Change a variable to the opposite?
Results 1 to 11 of 11
    Sep 2007
    Default Change a variable to the opposite?
    I want to connect a BCD thumbwheel to my board. However, instead of 1001 = 9 which is what the thumbwheel outputs, I need 0110.
    I'm not sure why the circuitry is like this but I was wondering if there was a simple command to flip a whole variable or what the best way to do this would be?
    Thank you.
    Default Re: Change a variable to the opposite?
    Untested, but give it a try:
    For i = 0 to 3
      BCD_Value.0[i] = ~BCD_Value.0[i]
    NEXT
    Sep 2007
    I came up with:
    For I = 0 to 3
    if BCD_In.0[I] = 0 then
    BCD_In.0[I] = 1
    BCD_In.0[I] = 0
    next I
    But yours is much simpler!
    Perfect.
    Thank you.
    Nov 2009
    London
    BCD_Value=BCD_Value ^ $0F
    Sep 2007
    Megahertz,
    If I understand yours correctly, you're raising the value to the power of 15? How did you come up with 15? Is that a function of the 4 bits? So if it is an 8 bit variable what would the value be?
    I just want to understand the logic behind it.
    Thank you
    May 2006
    Del Rio, TX, USA
    That is an "exclusive OR" (XOR) with a byte of 00001111. So when you input 00001001, it will return 00000110.
    Here is the truth table on page 79 of the manual.
    A    B   A ^ B
    0    0      0
    0    1      1
    1    0      1
    1    1      0
    If only A or only B is 1, then result is 1.
    The ^ operator is commonly used to invert selected bits:
