PicBasic Pro code to drive MCP4291 DAC?
Results 1 to 18 of 18
    Mar 2009
    Colorado
    Default PicBasic Pro code to drive MCP4291 DAC?
    Can anyone point me to posts/tutorials for PicBasic Pro code to drive MCP4291 DAC? I did an advanced search of the Forum using keywork DAC and came up empty. Will probably be using a PIC16F676 to control the MCP4291 DAC.
    Default Re: PicBasic Pro code to drive MCP4291 DAC?
    Hi jellis00
    Here's an example in basic (but the wrong basic) for the MCP4921. It's a little past half way through:
    http://www.mikroe.com/eng/chapters/v...r-13-examples/
    Apr 2011
    NSW, Australia
    This is what I have used to produce 3 sinewaves out of 3 MCP4921 DACs. Cant find an MCP4291
    include "modedefs.bas"
    ANSEL      = %00000000 'Disable analog inputs Channels 0 to 7
    ANSELH     = %00000000 'Disable analog inputs Channels 8 to 11
    WPUB       = %00000000 'Disable weak pull-ups
    ADCON0     = %00000000 'A/D Module is OFF
    CM1CON0    = %00000000 'Comparator1 Module is OFF
    CM2CON0    = %00000000 'Comparator2 Module is OFF
    INTCON     = %00000000 'INTerrupts CONtrol
    TRISA      = %00000000 'Set Input/Output (0 to 5)
    PORTA      = %00000000 'Ports High/Low (0 to 5)
    TRISB      = %00000000 'Set Input/Output (4 to 7)
    PORTB      = %00000000 'Ports High/Low (4 to 7)
    TRISC      = %01000000 'Set Input/Output (0 to 7)
    PORTC      = %01000000 'Ports High/Low (0 to 7)
    addr var word [90]
    addr[1]=2139
    addr[2]=2278
    addr[3]=2415
    addr[4]=2551
    addr[5]=2684
    addr[6]=2813
    addr[7]=2938
    addr[8]=3059
    addr[9]=3175
    addr[10]=3285
    addr[11]=3389
    addr[12]=3486
    addr[13]=3576
    addr[14]=3658
    addr[15]=3732
    addr[16]=3797
    addr[17]=3854
    addr[18]=3902
    addr[19]=3940
    addr[20]=3969
    addr[21]=3989
    addr[22]=3998
    addr[23]=3998
    addr[24]=3989
    addr[25]=3969
    addr[26]=3940
    addr[27]=3902
    addr[28]=3854
    addr[29]=3797
    addr[30]=3732
    addr[31]=3658
    addr[32]=3576
    addr[33]=3486
    addr[34]=3389
    addr[35]=3285
    addr[36]=3175
    addr[37]=3059
    addr[38]=2938
    addr[39]=2813
    addr[40]=2684
    addr[41]=2551
    addr[42]=2415
    addr[43]=2278
    addr[44]=2139
    addr[45]=2002
    addr[46]=1861
    addr[47]=1722
    addr[48]=1585
    addr[49]=1449
    addr[50]=1316
    addr[51]=1187
    addr[52]=1062
    addr[53]=941
    addr[54]=825
    addr[55]=715
    addr[56]=611
    addr[57]=514
    addr[58]=424
    addr[59]=342
    addr[60]=268
    addr[61]=203
    addr[62]=146
    addr[63]=98
    addr[64]=60
    addr[65]=31
    addr[66]=11
    addr[67]=2
    addr[68]=2
    addr[69]=11
    addr[70]=31
    addr[71]=60
    addr[72]=98
    addr[73]=146
    addr[74]=203
    addr[75]=268
    addr[76]=342
    addr[77]=424
    addr[78]=514
    addr[79]=611
    addr[80]=715
    addr[81]=825
    addr[82]=941
    addr[83]=1062
    addr[84]=1187
    addr[85]=1316
    addr[86]=1449
    addr[87]=1585
    addr[88]=1722
    addr[89]=1861
    addr[90]=1996
    ' Variables
    SCK     VAR PORTB.6 'Clock pin
    CS1     VAR PORTC.0 'Chip Select Active low
    CS2     VAR PORTC.1
    CS3     VAR PORTC.2
    SDO     VAR PORTC.7 'Data Out pin
    FREQ    VAR BYTE
    SWITCH  VAR PORTC.6
    counter    VAR word
     highbit var word
     lbit var highbit.byte0
     hbit var highbit.byte1
    START:
    IF SWITCH THEN
    FREQ = 35
    FREQ = 185
     for counter  = 1 to 90
      highbit = addr[counter] +20480
    low cs1
     SHIFTOUT SDO,SCK,msbfirst,[hbit]
     SHIFTOUT SDO,SCK,msbfirst,[lbit]
    high cs1
    PAUSEUS FREQ
    low cs2
    high cs2
    PAUSEUS FREQ
    low cs3
    high cs3
    PAUSEUS FREQ
     next counter
      counter=1
    GOTO START:
    regards
    aajgss
    Here's another example like aajgss's for the MCP4921. It generates a sine or cosine wave.
