Hello - Has anyone done anything with the LDP8806 RGB light strip? I have seen examples of people using the Arduino, but nothing in PBP. Would love to get something like this up and running for Christmas! Any thoughts? Jeff
the same problem with me i want to control lpd6801 but i don't know how can i start
Well surely if Arduino can do it so can PBP. the best place to start getting help will be to provide us with more info then just the name. I googled it, but admit to not looking past the first page for a datasheet. So if you can provide a link to the DS, maybe we will be able to help you sort this out.
-Bert
i am sure you found this info , but ill will post it anyways
https://github.com/adafruit/LPD8806
Actually I didn't find that cuz generally I skip over any result that doesn't look like an actual datasheet will be there. But upon following your link and reading several threads, I have come to realize there is no available datasheet for this chip - at least not in english. So it looks like there are 2 choices - port the duino code to PBP, or play guessing games with the part. Assuming it has 4 connections, I would assume that it is an I2C interface.
If this is the case (which you may be able to verify by pouring over the duino code to find the actual method called to talk to it), you can just set up some loops to start sending address/data to see if anything happens. My guess would be an address for each chip maybe then some data describing the color. So I would start by sending FFh to all 127 address's 1 at a time then see if the LED's light up. If none do, try different data going through the entire address selection again.
Not sure if this is helpful or not, I hope it is. Also I hope I don't come off sounding like a smart A$$ - I do not mean too if I do.
-Bert
lpd8803-8806-8809--lpd6803-lpd1101 all the same
Hello Everyone - Thanks for your posts. I am sorry that I droped out of this, but I am now in Mexico dealing with a family illness. In my spare time, I have scoured all the forums, blogs, posts that I could find and I finally came across some obscure post that broke the ice for me. I will explain what I found... For the LDP8806 LED strip, the thing that threw me off was that there was no "latch" pin. Just 4 wires: +5V, Gnd, Data and Clock. At first, I thought it was I2C, but that did not pan out. I then discovered that you have to send 3 bytes for each LED on the strip (using SHIFTOUT). 1 byte for each of R, G & B. If you want the particular LED to be turned on, the high bit (bit 7) should always be set to 1. The remaining 7 bits will determine the brightness of that LED (that's the nice thing about this chip is that it has built-in PWM). So, if you sent an LED a %10000000, you would activate that LED, but it would be set at 0 brightness (off). Send %11111111 would be on at full strength. OK, lets say you have a 1M strip. That will have 32 RGB LEDs on it and you want the output to be white. You would send:
GreenLED = %11111111
RedLED = %11111111
BlueLED = %11111111
for icnt = 1 to 32
shiftout dp1, cp1, 1, [GreenLED/8, RedLED/8, BlueLED/8]
Next
That loads all of the LEDs on the strip with the information. Now here's the jewel... To get it to latch (display), you send 3 %00000000's (SHIFTOUT DP1, CP1, 1, [%00000000, %00000000, %00000000]) one time and that gets sent down the line and you now have a bright white strip. That is pretty much it. Now you can use your imagination and get all kinds of cool effects - I have! Hope that helps! Have fun! Jeff
Good stuff Jeff, Thanks for clearing this up!!
-Bert
The library I used for my LPD8806 strip was here:https://github.com/adafruit/LPD8806
Can you use that with PICBasic Pro?
This looks like fun! Does anyone know the secret to addressing an individual segment on a longer string? If 8 bits are used to address the IC... 1 for the LED itself and 7 for PWM brightness control, where would you address the segment?
Thanks!
Brian
Brian - If you wanted to set LED #213 to red and all the rest to black (off), you would send a single command for a red led and then 212 commands for black and then send the latch comand. Is that what you are asking? Jeff
Yes, thanks very much! I just ordered 3 meters of the LED strip and looking forward to the light show!
Thanks again Jeff!
Brian
