Help With DS1337 Squarewave Output
Results 1 to 2 of 2
    brighton
    Default Help With DS1337 Squarewave Output
    Hello All
    Just need a bit of help here .
    I am trying to use the DS1337 as an alarm with INTA (pin 3 of Ds1337) connected to RB0 Interupt pin of my Pic
    so that anytime the alarm time is reached it pulls RB0. This part is working ok.
    i want to use the other INTB (pin 7 ) to generate a 1 Hz tick .
    so using the datasheet on pages 10 & 11 i set my control register to 00000001
    as pg 10
    http://www.maxim-ic.com/datasheet/index.mvp/id/3128
    but i still don't get the 1hz tick on pin 7 here is my code below i must be doing something really stupid
    '* Name : ALARM1.BAS *
    '* Author : [SANTANA] *
    '* Notice : Copyright (c) 2004 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 30/10/2004 *
    '* Version : 1.0 *
    '* Notes :THE PROGRAM USES A TRIGGERS AN ALARM WHEN THE *
    '* :ALARM TIME SET BY THE USER MATCHS THAT OF THE RTC *
    '* :ON PIN 3 OF A DS1337 *
    '* :THE HRS:MINS & SECS MUST MATCH EXACTLY ON BOTH *
    '* :THE MAIN RTC TIME AND THE ALARM TIME
    DEFINE LOADER_USED 1 ' uses a bootloader
    Include "Modedefs.Bas"
    Define OSC 20
    clear
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    ' Setup Hardware for uart
    DEFINE HSER_BAUD 9600
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_CLROERR 1
    ' Clock Defines
    DS_SCL VAR PORTC.0 ' I2C clock pin
    DS_SDA VAR PORTC.1 ' I2C data pin
    RTC CON %11010000 ' RTC device address (byte addressing)
    ' -------------- RTC Address definitions -----------------
    SecReg CON $00 ' seconds address (00 - 59) ' MSB of SecReg must be set to a 0 to enable RTC
    MinReg CON $01 ' minutes address (00 - 59)
    HourReg CON $02 ' hours address (01 - 12) or (00 - 23)
    DayReg CON $03 ' day address (1 - 7)
    DateReg CON $04 ' date address (01 - 28/29, 30, 31)
    MonthReg CON $05 ' month address (01 - 12)
    YearReg CON $06 ' year address (00 - 99)
    'Alarm 1 Address definitions
    Alm1sec CON $07 ' Alarm 1 seconds address (00 - 59)
    Alm1min CON $08 ' Alarm 1 minutes address (00 - 59)
    Alm1hr CON $09 ' Alarm 1 hours address (01 - 12) or (00 - 23)
    Alm1Day CON $0A ' Alarm 1 day address (1 - 7)
    'Alarm 2 Address definitions
    Alm2min CON $0B ' Alarm 2 minutes address (00 - 59)
    Alm2hr CON $0C ' Alarm 2 hours address (01 - 12) or (00 - 23)
    Alm2Day CON $0D ' Alarm 2 day address (1 - 7)
    ContReg CON $0E ' control register
    StatusReg CON $0F ' STATUS register
    cntrl CON %00000001 ' sets the SQW/OUT to 1Hz pulse, logic level low
    'set interupt on INTA (From pg 9 of data sheet)
    sec VAR BYTE ' seconds
    MINs VAR BYTE ' minutes
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    date VAR BYTE ' date
    mon VAR BYTE ' month
    yr VAR BYTE ' year
    'ALARM1 VARIABLES
    A1sec VAR BYTE ' seconds
    A1MINs VAR BYTE ' minutes
    A1hr VAR BYTE ' hours
    A1day VAR BYTE ' day
    flag var byte
    ' Initialise Hardware
    'ADCON1=7
    TRISA =%00100000
    TRISB =%11100111
    TRISC =%10000001
    TRISD =%00000000
     VCC_EN      VAR PORTB.6
     LCD_EN      VAR PORTB.3
     HIGH VCC_EN
    Pause 1000
    hserout [" DS1337 TEST " ,10,13]
    flag=0
    GoSub SetTimeAndDate
    ' Main Program Loop
    Loopx:
    I2CRead DS_SDA, DS_SCL, RTC, SecReg, [sec,MINs,hr,day,date,mon,yr]
    I2CRead DS_SDA, DS_SCL, RTC, Alm1sec,[A1sec,A1MINs,A1hr,A1day]
    I2Cread DS_SDA, DS_SCL, RTC, StatusReg,[flag]
    hserout["Alarm Time : ",HEX2 A1hr, ":", HEX2 A1MINs, ":", HEX2 A1sec ,"      "]
    hserout["Present Time: ",HEX2 hr, ":", HEX2 MINs, ":", HEX2 sec ,10,13]
    if flag.0=1 then gosub Take_Reading
    GoTo Loopx
    ' Read Ds1337
    ' Display Section
    Take_Reading:
    hserout ["ALARM TRIGGERED",10,13 ]
    Pause 1000 ' Allow Time for user to view
    gosub SetTimeAndDate ' RESET TIMER
    I2CWrite DS_SDA, DS_SCL, RTC, StatusReg,[%00000000]' clear status reg<------
    PAUSE 10
    SetTimeAndDate:
    yr=0:date =0:mon =0:day=0:hr=0:mins=0:sec=0
    A1sec=0:A1MINs=0:A1hr=0: A1day=0
    ' The constants below set the RTC to: 16:30:50 on 13-08-2004
    yr=$04
    mon=$08
    date=$13
    day=$01
    hr=$16
    mins=$30
    sec=$50
    'SET ALARM FOR 16:31:05
    A1hr=$16
    A1MINs=$31
    A1sec=$05
    A1day=$13
    'Set the main Time
    I2CWrite DS_SDA, DS_SCL, RTC, SecReg,[sec,mins,hr,day,date,mon,yr]
    Pause 10
    'Set the Alarm 1 Time
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[$20]
    Pause 10
    PAUSE 10
    I2CWrite DS_SDA, DS_SCL, RTC,Alm1sec,[A1sec,A1MINs,A1hr,A1day]
    Pause 10
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[5]
    Pause 10
    Isaac
    brighton
    Default Re: Help With DS1337 Squarewave Output
    Found the problem
    told you i was stupid
    should be
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg,[%00000001]
