+ Reply to Thread
Results 1 to 2 of 2
    slash819's Avatar
    slash819 Guest
    Default PIC 12F683 and DS18B20 problem
    Hi everyone,
    I'm trying to obtain the temperature using four DS18B20s and transfer the result to my PC using serial port. My code is below, but I couldn't obtain the result I wanted, when I simulated using Proteus. I used SEROUT command instead of HSEROUT, because this PIC model doesn't have built in USART. Maybe I did a mistake using this command. I'd be glad, if you can help. (BTW i'm using MicroCode studio and MPASM).
    Code :
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 27.02.2012 *
    '* Version : 1.0 *
    '* Notes : *
    @ __CONFIG _WDT_OFF & _MCLRE_ON & _CP_OFF & _PWRTE_ON & _CPD_OFF & _BOD_OFF & _FCMEN_ON & _IESO_OFF & _INTRC_OSC_NOCLKOUT
    OSCCON = %01100001
    DEFINE XTAL = 4
    PortA=0
    Busy VAR BIT
    HAM VAR WORD
    HEAT VAR WORD
    FLOAT VAR WORD
    SIGN_BIT VAR HAM.Bit11
    NEG_HEAT CON 1
    DEGREE CON 223
    SIGN VAR BYTE
    TEMP VAR BYTE
    COMM_PIN VAR PORTA.0
    COMM_PIN1 VAR PORTA.1
    COMM_PIN2 VAR PORTA.2
    COMM_PIN3 VAR PORTA.3
    CLEAR
    START:
    GOSUB READSENSOR
    GOSUB READSENSOR1
    GOSUB READSENSOR2
    GOSUB READSENSOR3
    GOTO START
    READSENSOR:
    OWOUT Comm_Pin,1,[$CC,$44]
    WAT :
    OWIN COMM_PIN,4,[Busy]
    IF Busy=0 THEN WAT
    OWOUT COMM_PIN,1,[$CC,$BE]
    OWIN COMM_PIN,2,[HAM.Lowbyte,ham.highbyte]
    GOSUB CALC
    CALC:
    SIGN = "+"
    IF SIGN_BIT = NEG_HEAT THEN
    SIGN = "-"
    TEMP = ($FFFF - HAM + 1)*625
    HEAT = DIV32 10
    GOTO SUB
    TEMP = 625*HAM
    HEAT = DIV32 10
    SUB:
    FLOAT = (HEAT//1000)/100
    HEAT = (HEAT/1000)
    SEROUT PORTA.0,2,[HEAT,10]
    READSENSOR1:
    OWOUT Comm_Pin1,1,[$CC,$44]
    WAT1 :
    OWIN COMM_PIN1,4,[Busy]
    IF Busy=0 THEN WAT1
    OWOUT COMM_PIN1,1,[$CC,$BE]
    OWIN COMM_PIN1,2,[HAM.Lowbyte,ham.highbyte]
    GOSUB CALC1
    CALC1:
    SIGN = "+"
    SIGN = "-"
    HEAT = DIV32 10
    GOTO SUB1
    TEMP = 625*HAM
    HEAT = DIV32 10
    SUB1:
    HEAT = (HEAT/1000)
    SEROUT PORTA.1,2,[hEAT,10]
    READSENSOR2:
    OWOUT Comm_Pin2,1,[$CC,$44]
    WAT2 :
    OWIN COMM_PIN2,4,[Busy]
    IF Busy=0 THEN WAT2
    OWOUT COMM_PIN2,1,[$CC,$BE]
    OWIN COMM_PIN2,2,[HAM.Lowbyte,ham.highbyte]
    GOSUB CALC2
    CALC2:
    SIGN = "+"
    SIGN = "-"
    HEAT = DIV32 10
    GOTO SUB2
    TEMP = 625*HAM
    HEAT = DIV32 10
    SUB2:
    HEAT = (HEAT/1000)
    SEROUT PORTA.2,2,[HEAT,10]
    READSENSOR3:
    OWOUT Comm_Pin3,1,[$CC,$44]
    WAT3 :
    OWIN COMM_PIN3,4,[Busy]
    IF Busy=0 THEN WAT3
    OWOUT COMM_PIN3,1,[$CC,$BE]
    OWIN COMM_PIN3,2,[HAM.Lowbyte,ham.highbyte]
    GOSUB CALC3
    CALC3:
    SIGN = "+"
    SIGN = "-"
    HEAT = DIV32 10
    GOTO SUB3
    TEMP = 625*HAM
    HEAT = DIV32 10
    SUB3:
    HEAT = (HEAT/1000)
    SEROUT PORTA.3,2,[HEAT,10]
    Oct 2009
    Utah, USA
    Default Re: PIC 12F683 and DS18B20 problem
    This might help you... there is an article in the "wiki" section under "projects" "temperature" that shows how to read multiple ds18B20's...
    http://www.picbasic.co.uk/forum/cont...r-nine-of-them
    Dwight
