highest or lowest variable in an array; how do you find it?
Results 1 to 7 of 7
    Dec 2009
    Kalamazoo
    Default highest or lowest variable in an array; how do you find it?
    Hi everyone.
    im trying to determine the highest and lowest variable in a 50 byte array. whats the easiest way to do it?
    NAG CON WIFE!
    WIFE VAR MOOD
    Default Re: highest or lowest variable in an array; how do you find it?
    Here's one way:
    i       var byte
    lowest  var byte
    highest var byte
    myarray var byte[50]
    'then do something to fill array with data
    lowest = 255
    highest = 0
    for i = 0 to 49
        if myarray[i] < lowest then lowest = myarray[i]
        if myarray[i] > highest then highest = myarray[i]
    next i
    http://www.scalerobotics.com
    Quote Originally Posted by DDDvvv View Post
    Hi everyone.
    yArray VAR BYTE[50]
    yLow VAR BYTE
    yLow = 255
    yHigh VAR BYTE
    yHigh = 0
    i VAR BYTE
    FOR i = 0 TO 49
    IF yArray[i] < yLow THEN
    yLow = yArray[i]
    IF yArray[i] > yHigh THEN
    yHigh = yArray[i]
    NEXT
    Not being duplicative just that ScaleRobotics Posted First.
    Norm
    Nov 2009
    London
    I'll take a shot at it as well, but the gurus have already replied, this is just a little different.
    i       var byte
    lowest  var byte
    highest var byte
    for i = 0 to 48
       Highest= MyArray[i] MAX MyArray[i+1]
       Lowest= MyArray[i] MIN MyArray[i+1]
    next i
    ScaleRobotics, I hope you had good internet free holidays
    I don't think Megahertz code will work as it is resetting the maximum and minimum value each pass thru the loop. NO testing is being done against the variables "Highest" and "Lowest"....
    EN82fn
    Nov 2009
    London
    OOps, my mistake. Instead use the following:
    i       var byte
    lowest  var byte
    highest var byte
    CheckHigh Var Byte
    CheckLow Var Byte
    CheckHigh=0 : CheckLow=255
    for i = 0 to 48
       CheckHigh= MyArray[i] MAX MyArray[i+1]
       If CheckHigh>Highest then Highest=CheckHigh
       If CheckLow<Lowest then Lowest=CheckLow
    next i
    Thanks Dave for correcting me
    Dec 2009
    Kalamazoo
    thanks guys .
    i was thinking of doing it like post #2, and i thought there was an easier way to skin it. this really helps alot with all this options.
    NAG CON WIFE!
    WIFE VAR MOOD
