16f84A to 16f628A
Results 1 to 9 of 9
    Sep 2009
    Default 16f84A to 16f628A
    Hi friends
    I am new user in picbasic
    And need help, for the transformation of this code to work on 16F628A instead of the 16F84A
    @ device PIC16F84A, HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF
    TrisA = %00000000
    PortA = %00000000
    TrisB = %00000001
    PortB = %00000000
    Digit Var Byte
    Time  Var Word
    Tcon Con 245
    Time = Tcon
    Imp   Var Word
    Imp = 0
    RPM   Var Word
    RPM = 0
    OPTION_REG = %10000011
    TMR0=5
    INTCON = %10110000
    Pause 1000
    PortB = $7e  '-
    PortA.0 = 0: PortA.1 = 0: PortA.2 = 1
    Pause 1000
    PortB = $7e  '-
    PortA.0 = 0: PortA.1 = 1: PortA.2 = 0
    Pause 1000
    PortB = $7e  '-
    PortA.0 = 1: PortA.1 = 0: PortA.2 = 0
    Pause 1000
    ' ------------------------- [ Interrupt ] -------------------------
    On Interrupt Goto myint
    ' ------------------------- [ Main ] -------------------------
    Digit = RPM Dig 0
    GoSub Look
    Pause 4
    PortB = $FE
    Digit = RPM Dig 1
    GoSub Look
    Pause 4
    PortB = $FE
    if RPM < 100 then
    Pauseus 300
    Goto Main
    Digit = RPM Dig 2
    GoSub Look
    Pause 4
    PortB = $FE
    Goto Main
    Disable
    Myint:
    if intcon.1=1 then
    Imp = Imp + 1
    INTCON.1 = 0
    if intcon.2=1 then
    Time = Time - 1
    if Time = 0 then
    Time = Tcon
    RPM = Imp * 60 / 10
    Imp = 0
    TMR0=5
    intcon.2=0
    Resume
    Enable
    Look:
    LookUp Digit, [$80, $F2, $48, $60, $32, $24, $04, $F0, $00, $20], PortB
    May 2009
    Default Re: 16f84A to 16f628A
    Change first line to @ Device PIC16f628A HS_OSC, WDT_OFF, PWRTE_ON, CP_OFF
    That in theory is all that should be needed.
    Quote Originally Posted by grahamg View Post
    nope, 16f628 has comparators too add cmcon = 7
    Sep 2009
    I made the changes and work henceforth in 16F628
    I thank you for the precious help
    Sep 2009
    I made an addition to the code
    The PortA.3 working properly, the PortA.4 but did not work always remains at a low level
    What I make error, please help
    TrisA = %00000000
    PortA = %00000000
    TrisB = %00000001
    PortB = %00000000
    Digit Var Byte
    Time  Var Word
    Tcon Con 245
    Time = Tcon
    Imp   Var Word
    Imp = 0
    RPM   Var Word
    RPM = 0
    TMR0=5
    INTCON = %10110000
    Pause 1000
    PortB = $7e  '-
    Pause 1000
    PortB = $7e  '-
    Pause 1000
    PortB = $7e  '-
    Pause 1000
    Digit = RPM Dig 0
    GoSub Look
    Pause 4
    PortB = $FE
    Digit = RPM Dig 1
    GoSub Look
    Pause 4
    PortB = $FE
    if RPM < 100 then
    Pauseus 300
    Goto Main
    Digit = RPM Dig 2
    GoSub Look
    Pause 4
    PortB = $FE
    ' ----------------------- [ HIGH RPM ] -----------------------
    if RPM >= 60 then
    high PortA.3
    low PortA.3
    if RPM >= 70 then
    high PortA.4
    low PortA.4
    Goto Main
    Disable
    Myint:
    if intcon.1=1 then
    Imp = Imp + 1
    INTCON.1 = 0
    if intcon.2=1 then
    Time = Time - 1
    if Time = 0 then
    Time = Tcon
    RPM = Imp * 60 / 10
    Imp = 0
    TMR0=5
    intcon.2=0
    Resume
    Enable
    Look:
    May 2009
    You have not added Cmcon=7. Put it at the start of the program
    Sep 2009
    grahamg Yes I added cmcon = 7
    @ device PIC16F628A, HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF
    TrisA = %00000000
    PortA = %00000000
    TrisB = %00000001
    PortB = %00000000
    cmcon = 7
    Digit Var Byte
    Time Var Word
    Tcon Con 245
    Time = Tcon
    Imp Var Word
    Imp = 0
    RPM Var Word
    RPM = 0
    TMR0=5
    INTCON = %10110000
    Pause 1000
    EEPROM 80,[83,46,84,32,69,108,101,99,116,114,111,110,105,99,1 15]
    May 2008
    Italy
    RA4 is an open collector pin so it will not turn from zero to 5 volts as all the digital pins.
    If all you need is to turn your led on & off, then connect your 330 ohms resistor to 5 volts and RA4 pin to junction from led and 330 ohms resistor.
    Remember then when pin is on your led will be off.
    Cheers
    Al.
    Sep 2009
    Friend aratti yes you have absolute right
    Now works also the PortA.4 yessssssssssssssssssss
    Thank you very much
