Converting 10bit ADC result to 8 bit
Results 1 to 10 of 10
    Feb 2004
    Michigan, USA
    Default Converting 10bit ADC result to 8 bit
    I need to write some ADC results in EEprom for calibrating a design. This wont be needed in the final product, its just to calibrate a resistor divider.
    I'm using a 10bit ADC result and need the result in 10 bits for elsewhere in the program. If I put the result into a duplicate VAR WORD and divide it by 4 , can I put that result in a new VAR BYTE and write the byte to EEprom?
    It *looks* like this works from what I'm reading back from EEprom but I just wanted a second opinion.
    Thanks!
    Default Re: Converting 10bit ADC result to 8 bit
    shift the value 2 places to the right.... 10bits shift >> 2, 8 bits....
    EN82fn
    Aug 2003
    If you simply shift out the least significant bits you lose any small variations between values
    that might not have occurred with a divide, but then when you multiply back to the original range
    you also drop resolution.
    You can calculate a new range like this:
    NewValue = (((OriginalValue - OriginalMin) * (NewMax - NewMin)) / (OriginalMax - OriginalMin)) + NewMin
    USA - Arizona
    Unless I am missing the obvious. Shifting right by two, or dividing by two (integer division) is identical. The only difference should be in speed. Shifts should always be faster, and divides may be slower depending on the compiler optimization.
    Lanquer, That is correct...
    EN82fn
    Aug 2003
    Ignore my whole post... don't know where my head was,
    you're going to drop the same resolution anyway!
    Feb 2004
    Michigan, USA
    Correct me if I'm wrong but if you divide a 10 bit result by 2, you get a 9 bit result. EG 1024/2 = 512. 8 bit max is 256 so you'd have to divide it by 4.
    USA - Arizona
    you're correct, this
    or dividing by two
    was my hands playing catchup with the brain
    May 2008
    Italy
    Why all this manipolation loosing valuable information contained in the 10 bits ADC, when you can store the whole 10 bits in the eeprom.
    Write 0,ADC.lowbyte
    Write 1,ADC.highbyte
    Will store
    Read 0, ADC.lowbyte
    Read 1,ADC.highbyte
    Will retrive your word.
    Cheers
    Al.
    Feb 2004
    Michigan, USA
    It'll also half the number of results that can be stored. Accuracy wasnt an issue, number of results was.
