Communication help for DCC (Digital Command Control)
Results 1 to 5 of 5
    Dec 2008
    Default Communication help for DCC (Digital Command Control)
    I am working on some new ideas for my model railroad and would like some help with DCC communication. I have the documentation that tells you how the communication works. However, it should be done via interrupts and thats where I need help. I attached the document that explains how DCC works. The chip of choice is the 18F2620. I know this chip should work as it is used in lightorama.com controllers ( DMX communications ).S-92-2004-07.pdf
    Default Re: Communication help for DCC (Digital Command Control)
    Nov 2013
    Did you finished it ?
    You made a decoder, or a command control ?
    Dec 2008
    Quote Originally Posted by billys7 View Post
    No not yet....it got put on the back burner with house projects. Gotta love "home" work.
    Feb 2008
    Michigan, USA
    I got sidetracked too, but here is a discussion that has a few references: http://www.picbasic.co.uk/forum/showthread.php?t=9559
    Bo
