Can someone please provide a proteus module for DAC ??
Results 1 to 10 of 10
    Jan 2010
    Default Can someone please provide a proteus module for DAC ??
    Can someone be kind enough to provide me a proteus module to operate a DAC. I read few posts and it seems it is not an easy task for someone like me to make one easily as I don't know too much about electronics. All I need is a uC connected to a DAC. I would like to have serial window in which I type the 10 bit number and the DAC outputs the corresponding voltage.
    I am sure everyone can use this kind of modular attachment in their proteus designs and check their simulations properly.
    Jan 2010
    Default Re: Can someone please provide a proteus module for DAC ??
    Anyone, Please help?
    I am only asking this because I find it impossible to provide voltage to my ADC in 1.22mV increments.
    What real life parts are you having trouble with? What exactly are you trying to do?
    Jan 2010
    Hi mackrackit, I have developed a circuit in proteus to learn more about ADC which I am trying to simulate. It's just for learning currently what I am doing. I tried using the POT component, but the increments cannot be controlled precisely. I saw Darrel advising in some post to use DAC in the library, but that's way out of my league currently. So I was wondering if someone would be kind enough to create a module in proteus which I can add to my design and connect the output of the created module to my simulation, that way I can have full control over ADC 10 bit range. Having a micro controlling the ADC will be a big benefit as using a mirco and Virtual terminal, any value can just be written in the Virtual terminal (0-4096) as an input to the micro and the micro can make the ADC output the corresponding voltage.
    If Darrel does not see this thread you might try contacting him directly.
    I do not use SIMs, that is why I ask about the real life parts. Do you have a bread-board?
    Mar 2006
    China
    I dont use sims either but why dont you connect a signal generator and feed the signal to an
    --R --- R ---
    C C
    GND
    low pass filter and after that you should have a DC level that adjusted by the amplitude from the signal generator. If you use PWM signal it should be linear.
    Jan 2010
    Thanks jumper, what you are saying is at a much higher level than I can understand. I really would like someone with expertise in proteus to help me.
    Jan 2010
    I tried with DAC_10 device under Modelling Primitives, I don't know if I am doing it right, but I connected D0-9 bus to 10 dip switch array. VRef+ to +5V and - to Gnd. Changing the DIP switch position is not changing the output voltage, which is staying as constant 0V. I tried connecting LE pin to +ve & ground both but no luck.
    Did you label the blue bus (just outside the chip) with d[0..9], and label all the individual lines from the dip switch that go to the blue bus ( d0, d1 ...)
    http://www.scalerobotics.com
    Here's an example that gives two 12-bit analog voltages using a DAC.
    A Virtual Terminal is used to set the voltages.
    http://support.melabs.com/threads/28...replaces-pots)
