+ Reply to Thread
Results 1 to 9 of 9
Thread: Group - ungroup of commands
    Dec 2008
    Ploiesti, ROMANIA
    Default Group - ungroup of commands
    Hi !
    I need to do this : when I push a button (main program), I send through a pin this command (gosub command): Header, body,pause, body, pause .. where "body" repeat as long I push the button ( header it's something like "010001010", where 0 is us pause, 1 is "x" us of logic "1" ; the body resembles header).
    Next time when I push the button, the command must be the same : Header, body, pause, body, pause, so on, so on ...
    I cant find a way to send just for one time the header at each press of button ... I try to increment one variable (n=n+1) but wherever I put its reset, the results are not the expected ... the entire command are send (including header).
    Please, give me a clue ! Thanks in advance ! Regards !
    Bombay, India
    Default Re: Group - ungroup of commands
    Something like this?
         ' somewhere in main
        if ButtonIsPressed then gosub ButtonProcess
    ButtonProcess:
         gosub SendHeader                    ' send the 010001010 pattern with this subroutine
         while ButtonIsPressed               ' as long as the button remains pressed,
              gosub SendBody                 ' send the body pattern
              Pause xxx                          ' followed by the pause
         wend                                      ' loop @ while statement
         '  when button is released, you may want to send something too!!
         gosub SendTrailer                    ' similar to the header but sent at end of button press.  Makes it a bit exciting !!
    Dec 2008
    Ploiesti, ROMANIA
    Thank You !
    Unfortunately, my code it's a little ... special and this procedure dont work ...
    My code :
    ;reading buttons on line 2
        Portb.0 = 0
        TrisA.1 = 1
        pause 10
        status_3 = PortA & 011100
        Portb.0 = 1
        TrisA.1 = 0
        select case status_3
                    case 12
                    Gosub Starting  ; this is "header"
                    Gosub Sursa     ; ths is "body"
                    case 20
                    Gosub VolUp     ; this is "body", composed by Adresa + VolUp
                    case 24
                    Gosub Starting
                    Gosub VolDn
        end select
    Goto main
    STARTING:
    PORTB.4 = 0
    pauseus 8400
    PORTB.4 = 1
    pauseus 4200
    ADRESA:
        For i = 0 to 7
        lookup2 i, [a,a,a,a,b,b,b,a], j
        PORTB.4 = 0
        PauseUs 526
        PORTB.4 = 1
        PauseUs j
        next i
    VolUp:
    GOSUB ADRESA
        for i = 0 to 7
        lookup2 i, [b,b,a,b,b,b,b,a], j
        PORTB.4 = 0
        PauseUs 526
        PORTB.4 = 1
        PauseUs j
        next i
    Pause 12
    Why wouldn't Jersons procedure work with that code? You just need to think about how it works and APPLY it to your program...
    case 12
      While (PortA & %00011100) = 12
      Wend
    OR, if you want to be SURE to send 'body' atleast one time.
    case 12
      Gosub Sursa
      Wend
    Also, since you're always sending the header you could move that to outside of the Select Case structure. Send 'header' then select which 'body' to send. That'll save a couple of GOSUBS.
    Dec 2008
    Ploiesti, ROMANIA
    Still don't work...
    First try:
        Portb.0 = 0
        TrisA.1 = 1
        pause 10
        status_3 = PortA & %00011100
        Portb.0 = 1
        TrisA.1 = 0
                     case 20
                     gosub starting
                     While (PortA & %00011100) = 20
                     Gosub VolUp
                     wend
         end select
    Goto Main
    the "code" generated is ... totally inadequate (picture 1).
    Second try :
        Portb.0 = 0
        TrisA.1 = 1
        pause 10
        Portb.0 = 1
        TrisA.1 = 0
                     case 20
                     gosub Starting
                     Gosub VolUp
                     Gosub VolUp
                     wend
         end select
    Goto main
    the "code" generated is ...full, with "header" at any VolUp command ! (picture 2).
    What do I do wrong ?
    One possible cause is that when you read PortA inside the WHILE-WEND loop PortA.1 is not read properly since you make it an output before entering the loop. If you're going to read the pins they need to be inputs.
    Dec 2008
    Ploiesti, ROMANIA
    Wherever I put this code (While (PortA & %00011100) = 20 : Wend) the result are always the same : full command is sending.
    Recap :
    - if I push button for VolUp (case 20) I need to send this code : Starting (heading) , followed by VolUp command (body). If the VolUp it still pressed, while the button is pressed, only body must be sending ;
    - the next time I press VolUp, the whole process must be repeated : Starting, followed by body while buton is pressed ...
    Maybe instead of (While (PortA & %00011100) = 20 : Wend) I must use another command ... but I dont realise which one ...
    Dec 2008
    Ploiesti, ROMANIA
    Bingo ?!
        Portb.0 = 0
        TrisA.1 = 1
        pause 10
    ;    Portb.0 = 1
    ;    TrisA.1 = 0
                    case 20
                    gosub starting
                    while (PortA & %00011100) = 20
                    gosub volup
                    wend
        end select
        Portb.0 = 1 ; I've moved these here
        TrisA.1 = 0  ;   "  "
    Goto main
    I think You are right again, Mr. Henrik ! I will made hardware test and post the results ! Thanks ! Regards !
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
    Dec 2008
    Ploiesti, ROMANIA
    The code posted earlier ...
    Portb.0 = 0
    TrisA.1 = 1
    pause 10
          case 20
          gosub starting
                 while (PortA & 011100) = 20
                        gosub volup
                 wend
          end select
    Portb.0 = 1
    TrisA.1 = 0
    Goto main
    Work verry, verry fine !!!
    Thank You, Mr.Henrik !!!
+ Reply to Thread