    Would like to try speeding it up, using the MSSI or MSSp modules. If anyone has an idea for this
    please post.
    '*  Name    : DAC_MCP4921_WAVE.PBP                              *
    '*  Author  : MARK S                                         *
    '*  Date    : 4/30/2011                                         *
    '*  Notes   : DEMO 12BIT DAC MCP4921 - OUTPUTS SINE OR COSINE WAVE  *
    '*          : FIXED FREQUENCY SHIFTOUT VERY SLOW, TRY MSSP MODULE                                                 *
    'PIC18F4680   PBP2.6, MPASM
    DEFINE  OSC 20
    'REGISTERS
        INTCON = %00000000
        INTCON2.7 = 0       'weak pullups portB
        'ADCON0 = %00000001 'A/D module enabled, channel 0
        ADCON1 =%00001111   'ALL DIGITAL
        'ADCON2 = %10101011 'Right justified, 12 Tad, Frc clock
        CMCON  =%00000111   'COMP OFF
        T3CON = 0
        CCP1CON = 0 'ECCP OFF
        ECCP1AS = 0
        ECCP1DEL = 0
    'PORTS
     TRISA = %00000000  ' PORTA ALL OUTPUT
     TRISB = %00000000  ' PORTB
     TRISC = %00000000  ' PortC TMR1 RC0 = INPUT
     TRISD = %00000000
        TRISE = %00000111
    'VARIABLES & DAC CONNECTIONS  VREF PIN6 4921 TIED TO +5V
        SCLK        VAR PORTD.0      'SPI CLOCK   PIN3 4921
        SDAT        VAR PORTD.1      'SPI DATA    PIN4 4921
        CS_DAC      VAR PORTD.2      'Chip select PIN2 4921
        LOAD_DAC    VAR PORTD.3      'PIN5 4921
        WAVE_INDEX  VAR WORD         'TABLE POINTER
        DAC_OUT     VAR WORD         '0-4095 OUTPUT 0 TO 5V, value returned from table
    MAIN:
    HIGH LOAD_DAC
    HIGH CS_DAC
    FOR WAVE_INDEX = 0 TO 255
    'GOSUB COS_TABLE
    GOSUB SINE_TABLE
    'PAUSEUS 500  'LOWER OUTPUT FREQ
    LOW CS_DAC
    SHIFTOUT SDAT,SCLK,1,[%0011,DAC_OUT\12] 'Set DAC out
    HIGH CS_DAC
    LOW LOAD_DAC
    @   NOP
    HIGH LOAD_DAC
    NEXT WAVE_INDEX
    GOTO MAIN
    SINE_TABLE:
    lookup2 WAVE_INDEX, [0,1,2,6,10,15,22,30,39,50,61,74,88,103,120,137,156,_
            176, 197,219,242,266,291,318,345,374,403,433,465,497,_
            531,565,600,636,673,710,749,788,828,869,910,952,995,_
            1039,1083,1127,1172,1218,1264,1311,1358,1406,1453,1502,1550,1599,_
            1648,1698,1747,1797,1847,1897,1948,1998,2048,2098,2148,2199,2249,_
            2299,2349,2398,2448,2497,2546,2594,2643,2690,2738,2785,2832,2878,_
            2924,2969,3013,3057,3101,3144,3186,3227,3268,3308,3347,3386,3423,_
            3460,3496,3531,3565,3599,3631,3663,3693,3722,3751,3778,3805,3830,_
            3854,3877,3899,3920,3940,3959,3976,3993,4008,4022,4035,4046,4057,_
            4066,4074,4081,4086,4090,4094,4095,4095,4095,4094,4090,4086,4081,_
            4074,4066,4057,4046,4035,4022,4008,3993,3976,3959,3940,3920,3899,_
            3877,3854,3830,3805,3778,3751,3722,3693,3663,3631,3599,3565,3531,_
            3496,3460,3423,3386,3347,3308,3268,3227,3186,3144,3101,3057,3013,_
            2969,2924,2878,2832,2785,2738,2690,2643,2594,2546,2497,2448,2398,_
            2349,2299,2249,2199,2148,2098,2048,1998,1948,1897,1847,1797,1747,_
            1698,1648,1599,1550,1502,1453,1406,1358,1311,1264,1218,1172,1127,_
