isd4002 problems help required please
Results 1 to 10 of 10
    Cambridge UK
    Default isd4002 problems help required please
    I have down loaded and modified the following code from MELABS samples so I can understand the coding.
    I have changed the code so that I have three push buttons record, finish and play. The binary switch on porta selects the address to start playing the message . The problem is I can only play from address zero, if some one would be kind enough to check the code and point me in the right direction it would be a great help. I have spent four weeks on this with out progression.
    Here is the code in full.
    ' Program to record and play multiple voice messages.
    ' Uses hardware SPI for 2-way communication to the voice device.
    ' Record messages in sequence by pressing the REC button.
    ' Then pressing the FINISH button to stop recording. The messages
    ' may be played back by selecting the address on the deciaml to binary
    ' switch and pressing the PLAY button.
    @ DEVICE PIC16F819, INTRC_OSC_NOCLKOUT
    ' System Clock Options (Internal)
    @ DEVICE PIC16F819, WDT_ON
    ' Watchdog Timer
    @ DEVICE PIC16F819, PWRT_ON
    ' Power-On Timer
    @ DEVICE PIC16F819, MCLR_OFF
    ' Master Clear Options (Internal)
    @ DEVICE PIC16F819, BOD_OFF
    ' Brown-Out Detect
    @ DEVICE PIC16F819, CPD_OFF
    ' Data Memory Code Protect
    @ DEVICE PIC16F819, PROTECT_OFF
    DEFINE OSC 8 ' Define for 8MHz crystal internal
    OSCCON = $70 'set the clock to 8 Mhz, 60 for 4MHz
    select_voice VAR PORTB.3 ' Chip select for voice recorder
    serial_mcu_out VAR PORTB.2 ' SPI data output
    serial_clk VAR PORTB.4 ' SPI clock pin
    voice_int VAR PORTB.5 ' Interrupt signal from voice device
    ADCON1 = 7 ' Set PORTA and PORTB to digital
    ' Define program variables
    control VAR BYTE
    address VAR WORD
    isd_data_in VAR WORD
    isd_data_out VAR WORD
    message_loc VAR WORD[16]
    i VAR BYTE
    i = 0
    message_loc[0]=0
    ' set up SPI port
    BF VAR SSPSTAT.0 ' Alias Buffer Full flag
    SSPSTAT = %01000000 ' Set SMP=0, CKE=1
    SSPCON = %00100010 ' Set CKP=0, SPI master, clock = Fosc/64, Enable the port
    TRISB = %11100011 ' Set data-direction to allow SPI on PortB
    High select_voice
    'portb.0 is Play
    'portb.1 is MCU IN (SDI)
    'portb.2 is MCU OUT (SDO)
    'portb.3 is Select voice
    'portb.4 is Serial clock (SCK)
    'portb.5 is Voice int (SS)
    'portb.6 is Record start
    'portb.7 is Record Finish
    TRISA = %00001111 'Bits 0-3 address select
    Pause 1000 ' allows power to settle
    loop:
    IF PORTB.6 = 0 Then
    address = message_loc[i] 'Sets address to begin recording
    GoSub record
    EndIF
    IF PORTB.7 = 0 Then
    GoSub finish
    i = (i+1) & $0F
    message_loc[i] = (isd_data_in >> 2) + 2 ' remove status bit
    EndIF
    IF PORTB.0 = 0 Then
    Pause 500 'allow key to release
    i = PORTA ' number selected plays corresponding message
    i = i+$0F
    address = message_loc[i] 'sets playback address
    GoSub ply
    EndIF
    wait_for_int:
    IF voice_int = 1 Then
    GoTo wait_for_int 'loop here till finished
    GoSub finish 'power down chip
    EndIF
    GoTo loop ' Do it forever
    ' ISD4003 Control Values:
    power_up CON %00100000 ' Power up the device
    set_play CON %11100000 ' Set the playback address
    play CON %11110000 ' Start playback
    set_rec CON %10100000 ' Set the record address
    rec CON %10110000 ' Start recording
    power_dwn CON %00010000 ' Stop playback or record and power down the device
    record: 'Record a message
    control = power_up ' Set control byte to power up
    GoSub spi_send ' Send to device
    Pause 100 ' Pause to let the device come up
    control = set_rec ' Set control byte to set record address
    Return ' Return to main loop
    ply:
    Pause 50 ' Pause to let the device come up
    control = set_play ' Set control byte to set play address
    finish:
    control = power_dwn ' Set control byte to power down
