Need some examples using Lookup( I'm playing with led matrix sample code)
Results 1 to 6 of 6
    Jun 2011
    Philippines
    Default Need some examples using Lookup( I'm playing with led matrix sample code)
    Hi everyone, I know this is a beginner question but I need help how on how to understand this code(not mine) below and perhaps later on modify it for my application.
    Lookup yazi_reg,[30,"HELLO WORLD LED MATRIX DISPLAY "],harf_reg
    "LOOKUP statement can be used to retrieve values from a table of 8-bit constants." I got this from the manual but unfortunately I don't really get it yet.
    Hope anyone can tell me how the above line should work..and can I make an array variable to place "HELLO WORLD LED MATRIX DISPLAY "? Assuming string of characters was entered from PC - mcu.
    The whole code:
    porta=0  :  portb=0  :  portc=0  :  portd=0
    trisa=0  :  trisb=0  :  trisc=0  :  trisd=0
    porte=0  : trise=0
    harf_reg var byte
    adres_sec var byte
    yinele var byte
    sutun_reg var byte[300]
    veri var byte
    yazi_reg var byte
    i VAR BYTE
    x var byte
    z var byte
    y var byte
    t var byte
    q var byte
    sure var byte
    yedek var byte
    'Define OSC 48
    CLEAR  :  portd=255:sure=200 :GOTO oku:
    oku:
    call yazi  : yazi_reg=yazi_reg+1  :  z=harf_reg
        for i=1 to z
            call yazi  : yazi_reg=yazi_reg+1  : call data_sec
            for y=0 to yinele
                call datalar
                sutun_reg[t]=veri  :  t=t+1
                adres_sec=adres_sec+1
            next y
        next i
    t=0
    goto gonder
    gonder:
    FOR Q=0 TO 5
        for i=0 to 15 ' 15
            portb=sutun_reg[t]  :  t=t+1
            porta=i
            portc=111110:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=111101:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=111011:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=110111:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=101111:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=011111:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=111111:pauseus sure:portc=111111
        next i
         for i=0 to 15
            porta=i
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
            sutun_reg[i]=sutun_reg[i+1]
        next i
            sutun_reg[240]=yedek
    goto gonder
    yazi:
    lookup yazi_reg,[30,"HELLO WORLD LED MATRIX DISPLAY "],harf_reg
    data_sec:
    select case harf_reg
    case "A"
    adres_sec=0  :  yinele=5  :  return
    case "B"
    adres_sec=6  :  yinele=5  :  return
    case "C"
    adres_sec=12  :  yinele=5  :  return
    case "D"
    adres_sec=18  :  yinele=5  :  return
    case "E"
    adres_sec=24  :  yinele=5  :  return
    case "F"
    adres_sec=30  :  yinele=5  :  return
    case "G"
    adres_sec=36  :  yinele=5  :  return
    case "H"
    adres_sec=42  :  yinele=5  :  return
    case "I"
    adres_sec=48  :  yinele=3  :  return
    case "i"
    adres_sec=52  :  yinele=3  :  return
    case "J"
    adres_sec=56  :  yinele=5  :  return
    case "K"
    adres_sec=62  :  yinele=5  :  return
    case "L"
    adres_sec=68  :  yinele=5  :  return
    case "M"
    adres_sec=74  :  yinele=5  :  return
    case "N"
    adres_sec=80  :  yinele=5  :  return
    case "O"
    adres_sec=86  :  yinele=5  :  return
    case "P"
    adres_sec=92  :  yinele=5  :  return
    case "Q"
    adres_sec=98  :  yinele=5  :  return
    case "R"
    adres_sec=104  :  yinele=5  :  return
    case "S"
    adres_sec=110  :  yinele=5  :  return
