Hserin Array Question
Results 1 to 2 of 2
    Sep 2007
    Default Hserin Array Question
    I just started to test out using Hserin.
    I first did a test using
    Hserin [dec Data]
    if Data > 1 then
    LED = 1
    LED = 0
    This was just to make sure everything was communicating and it was. Now on to the real data.
    The data string I want to send is at minimum 23 characters but can be longer (24 for a full 3 bytes) if necessary.
    The data package will look like this:
    “12345678_12_34_87654321”
    I’m using the command
    Hserin [str RxDATA\23]
    ‘RxDATA is defined as
    RxDATA var byte[3]
    Now my problem is how to breakdown the array into
    RxDATA1 = 12345678
    RxDATA2 = 12
    RXDATA3 = 34
    RxDATA4 = 87654321
    I’m guessing I have multiple issues going on here so any guidance is appreciated.
    Thank you,
    Hylan
    Sep 2007
    Default Re: Hserin Array Question
    Okay, so I think I was over thinking this a bit. I'm able to switch my RxDATA1 & 4 to binary so now I can just use:
    hserin [bin RxDATA1, skip 1, dec RxDATA2, dec RxDATA3, bin RxDATA4]
    This seems to work pretty well
