Solution for 4 wire plug .. anyone ??
Results 1 to 12 of 12
    Sep 2006
    Default Solution for 4 wire plug .. anyone ??
    HI,
    I am making a few boxed circuit. I am thinking of using a telephone
    jack so I can communicate between two boxes ( I need 4 wires) Until
    now it was good, telephone jacks are popular so they are fairly cheap.
    The problem is that I do not have any square bits that fits on my
    drills
    I mean puncturing a square on the side of a plastic box is time
    consuming Vs round. Especially if you are about to do 50+.
    Anybody have a trick to make fast and almost perfect square. Or even
    a round connector would be better, but I could not find any under 2$,
    Its only for communication purposes,
    k
    Miami, Florida USA
    Default Re: Solution for 4 wire plug .. anyone ??
    Hmmm, that's a tough one . The only thing that I can think of is investing in a cheap CNC machine. Sorry if this is not what you wanted to hear.
    Anonymous
    Mar 2006
    China
    Make a stainless steel plate that has the square hole for the connector. Fix this plate to the plastic box. A few seconds with a Dremel hand tool and the material that once was a wall (side of the box) is now on the floor.
    Quick and easy to repeat.
    Sep 2006
    the whole idea is NOT to make that square hole
    K
    May 2006
    Del Rio, TX, USA
    How soft is the pastic? If it's soft plastic and you have a drill press, then a mortising attachment may work (even though it says "for wood use only").
    http://www.northerntool.com/shop/too...2050_200312050
    Dec 2010
    How about a computer PS2 connector? Those are cheap and plentiful...
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by lerameur View Post
    drills I mean puncturing a square on the side of a plastic box is time
    Since you are doing 50, one of these might help: http://www.ebay.com/sch/i.html?_nkw=...knockout+punch
    Not terribly cheap, but all you do is drill a round hole and you get a perfect square.
    Mar 2011
    Los Angeles, California
    Hi Lerameur!
    The solution ready depends upon how your box is configured. If the circuit board or electronics are mounted on a/the flat lid then you could use a "nibbler" to create a square "slot" in the edge of the box. There is also a 90 degree punch (#81652 or #82394) from Micromark (www.micromark.com). Best, Ed
    A 5 pin miniDIN connector would fit the bill pretty well. Only a $1.08 from mosuer. Here is a data sheet link:
    http://www.mouser.com/catalog/specsheets/KC-300168.pdf
    Tim Barr
    Sep 2006
    HI,
    the 5 pin mini din is still a square.. but I really like that square punch from Ramius, It seems to be similar to a mortiser bit but is good for plastic, thanks
    ken
    Feb 2003
    HI,
    ken
    Yes, the minidin sockets have a square body but you mount them just behind the panel and have a round hole for the plug to go through.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sep 2009