    case "T"
    adres_sec=116  :  yinele=5  :  return
    case "U"
    adres_sec=122  :  yinele=5  :  return
    case "ü"
    adres_sec=128  :  yinele=5  :  return
    case "V"
    adres_sec=134  :  yinele=5  :  return
    case "W"
    adres_sec=140  :  yinele=5  :  return
    case "X"
    adres_sec=146  :  yinele=5  :  return
    case "Y"
    adres_sec=152  :  yinele=5  :  return
    case "Z"
    adres_sec=158  :  yinele=5  :  return
    case " "
    adres_sec=164  :  yinele=5  :  return
    case "0"
    adres_sec=170  :  yinele=5  :  return
    case "1"
    adres_sec=176  :  yinele=3  :  return
    case "2"
    adres_sec=180  :  yinele=5  :  return
    case "3"
    adres_sec=186  :  yinele=5  :  return
    case "4"
    adres_sec=192  :  yinele=5  :  return
    case "5"
    adres_sec=198  :  yinele=5  :  return
    case "6"
    adres_sec=204  :  yinele=5  :  return
    case "7"
    adres_sec=210  :  yinele=5  :  return
    case "8"
    adres_sec=216  :  yinele=5  :  return
    case "9"
    adres_sec=222  :  yinele=5  :  return
    end select
    datalar:
     lookup adres_sec,[$7C,$0A,$09,$0A,$7C,0_      ;A
                       ,$7F,$49,$49,$49,$36,0_      ;B
                       ,$3E,$41,$41,$41,$22,0_      ;C
                       ,$7F,$41,$41,$41,$3E,0_      ;D
                       ,$7F,$49,$49,$49,$41,0_      ;E
                       ,$7F,$09,$09,$09,$01,0_      ;F
                       ,$3E,$41,$49,$49,$3A,0_      ;G
                       ,$7F,$08,$08,$08,$7F,0_      ;H
                       ,$41,$7F,$41,0_              ;I
                       ,$44,$7D,$44,0_              ;Ý
                       ,$20,$40,$41,$3F,$01,0_      ;J
                       ,$7F,$08,$14,$22,$41,0_      ;K
                       ,$7F,$40,$40,$40,$40,0_      ;L
                       ,$7F,$02,$04,$02,$7F,0_      ;M
                       ,$7F,$04,$08,$10,$7F,0_      ;N
                       ,$3E,$41,$41,$41,$3E,0_      ;O
                       ,$7F,$09,$09,$09,$06,0_      ;P
                       ,$3E,$41,$51,$61,$3E,0_      ;Q
                       ,$7F,$09,$19,$29,$46,0_      ;R
                       ,$26,$49,$49,$49,$32,0_      ;S
                       ,$01,$01,$7F,$01,$01,0_      ;T
                       ,$3F,$40,$40,$40,$3F,0_      ;U
                       ,$1E,$41,$01,$41,$1E,0_      ;Ü
                       ,$1F,$20,$40,$20,$1F,0_      ;V
                       ,$3F,$40,$30,$40,$3F,0_      ;W
                       ,$63,$14,$08,$14,$63,0_      ;X
                       ,$07,$08,$70,$08,$07,0_      ;Y
                       ,$61,$51,$49,$45,$43,0_      ;Z
                       ,$00,$00,$00,$00,$00,0_      ;Space
                       ,$3E,$51,$49,$45,$3E,0_      ;0
                       ,$42,$7F,$40,0_              ;1
                       ,$62,$51,$49,$45,$42,0_      ;2
                       ,$22,$49,$49,$49,$36,0_      ;3
                       ,$18,$14,$12,$7F,$10,0_      ;4
                       ,$2F,$49,$49,$49,$31,0_      ;5
                       ,$3E,$49,$49,$49,$32,0_      ;6
                       ,$61,$11,$09,$05,$03,0_      ;7
                       ,$36,$49,$49,$49,$36,0_      ;8
                       ,$26,$49,$49,$49,$3E,0],veri ;9
    Thanks in advance,
    tacbanon
    Default Re: Need some examples using Lookup( I'm playing with led matrix sample code)
    In your example, if yazi_reg is 0 harf_reg will be set to 30 when executing the LOOKUP statement. If yazi_reg is 1 harf_reg will be set to 72 (which is the ASCII code for 'H') and so on.
