IN PBP we will write something like this...
TRISB=0 ' set PORTB as output
TRISA=%11111101 ' set PORTA as input except PORTA.1
a VAR BYTE
a=1
Loop:
Toggle PORTA.1
IF PORTA.0=0 then Gosub DoSomething ' testing PORTA.0 status
goto Loop
DoSomething:
PORTB=a ' send to PORTB
if a<255 then
a=a+1
a=1
IN PBC, IMO it will look something like.. please correct me someone if i'm wrong
POKE $86,0 ' set PORTB as output
POKE $85,253 ' set PORTA.1 as output other as input
b0=0
loop:
toggle 0
PEEK $05,b1 ' read PORTA status
b1=b1 & 1 ' keep only bit 0 of PORTA
' well i don't know if you can use something like
' if b1.0=0 then gosub DoSomething... worth to give a try
if b1=0 then gosub DoSomething
goto loop
DoSomething:
POKE $06,b0 ' send to PORTB
if b0<255 then
b0=b0+1
b0=1
this will toggle the PORTA.1 pin untill PORTA.0 go low, once it go to low, it will send the value of b0 var to PORTB.... well it's suppose to
