Serial interrupt on PicBasic Pro
+ Reply to Thread
Results 1 to 3 of 3
    Feb 2011
    Default Serial interrupt on PicBasic Pro
    I need some help with this serial interrupt... It's working but not so well because when the interrupt happens I receive the serial data and treat the information. The problem is when the program return from the 1st interrupt to the Loop, I can't do another interrupt. I send serial data but the interrupt not happens.
    So, please, can anyone help me?
    Thanks...
    Here's my code..
    define LOADER_USED 1 INCLUDE "modedefs.bas"
    RX VAR PORTC.7 'SERIAL'S RECEIVE BIT.
    TX VAR PORTC.6 'SERIAL'S TRASMITTER BIT.
    CMD VAR PORTD.2
    CONT VAR BYTE
    CMD = 0
    CONT = 0
    TRISC = 000000
    TRISD = 000100
    TRISE = 0
    INTCON = 000000 ; GENERAL AND PERIPHERALS INTERRUPT
    PIE1.5 = 1 ; " " " DE RECEPÇÃO DA USART
    RCSTA.1 = 0 ; MANY BYTES RECEIVED WITHOUT READ
    RCSTA.2 = 0 ; Stop Bit
    RCSTA.4 = 1 ; CONTINOUS REVEICE
    RCSTA.6 = 0 ; 8 BITS' RECEIVE
    RCSTA.7 = 1 ; USART ACTIVATION
    RCIF var PIR1.5 ; RECEIVE INTERRUPT
    STATUSLED var PORTD.0 ; LED'S NOTIFICATION OF "PROCESS RUNNING"
    USERLED var PORTD.1 ; LED CONTROLLED BY USER
    DELAY var word
    DISCARD var byte ; Clean the RCREG
    FRAME VAR BYTE[10]
    FRAME = 0
    PORTD = 0
    PORTC = 0
    PORTE = 0
    ON INTERRUPT GOTO USART_INTERRUPT
    LOOP:
    toggle statusled
    for delay = 1 to 5000 ; use a loop delay to ensure
    pauseUS 5 ; getting interrupt as fast as
    next ; possible
    goto LOOP
    DISABLE
    USART_INTERRUPT:
    WHILE RCIF = 1
    RCREG = DISCARD
    WEND
    SERIN2 RX,84,[WAIT("E"),STR FRAME\10]
    IF FRAME[0] = "E" THEN
    IF FRAME[1] = "B" THEN
    IF FRAME[2] = "9" THEN
    IF FRAME[3] = "0" THEN
    SELECT CASE FRAME[4]
    CASE "S"
    IF FRAME[7] = "0" THEN
    IF FRAME[5] = "E" THEN
    IF FRAME[8] = "0" THEN
    IF FRAME[6] = "P" THEN
    WHILE FRAME[9] = "0" AND CMD = 0 AND CONT < 36
    PORTC.0 = 1
    PAUSE 2500
    CONT = CONT + 1
    WEND
    CASE "L"
    IF FRAME[5] = "V" THEN
    IF FRAME[6] = "A" THEN
    IF FRAME[9] = "0" THEN
    while FRAME[7] = "L" AND CMD = 0 AND CONT < 36
    PORTC.1 = 1
    PORTC.3 = 1
    PAUSE 2500
    CONT = CONT + 1
    WEND
    CASE "D"
    WHILE FRAME[7] = "L" AND CMD = 0 AND CONT < 36
    PORTC.2 = 1
    PORTC.3 = 1
    PAUSE 2500
    CONT = CONT + 1
    WEND
    END SELECT
    REVERSE CMD
    CMD = 0
    REVERSE CMD
    FRAME = 0
    PORTC.0 = 0
    PORTC.1 = 0
    PORTC.2 = 0
    PORTC.3 = 0
    CONT = 0
    WHILE RCIF = 1
    RCREG = DISCARD
    WEND
    RESUME
    ENABLE
    Default Re: Serial interrupt on PicBasic Pro
    A good rule with interrupts is to get in and out as fast as possible.
    Try not doing all of the processing inside the interrupt routine and see if that helps.
    Feb 2011
    Thanks mackrackit! I modified the program and just put a flag that i created inside of the interrupt routine. So the interrupt set that flag = 1 and go back to Loop and then if this flag = 1, the program goto to another routine and do all the processing. But don't solve the problem.
    I did a test that I remove the SERIN2 and leave all the IF's, CASE and WHILE inside the interrupt routine, then the problem was solved, I can interrupt normally. But i need to receive the data with 10 bytes when interrupt happens.
    So, I'm stuck on that problem. =/
