Some code to talk to the Vdrive2 device from Vinculum.
Thought this code may be of interest to someone:
1. DEBUG on G1/G2.
2. Vdrive2 on portB.
3. Vdrive2 CTS to ground, RTS not used.
' -----[ Program Description ]---------------------------------------
' Name: WVL Vdrive_03  File write test
' Program stores two 8-bit readings to USB thumb drive using a Vdrive2
' Vdrive jumper in UART MODE (UART/SPI pulled up datasheet V.99 is correct)
' Pin        Name    Description
' 1          GND     5V common
' 2          RTS     Request to Send
' 3          Vdd     Connects to +5V
' 4          RXD     Receive Data
' 5          TXD     Transmit Data
' 6          CTS     Clear to Send (connect to common or make low)
' 7          NC      No Connection
' 8          RI      Ring Indicator (not used)
' PIC18F8722 on BIGPIC5
' DEBUG used for PC comms and SERIN/SEROUT for VDrive2 comms all at 9600 Baud
' -----[ DEFINES ]---------------------------------------------------
clear
DEFINE OSC 40    ' Compile as HS
DEFINE LCD_DREG PORTD     ' Define PIC port used for LCD Data lines
DEFINE LCD_DBIT 4      ' Define first pin of data nibble
DEFINE LCD_RSREG PORTD     ' Define PIC port used for R/S line
DEFINE LCD_RSBIT 2      ' Define Portb pin used for R/S
DEFINE LCD_EREG PORTD    ' Define PIC prot used for E line
DEFINE LCD_EBIT 3      ' Define PortB pin used for E connection
DEFINE LCD_BITS 4      ' Define the 4 bit communication mode
DEFINE LCD_LINES 4      ' Define using a 2 line LCD
DEFINE LCD_COMMANDUS 1500 ' Define delay time between sending commands
DEFINE LCD_DATAUS 45     ' Define delay time between data sent
lcdout $fe,$1
pause 2000
FLAGS=0
INCLUDE "modedefs.bas"  ' Include serial modes
DEFINE DEBUG_REG  PORTG     ' Note: UART2
DEFINE DEBUG_BIT  1
DEFINE DEBUG_BAUD 9600  ' VDrive2 default speed
DEFINE DEBUG_MODE 0
DEFINE DEBUGIN_REG  PORTG
DEFINE DEBUGIN_BIT  2
DEFINE DEBUGIN_BAUD 9600
DEFINE DEBUGIN_MODE 0
define ADC_BITS 8
' -----[ VARIABLES ]-----------------------------------------------------------
X   VAR byte
Y           var byte
Z   var byte
A   var byte
B   var byte
C   var byte
D   var byte
E   var byte
F   var byte
G   var word
DataIn  var byte[50]
Echo  var byte
Rx          VAR PORTB.1  ' Data in from VDrive [Yellow]
Tx          VAR PORTB.0  ' Data out to VDrive [Orange]
Heartbeat var PORTD.0
Number  VAR BYTE[10]
' -----[ INITIALISE ]----------------------------------------------------------
ADCON1  = %00001111   ' All digital
TRISA = %00000011   ' A0 and A1 inputs
TRISB = %00000000
TRISC = %00000001   ' C0 is data in, C1 is data out
TRISD = %00000000
TRISE = %00000000
TRISF = %00000000
TRISG = %00000000
TRISH = %00000000
TRISJ = %00000000
' -----[ IDENTIFY ]------------------------------------------------------------
 lcdout $fe,$80, "WVL Vdrive_03"
 lcdout $fe,$c0, "PIC18F8722"
 pause 3000
 lcdout $fe,1
' *                         ESTABLISH COMMS WITH VDRIVE                       *
Begin:
 Debug "VDrive2 Starting",13
 Pause 200
 Debug "Attempting synchronisation:"
Syncro:
 Pause 200
 toggle Heartbeat
 X=X+1
 debug " ",dec3 X
 SerOut2 TX,84,["E",13]       ' Send sync command folowed by CR
