for me!
    define OSC 20
    @ DEVICE PIC16F877A,HS_OSC,WDT_ON,MCLR_OFF,BOD_Off,LVP_OFF,PROTECT_OFF
    include "modedefs.bas"
    '----- Data Output To Pc Without MAX232 at 9600bauds reverse ----
    DataTx var portc.6  'TX serial data to PC
    BaudTx con 16468     '9600 bauds reverse
    'Alias pins - MAX31855 temp sensor
           MXSCLK      var     PORTD.0   'MAX31855 Clock
           MXCS        var     PORTD.1   'MAX31855 Chip Select
           MXSO        Var     PORTD.3   'MAX31855 Serial Data
           '--Variables-----------------------
           TCtemp       var     word    'raw data from MAX31855
           tempC       var     word    'temperature in degrees C
           tempF       var     word    'temp C converted to degrees F
           CJtemp       var     word    'raw data from MAX31855
           tempcjC       var     word    'temperature ColdJuction in degrees C
           tempcjF       var     word    'ColdJuction C converted to degrees F
      '-----------Read and display temperature from MAX31855-----------
           'Read Temp of Thermocouple
           LOW MXCS                            'chip select low
           shiftin MXSO, MXSCLK, 0, [TCtemp\16] 'shift in the data
           HIGH MXCS                           'chip select high
          tempC =   TCtemp >> 4              'side shift to ditch the stuff to the right of the decimal point and just show whole degrees)
          tempF = ((tempC * 18)/10) + 32      'convert C to F
         '--------- Send Temp To PC ------------------
          if TempC.bit11 = 0 then        'Positive Sign of Temperature
          SEROUT2 DataTx,BaudTx, ["Theromocouple ",dec tempc ," degrees C  ",dec tempF," degrees F  " ,10,13 ] 'display the data on PC
           PAUSE 1000
            SEROUT2 DataTx,BaudTx, ["OUT of Range ",10,13 ]
          'Read Temp of ColdJuction
           shiftin MXSO, MXSCLK, 0, [CJtemp\32] 'shift in the data
          tempcjC  =   CJtemp>> 8                 'side shift to ditch the stuff to the right of the decimal point and just show whole degrees)
          tempcjF  = ((tempcjC * 18)/10) + 32      'convert C to F
          '--------- Send Cj Temp To PC ------------------
          SEROUT2 DataTx,BaudTx, ["ColdJuction ",dec tempcjc ," degrees C  ",dec tempcjF," degrees F  " ,10,13 ] 'display the data on PC
         'Check Thermocouple Status
          IF CJtemp.bit0=1  THEN
          SEROUT2 DataTx,BaudTx, [" NO CONNECTION  " ,10,13 ] 'display the data on PC
         IF CJtemp.bit1=1  THEN
          SEROUT2 DataTx,BaudTx, [" SHORT to GND " ,10,13 ] 'display the data on PC
            IF CJtemp.bit2=1  THEN
          SEROUT2 DataTx,BaudTx, [" SHORT to VCC   " ,10,13 ] 'display the data on PC
        PAUSE 1000
    Aug 2008
    Portugal
    Default Re: Max31855 Thermocouple Temperature Reading
    Thank you!
    Thanks and Regards;
    Gadelhas
    Jan 2013
    Thank you, I modify your code to work with PIC16F690 and to display temperature on serial 20x4 LCD and it works great.
    I have also tried to modify this code for LCD, but I'm getting very low readings in C. and also, they change strangely - when I heat thermocouple, they start to increase, than at some point (always different), will decrease by 5-10C and then again increase.
    Sep 2008
    Maine, USA
    Thanks Lefteris - this was very helpful. Not clear why you shift the data right by 4 bits, but it works great. Thanks for posting this!
    "Do or do not, there is no try" Yoda
    @ __config _HS_OSC & _WDT_ON & _PWRTE_ON &_BODEN_OFF & _LVP_OFF & _CPD_OFF
    Appears orig. config was for PB compiler AND NOT for 16F877a as stated as there is NO MCLR or PROTECT
