Hi Guys , having some problems getting IOC working on the 16F1825 , and wondered if its cos the pin is used both as input and output at times though out the program
Question is
A. Do i need to disable interrupts during the time the pin is used as an output or its does not matter as its an output ?
b. when using DT-int14 for this chip , i am aware that the interupt needs to be cleared before returning , is this a ASM clear or can this be a PBP clear - see part code
c. Do i need to enable IOC in Intcon or not worry as its done in the DT_ints-14 code
Cheers
Sheldon
INCLUDE "DT_INTS-14.bas"
INCLUDE "ReEnterPBP.bas"
INT_Handler IOC_INT,_GetIRcode, PBP, yes ; call GetIRcode subroutin on Interupt
INT_CREATE ; Creates the Interrupt Processor
INTCON = %10001000 ' Interupts Clear - GIE,PEIE,TMR0IE,INTE,IOCIE,TMR0IF,INTF,IOCIF
IOCAN.4 = 1 ' Enable interupt on change on portA.4 for negative going edge ( for getIR routine )
IOCAF.4 = 0 ' Clear Interupt on Change flag on portA.4
@ INT_ENABLE IOC_INT ; Enable PortA Change on Interrupt
' ============ Get IR Code Routine ================
' * ******* IOC - Interupt Handler routine ******* *
GetIRcode:
' TRISA.4 = 1 ' setup input=1,output=0 TRISA.3 = 1 to input
PULSIN IR,1,Leader ' get leader high pulse time value in on TRISA.4 ( pulsin_max set to 21600 = 108ms )
IF Leader < 800 tHEN ' look for 4500us high pulse - below 4000us then its 2nd key area pulse or data/ address bits (800^ 5us= 4000us)
IOCAF.4 = 0 ; clear IOCAF - clear the IOC flags port A
@ INT_RETURN
Endif
IF Leader > 960 tHEN ' above 4800us then it no sig (960*5us=4800us)
IOCAF.4 =0 ; clear IOCAF - clear the IOC flags port A
@ INT_RETURN
x=0 ' ensure 0
FOR X = 0 TO 31 ' grab 32 incoming pulses
PULSIN IR,1,leader ' now measuring high-going pulse widths
BtnVal(x) = leader/2 ' leader divide by 2 so Btnval(x) is byte (<255) not word value
NEXT X
z = 0 ' Z points to start range of byte
S = 7 ' S points to end range of byte
X = 0 ' start X at 0 to line up with BtnVal array
y = 0 ' ensure 0
for Y = 1 to 4 ' Get in Array and decode 4 bytes from 32 bit pulses
T = 7 ' Set T to 7 so that it puts BtnVal(0) in to D7 location
FOR X = Z TO S ' sort 8 pulses of byte
IF BtnVal[X] > 120 THEN ' > 120 x (5uS *2) = > 1.2mS pulse period = 1 (150)
DByteTmp = DByte[Y] ' get into temp var
DByteTmp.0[T]=1 ' Set value to 0 or 1 , T reverses bit order of BtnVal(x) so byte has correct bin value to write byte
DByteTmp.0[T]=0 ' Set value to 0 or 1 , T reverses bit order of BtnVal(x) so byte has correct bin value to write byte
DByte[Y] = DByteTmp ' get it back into DByte(y)
T = T - 1 ' T points to next MSB on loop
NEXT X
Z = x ' Z = X (0,8,16,24) points to start of next byte
S = 7 + X ' S (7,15,23,31) points to End of next DByte BtnVal offset to X
next Y ' loop for 4 bytes
' only save code if it differant to stored IR code
' **** this will need to change when using the config IR section
x=1 ' ensure 1
for x = 1 to 4
read x , STDByte[x] ' read the last saved IR code at startup
if DByte[x] <> STDByte[x] then
write x,DByte[x]
next x
IOCAF.4 =0 ; clear IOCAF - clear the IOC flags port A.4
@ INT_RETURN ; return used for Interupt call
