+ Reply to Thread
Results 1 to 3 of 3
Thread: how to use a variable for pulsout command
    Feb 2012
    PERTH AUSTRALIA
    Default how to use a variable for pulsout command
    Hi guys , is there away to use a variable for the pulsout command , or a way around the same
    eg
    time var word
    one con 1000
    time = one
    pulsout GPIO.0,time
    regards
    sheldon
    Le Treport 76 FRANCE
    Default Re: how to use a variable for pulsout command
    Hi, Sheldon
    That's exactly what you do here ...
    1) you first set a constant to 1000
    2) you set a variable equal to this constant
    3) you output signal of the variable length ...
    so, step 1) is not necessary ...
    writing
    Time VAR Word ; create your variable
    Time = 1000     ; set it to 1000
    PULSOUT pin, Time ; output your signal
    is the shortest way ... using a variable.
    Feb 2012
    PERTH AUSTRALIA
    cheers for that
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
+ Reply to Thread
