Help with Assembler Error
Results 1 to 4 of 4
    brighton
    Exclamation Help with Assembler Error
    Hello All
    Does anyone know what the following assembler Errors are ?
    i have being pulling my hair out since yesterday trying to complier my code but i get those errors
    i am using pbp2.60 and MCS
    Best Regards
    Isaac
    Default Re: Help with Assembler Error
    Are you declaring variables "ACCESS" and "N" in your program?
    If so, are you making them SYSTEM variables?
    If so, rename them or remove the SYSTEM modifier.
    Jan 2012
    Grid EN19MV
    I think that warning in the second line is saying that you are are using _CONFIG and that on 18F devices, you should be using CONFIG instead.
    Not having used 18F devices, I'm not sure, but that's what it seems to be saying to me.
    brighton
    I thought I get back to you ASAP as I have found out what the problem is
    Its all to do with me using the original old Microcode Studio plus (The Black CD)
    When I downloaded Microcode Studio Version 4 from Melab web site:-
    http://melabs.com/resources/win_ide.htm
    I don’t get the errors
    Isaac
