how to use a variable for pulsout command
Results 1 to 3 of 3
    Feb 2012
    PERTH AUSTRALIA
    Default how to use a variable for pulsout command
    Hi guys , is there away to use a variable for the pulsout command , or a way around the same
    eg
    time var word
    one con 1000
    time = one
    pulsout GPIO.0,time
    regards
    sheldon
    Default Re: how to use a variable for pulsout command
    Hi, Sheldon
    That's exactly what you do here ...
    1) you first set a constant to 1000
    2) you set a variable equal to this constant
    3) you output signal of the variable length ...
    so, step 1) is not necessary ...
    writing
    Time VAR Word ; create your variable
    Time = 1000     ; set it to 1000
    PULSOUT pin, Time ; output your signal
    is the shortest way ... using a variable.
    Feb 2012
    PERTH AUSTRALIA
    cheers for that