            1083,1039,995,952,910,869,828,788,749,710,673,636,600,_
            565,531,497,465,433,403,374,345,318,291,266,242,219,_
            197,176,156,137,120,103,88,74,61,50,39,30,22,15,10,6,_
            2,1],DAC_OUT
     COS_TABLE:
     lookup2 WAVE_INDEX, [4095,4095,4094,4090,4086,4081,_
            2,1,0,1,2,6,10,15,22,30,39,50,61,74,88,103,120,137,156,_
            4066,4074,4081,4086,4090,4094,4095],DAC_OUT
    Apr 2011
    NSW, Australia
    Mark_s
    What speed are you looking for?
    Mine was running at about 9 Hz on an 18F14K50. By setting Config1 to $F100 I now get around 70hZ which is what I was after.
    aajgss
    aajgss,
    I was getting similar frequencies as you, at 20mhz and 40mhz clock settings. My lookup table has 256
    values, so it takes long time to cycle. I going to try the MSSP tonight and see what is gained. I know a dspic running at 80mhz can output about 4khz with the same dac and MSSP. So I am trying for 1 to 2khz. Maybe a pipe dream? I'll post the code if it works.
    regards
    Apr 2011
    NSW, Australia
    Mark_s
    I'll be interested in how you go. I did try the MSSP and actually got slower. I know it was the code I had written, because its just logical it should be faster and was going to continue with it to see if I could find my error(s), but the change to the CONFIG1 gave me the frequency I wanted. If I could get it faster and use 2 degree steps instead of 4 degree steps it would be better.
    regards
    aajgss
    Okay I hammered out a routine to use the MSSP module. It gave me
    a 6x speed increase over shiftout. I'm just a hack so there maybe a
    better way to do it.
    Results:
    Shiftout MSSP
    10mhz 10hz 66hz
    20mhz 21hz 117hz
    40mhz 42hz 2 63hz
    80mhz 83hz 526hz
    The 80mhz is 20mhz crystal 4xpll, overclocking probably not reliable? but worked!
    '*  Name    : DAC_12BIT_MSSP                                    *
    '*  Date    : 6/9/2011
    '* SINE WAVE GENERATOR USING MCP4921 12BIT DAC                  *
    '* USES MSSP MODULE vs SHIFTOUT                                 *
    '* PIC18F4680, PBP2.6 MPASM                                     *
    DEFINE  OSC 20
    'REGISTER SET
    INTCON = %00000000
    T3CON = 0
    ECCP1AS = 0
    ECCP1DEL = 0
    SSPSTAT = %00000000   'TX IDLE LOW,SAMPLE MIDDLE
    SSPCON1 = %00100000 ' ENABLE MSSP,CLK IDLE LOW,FOSC/4
    'PORTS
     TRISA = %00000000  ' PORTA ALL OUTPUT        '
     PORTB = %00000000  ' CLEAR PORTB
     TRISD = %00000000
        TRISE = %00000000
    'DAC CONNECTIONS
    'VREF     PIN6 MCP4921 TIED TO +5V
    'CLOCK    PIN3 MCP4921 TO PORTC.3  "SCK"
    'DATA     PIN4 MCP4921 TO PORTC.5  "SDO"
    'CS       PIN2 MCP4921 TO PORTD.2
    'LOAD     PIN5 MCP4921 TO PORTD.3   CONNECT THIS TO GROUND TO SAVE A PORT PIN
    'VARIABLES
    CS_DAC      VAR PORTD.2
    LOAD_DAC    VAR PORTD.3    'KEEP LOW
    WAVE_INDEX  VAR WORD
    DAC_OUT     VAR WORD
    DAC_OUT1    VAR WORD
    SSPIF       VAR PIR1.3     ' SPI interrupt flag
    'START
    SSPBUF = 0          ' CLEAR SPI BUFFER
    SSPIF = 0           ' CLEAR SPI INTERUPT FLAG.