    In other words, harf_reg will be set to the value within the brackets "pointed at" by yazi_reg
    LOOKUP works with constants stored an compile time. You can not execute LOOKUP on an array of bytes, and there's really no need to. You can just do something like myByte = myArray[n] where n is the location in the array you want to "get".
    Jun 2011
    Philippines
    Good Day Henrik, Thanks for helping me out. I searched a little on SERIN2 to capture string of characters from PC to MCU.
    My study code:
    DEFINE    OSC 4
    str1 var byte[10]
    pause 200
           Serin2 PortC.7,84,[ str str1\30]    ' From PC
           Serout2 PORTC.6, 84,[str str1\30,13] ' Check if everything is okay
    Correct if I'm wrong, you mean to say I would not need to use LOOKUP if I use my variable (str1)? I'm sorry if I'm still confuse.
    tacbanon
    That's correct. You can not use LOOKUP with arrays since LOOKUP accesses static data stored in flash and not in RAM where your array is.
    i VAR Byte
    myByte VAR Byte
    For i = 0 to 15
      Lookup i, ["This is 16 bytes"], myByte   ' When you do this the string is stored in flash.
      Serout myByte
    NEXT
    In the above code the string This is 16 bytes is static, stored in program memory and can not be changed at runtime. If accessing arrays (ie data in RAM) you can get the same result by doing something like:
    i Var Byte
    myArray VAR BYTE[16]
    ArrayWrite myArray, ["This is 16 bytes"]   ' When you do this the string is stored in RAM
    For i = 0 to 15
       Serout myArray[i]
    NEXT
    Jun 2011
    Philippines
    Now it's clearer for me.
    Back in the led matrix code...
    Will this code be valid?
    i VAR Byte
    ArrayWrite str1,["HELLO WORLD LED MATRIX DISPLAY "]
    For i = 0 To 29
        harf_reg = str1[i]
        GoSub data_sec
    Next
    I assumed harf_reg will now hold the index value of each character and locate the corresponding ascii character...
    Thanks again,
    tacbanon
    Jun 2011
    Philippines
    I was able to run the original code in proteus...
    porte=0  : trise=0
    harf_reg var byte
    adres_sec var byte
    yinele var byte
    veri var byte
    yazi_reg var byte
    i VAR BYTE
    x var byte
    z var byte
    y var byte
    t var byte
    q var byte
    sure var byte
    yedek var byte
    Define OSC 4
    oku:
        for i=1 to z
            for y=0 to yinele
                call datalar
            next y
        next i
    t=0
    goto gonder
    gonder:
    FOR Q=0 TO 5
        for i=0 to 15 ' 15
            porta=i
        next i
        for i=0 to 15
            porta=i
        next i
        for i=0 to 15
            porta=i
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
        next i
    goto gonder
    yazi:
    ' For i = 0 To 29
    '    harf_reg = str1[i]
    '    GoSub data_sec
    ' Next
    data_sec:
    case "A"
    case "B"
    case "C"
    case "D"
    case "E"
    case "F"
    case "G"
    case "H"
    case "I"
    case "i"
    case "J"
    case "K"
    case "L"
    case "M"
    case "N"
    case "O"
    case "P"
    case "Q"
    case "R"
    case "S"
    case "T"
    case "U"
    case "ü"
    case "V"
    case "W"
    case "X"
    case "Y"
    case "Z"
    case " "
    case "0"
    case "1"
    case "2"
    case "3"
    case "4"
    case "5"
    case "6"
    case "7"
    case "8"
    case "9"
    end select
    datalar:
                       ,$41,$7F,$41,0_              ;I
                       ,$44,$7D,$44,0_              ;Ý
                       ,$42,$7F,$40,0_              ;1
    And did a modification on the code, to receive strings from PC but did not work, probable I do not understood the following code.
    oku:
        for i=1 to z
            for y=0 to yinele
                call datalar
            next y
        next i
    t=0
    goto gonder
    gonder:
    FOR Q=0 TO 5
        for i=0 to 15 ' 15
            porta=i
        next i
        for i=0 to 15
            porta=i
        next i
        for i=0 to 15
            porta=i
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
        next i
    goto gonder
    I hope someone can extend their help on this....
    tacbanon