    SerIn2 RX,84,200,Toolong,[Echo]  ' Wait 200mS for reply 'E'
 if Echo = "E" then Comms_Good
Toolong:
 GoTo Syncro
Comms_Good:
 Debug 13,"Disk synchronised",10,13     ' Show SUD has been sent
' *                             M A I N  C O D E                              *
 gosub Check_disk
 gosub Get_version
 gosub File_list
 gosub File_name_size      ' File size & name before FOR...NEXT loop
 gosub Free_space
 gosub File_delete
 gosub File_open        ' Create the file   "TestFile.csv" (XL type)
            ' When read becomes "TESTFILE.CSV"
 for X=1 to 17
  toggle Heartbeat
  debug "Writing to file X: ",dec3 X,13
  SerOut2 TX,84,["WRF ",0,0,0,4,13]  ' 32 bit number of bytes
  serout2 Tx,84,[dec3 x,10,13]   ' Number of bytes must be exact
 next X          ' Additional CR puts XL numbers into a column
 gosub File_close
 gosub File_size        ' File size after FOR...NEXT loop
            ' Read the file size and send first byte to LCD
 serout2 Tx,84,["IPA",13]     ' Switch to ASCII characters for display of HEX digits
 pause 100         ' Essential to wait after o/p switch
 serout2 Tx,84,["DIR TestFile.csv",13]  ' Issue the command
 serin2  Rx,84,[Wait ("TESTFILE.CSV $"),_
  hex2 A,skip 2,hex2 B,skip 2,hex2 C,skip 2,hex2 D]
 lcdout $fe,$80, "$: ",hex2 A," ",HEX2 B," ",HEX2 C," ",HEX2 D
 debug "All done",10,13
' *                         S U B R O U T I N E S                             *
Check_disk:
 for X=0 to 49 : DataIn[X]=0 : NEXT X  ' Clear the array
 serout2 tx,84,[13]       ' Issue the command. "D"= Disk Ok, "N"=no disk
 serin2  Rx,84,[str DataIn\1]    ' Read  1 character
 If DataIn[0] = "N" then
  debug "No disk detected "
  goto Check_disk
  debug "Disk found OK",10,13
 pause 100         ' These pauses are essential
Get_version:
 debug "Firmware version:"
 serout2 tx,84,["FWV",13]     ' Issue the command
 serin2  Rx,84,[str DataIn\50\">"]   ' Read characters until ">" is found
 debug str DataIn\50       ' Send data to the PC
File_list:
 debug 13,10,10,"List all files:"
 serout2 Tx,84,["DIR",13]     ' Issue the command
 serin2  Rx,84,[str DataIn\50\">"]   ' Read up to max of 50 chrs
 debug str DataIn\50
File_name_size:
 debug 13,10,10,"File name & size:"
 pause 10         ' Essential to wait after o/p switch
 serin2  Rx,84,2000,Jump2,[str DataIn\50\">"]' Read up to max of 50 chrs
Jump2:           ' Needed in case there is no file on the drive
 debug str DataIn\50
File_size:
 debug 13,10,10,"File size:",13
 serin2  Rx,84,2000,Jump3,[Wait ("TESTFILE.CSV "), str DataIn\50\">"]
Jump3:           ' Needed in case there is no file on the drive
 debug str DataIn\50,10,13
 serout2 Tx,84,["IPH",13]     ' Switch to HEX characters
Free_space
 debug 13,10,10,"Free space:",13
 serout2 Tx,84,["FS",13]      ' Return 4 bytes
 debug str DataIn\50
File_open:
 debug "Opening file",10,13
 serout2 Tx,84,["OPW TestFile.csv",13]  ' Issue the command
File_close:
 debug 10,"Closing file",10,13
 SerOut2 TX,84,["CLF TestFile.csv",13]  ' Issue the command
File_delete:
 debug 13,10,10,"Deleting file",10,13
 serout2 tx,84,["DLF TestFile.csv",13]  ' Issue the command