    spi_send: ' Use hardware SPI port to send and receive simultaneously
    Low select_voice ' Select voice chip
    address.highbyte = (address.highbyte & %00000111) | control ' Combine address and control data
    isd_data_out = address REV 16 ' Reverse the bits for LSB first
    SSPBUF = isd_data_out.highbyte ' Write the first byte to SSPBUF to initiate trasfer
    GoSub spi_wait ' Wait for transfer to finish
    isd_data_in.highbyte = SSPBUF ' Read the incoming data from SSPBUF
    SSPBUF = isd_data_out.lowbyte ' Write the second byte to SSPBUF to initiate transfer
    isd_data_in.lowbyte = SSPBUF ' Read the incoming data from SSPBUF
    isd_data_in = isd_data_in REV 16 ' Reverse the bits of incoming data (received LSB first)
    High select_voice ' Deselect voice chip
    spi_wait: ' Wait for transfer to finish
    IF BF = 0 Then spi_wait ' If the flag is still zero, keep waiting
    BF = 0 ' Reset the flag
    Thanks for your help and time
    Kind regards
    Nick
    Dec 2004
    USA
    Hi Nick,
    I used the SETPLAY command (%11100000) instead of PLAY (%11110000). It went something like this:
    CmdPlay VAR WORD
    CmdPwrUp CON %0010000
    SHIFTOUT MOSI, SCLK, 0, [CmdPwrUp\8]
    HIGH SS
    PAUSE 20
    LOW SS
    CmdPlay = %111000010001011 'SETPLAY + address
    SHIFTOUT MOSI, SCLK, 0, [CmdPlay\16]
    HIGH SS
    Klaus
    Cambridge UK
    Hi Klaus,
    Thanks for the code example, I have checked the code and I am using set_play (11100000). The problem I have is reading in the play address using 4 bits on porta and then looking it up in the array. I have included the full code in notepad if you want to look at it. I dont think my 1st post was very clear.
    I am going to keep your code sample and play with it once I get this working
    thanks again
    Nick
    Sep 2003
    INDIA
    Default Can you share the Code !
    Hi Nick,
    Can you share the code once done. I have a similar chip APR6016 to play with.
    Thanks for the start code.
    regards
    Mentor, Ohio
    Smile
    Hi Nick,
    I haven't used a PIC in this manner but I think the line:
    "TRISA = %00001111 'Bits 0-3 address select"
    is wrong. TRISA sets the data direction for PortA.
    Now if you had "TRISA = %00000000" then all of the lines of PortA are set as outputs. The next line should then be "PortA = %00001111".
    This would then turn PortA 0 - 3 on and 4 - 7 off.
    BobK
    Sorry, I didn't look at the date of the original post!
    Cambridge UK
    Hi BobK,
    PortA bits 0-3 are for a binary switch; they set the play address for the isd4002.
    charudatt,
    I have worked out all the problems myself, now it stores the address to eeprom and can be selected via the binary switch using a lookup table. Is this what you are after? Contact me via email in my personal info and I will send you the completed code.
    Nick
    Cambridge UK
    Hi BobK,
    charudatt,
    Nick
    Sep 2003
    INDIA
    Default Sent A Pm!
    Hi Nick,
    Sent You A Pm Some Days Back. Don't Know If You Got It.
    Charudatt
    Sep 2003
    INDIA
    Default Fyi - Apr6016 Design
    JUST IN CASE IF SOME ONE WAS INTERESTED, I HAVE A SIMILAR PROJECT USING APR6016 IC.
    THIS CONNECTS TO A DEVELOPMENT BOARD FOR CONTROL.
    APR6016 IS MANUFACTURED BY APLUS AND THE DATASHEET CAN BE FOUND AT http://www.aplusinc.com.tw/data/reco...et/apr6016.zip
    REGARDS
    sathyakiruba's Avatar
    sathyakiruba Guest
    Default Re: Fyi - Apr6016 Design
    dear sir,
    i need apr 6016 code for pic 16f877a
  1. Problems with U2 programmer C30 compiled code
    By minimii in forum Off Topic
    Last Post: - 5th November 2009, 09:43
  2. 2.60 + MCSP problems
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 27th September 2009, 15:42
  3. ISD4002 Address Question
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2009, 23:42
  4. Input problems
    By ALFRED in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2006, 21:02
  5. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 14:38