    LOW LOAD_DAC
    MAIN:
    HIGH CS_DAC
    GOSUB SINE_TABLE
        LOW CS_DAC
          DAC_OUT1 =$3000 | DAC_OUT   ' Combine table value with dac reg control
                SSPBUF = DAC_OUT1.HIGHBYTE  'SEND HIGH
                While SSPIF = 0            ' WAIT FOR TX TO COMPLETE
                    Wend
                    SSPIF = 0               'RESET INT FLAG
                SSPBUF = DAC_OUT1.LOWBYTE   'SEND LOW
                    Wend
        HIGH CS_DAC
    NEXT WAVE_INDEX
    GOTO MAIN
    SINE_TABLE:
            2,1],DAC_OUT
    May 2007
    I don't know what the OP's application is but using a PIC and a serial DAC (MCP4921) to generate sine waves is extremely inefficient. It consumes a tremendous amount of CPU resources and gives very poor performance - limited frequency range and resolution. Using a DDS chip such as the AD8937 (which incidentally costs about the same as then MCP4921) allows you to generate sine (and triangle and square) waveforms from 0-16MHz with 0.06Hz (28-bit) resolution. For low frequency applications (such as VFDs) you can use a lower speed clock - with a 1MHz clock you get 0-1MHz and 0.004Hz resolution. It uses the same SPI interface as the MCP4921 and the slowest 4MHz PIC will still be able to generate up to a 16MHz sine wave.
    Aug 2008
    Portugal
    rmteo, isn't AD9837?
    Thanks and Regards;
    Gadelhas
    May 2007
    Yes, it is AD9837. Sorry for the typo.
    Aug 2008
    Portugal
    Very interesting chip....
    Thanks and Regards;
    Gadelhas
    rmteo,
    You are correct an spi dac is not suited for generating sine waves. My goal was to
    learn how to use this dac, which I did. I have used the AD9835 and AD9850 which are lower
    resolution versions of the AD9837, which you mentioned. The 28 bits of resolution is fantastic and
    I may request a sample since Digikey and Mouser don't stock the AD9837 yet.
    Mar 2009
    Colorado
    Quote Originally Posted by mark_s View Post
    please post.
    Thank you aajgss and mark_s. I should have been more specific in my original post, but I am not using the DAC to generate sinusoidal, triangular or square waveforms. All I am doing is outputing an analog voltage value that equates to a calculation performed by the MCU. So I don't think I need the complexity of a look-up table for generating an output analog waveform. Instead, I am just looking for example code to output an analog voltage by the DAC that will change in value relatively slowly every 20 to 100 msecs. Anyone have suggestion as to how to do this, or better yet example PICBASIC Pro code? Oh, and BTW, the DAC I am using is an MCP4921 not a MCP4291 (typo on my part).
    Apr 2011
    NSW, Australia
    Good stuff Mark_s
    I tried your code and got a slightly faster speed than before. The difference being I was doing 360 Degrees in 90 steps where yours is 360 degrees in 510 steps so you code has sped it up by neary 6 times.
    aajgss
    Apr 2013
    Has Anyone used AD9837 and got programmable pure sine wave above 10MHz?
    Would the PIC16F178X with 16 bit PWM be of any help with this application?
    Norm
    Jul 2015
    jellis00, i am trying to get the same code for the mcp4921 to output 0-5v. Did you ever find the sample code to do this?
