newbe wants to store in 16f887 eeprom help
Results 1 to 6 of 6
    Sep 2008
    Default newbe wants to store in 16f887 eeprom help
    I am using a DTMF decoder with the 16f887 chip. The decoder circuit works great which and simply runs a program, and that works great. is there a statement that can tell the e prom in the 16f887 chip to run a goto routine r something like that. I want the e prom to hold this in memory forever and always run this new routine. then upon another DTMF command, it will go back to the normal routine that it started with. The DTMF part of this is solved. But cannot figure the e prom storage part of it. Thanks Leon
    Default Re: newbe wants to store in 16f887 eeprom help
    What about GOSUB the special routine IF you get that DTMF command, ELSE GOSUB the regular routine?
    You can add more routines in the IF later for extra DTMF commands.
    Dec 2011
    IO93ok
    I suspect you need SELECT CASE in the program not the eprom space which is used for DATA storage.
    I'm guessing you are using the tones as a control method. So you want a single tone or combination of tones to do something.
    You need to save the output of the tone decoder to a variable then use the variable result to Select Case . Each CASE can have the code you want to run.
    It's in the PBP manual.
    Eeprom is useful if your device powers down and up and you want continuity in your logic.
    Store your variable to eeprom before shutting down,then read it after power up and return it in a variable.
    Sep 2008
    Hi Demon, sounds like you are smart. What you are explaining makes sense. Yes, the DTMF decoder output goes to 4 ports of the 16f877. It is easy to do, If portx and portx and portx and portx=1 then decode or something like that. I do have the DTMF decoder and chip to work great. But I am trying to learn how to write the basic code to get the eprom to store this and turn on a port that will always
    upon 16f887 power up (once activated)will always turn on this port until a different(reset) DTMF code is received. Once the reset DTMF code is received, this port will not turn on up power up. I have tried with no success to get this to work. Any help on code to do this. Point me in the right direction. Thanks so much, Leon
    Dec 2011
    IO93ok
    I know I'm not smart enough but here's a small program i wrote to generate frequencies.
    Note that it reads and stores values both previous and new values to eeprom.
    '*  Name    : freqgen.BAS                                       *
    '*  Author  : Rob Lane                                          *
    '*  Notice  : Copyright (c) 2011                                *
    '*  Date    : 09/08/2011                                        *
        eeprom 4,[$10,$0e]   ' program in first run freq value 3600Hz (lowest)
        include "Modedefs.bas"      ' for lcd baud rate
        define OSC 10               ' for lcd baud rate 9600
    Duty        var byte         'duty cycle value (max 255)
    Freqval     var word         'frequency variable
    A2          var byte         'Button' variable
    Counter1    var byte
    PercVal     var word
    PercVal2    Var byte
            '      Control Buttons/Lines
        TRISA=%00011111      ' button pins
        TRISB=%00000000      ' port b as outputs
        CMCON=7              ' comparator ports to digital
        Pause 500 ' lcd to settle
        read 4,Freqval.byte0    'read previously stored freq
        read 5,Freqval.byte1    'from eeprom at power up
        SERout PortB.7,N9600,[254,1]   'lcd CLS
        pause 10                ' needed after cls command
        Duty=64                 ' set HPWM duty cycle
        A2=0                    ' set button debounce
        hpwm 1,Duty,Freqval         'output freq to hardware pwm channel 1
        PercVal=(Duty*1000)/256
        PercVal2=PercVal dig 0
        PercVal=(Duty*100)/256
    mainloop:
        serout PortB.7,N9600,[254,128]   'lcd line 1 home
        SERout PortB.7,N9600,["Frequency: ",#Freqval ]
        serout PortB.7,N9600,[254,192]   'lcd line 1 home
        SERout PortB.7,N9600,["Duty cycle: ",#PercVal ,".",#PercVal2,"%" ]
        Button PortA.0,0,255,0,A2,1,upfaster
        Button PortA.1,0,255,0,A2,1,downfaster
        Button PortA.3,0,255,0,A2,1,upslow
        Button PortA.4,0,255,0,A2,1,downslow
        high PortB.0       '==  LED on
        pause 500          '==  blink led to show in loop
        low PortB.0        '==  LED off
        pause 500          '==  for testing purposes
        goto mainloop
    freqgenoff:
        TRISB=%00001000    'turn off hpwm register
        goto mainloop
    freqsave:
        write 4,Freqval.byte0   'save freq to eeprom
        write 5,Freqval.byte1   'at button press end and
        goto mainloop           'return to main loop
    'UP FAST ===============================
    upfaster:
    upfast:
        if PortA.0=1 then freqsave  ' 1st trap exit to 'save' loop
        Freqval=Freqval+100       'increment freq
        if Freqval>=32000 then freqval=32000  'hold if at highest freq figure
        pause 5                          'slows looping
        if PortA.0=1 then freqsave          '2nd trap exit to 'save' loop
        goto upfast
     'DOWN FAST ===============================
    downfaster:
    downfast:
        if PortA.1=1 then freqsave  ' 1st trap exit to 'save' loop
        Freqval=Freqval-100       'decrement freq
        if Freqval<=700 then freqval=700  'hold if at highest freq figure
        if PortA.1=1 then freqsave          '2nd trap exit to 'save' loop
        goto downfast
    'UP Routine ============================
    upslow:
        counter1=1
    slowup:
        For counter1 = 1 to 5       ' if press longer than 5 then speedup
        if PortA.3=1 then freqsave  ' 1st trap exit to 'save' loop
        Freqval=Freqval+1       'increment freq
        pause 500                           'slows looping
        if PortA.3=1 then freqsave          '2nd trap exit to 'save' loop
        next counter1
        goto frequp
    frequp:
        hpwm 1,Duty,Freqval       'output freq to hardware pwm channel 1 @ 25% duty cycle(64)
        Freqval=Freqval+10       'increment freq
        pause 50                      'slows looping
        if PortA.3=1 then freqsave   '2nd trap exit to 'save' loop or
        if PortA.3=0 then frequp     'loop frequp
    'DOWN Routine ==========================
    downslow:
        counter1=1
    slowdown:
        if PortA.4=1 then freqsave  ' 1st trap exit to 'save' loop
        Freqval=Freqval-1       'decrement freq
        if Freqval<=700 then freqval=700   'hold if at lowest freq figure
        if PortA.4=1 then freqsave   '2nd trap exit to 'save' loop
        next counter1
        goto freqdown
    freqdown:
        hpwm 1,Duty,Freqval
        Freqval=Freqval-10
        if Freqval<=700 then freqval=700  ' hold if at lowest freq figure
        pause 50
        if PortA.4=0 then freqdown
