Multiple I2c Devices
Results 1 to 6 of 6
    Jan 2012
    Default Multiple I2c Devices
    I need four I2c ports to be used to communicate with four slave I2c devices (having same fixed address tcs3414) using 16F689. For one device it is OK with Busin and Busout. But i am unable to find a way to use multiple devices on same chip. Is there any solution exist using Picbasic Pro.
    Nov 2008
    Default Re: Multiple I2c Devices
    Hi
    This can easly be done in PBP using the I2CREAD and I2CWRITE commands.
    The I2C routines in PBP are software based and can be assigned to almost any pin on the PIC, in your case you could use RC0 - RC7 as 4 seperate I2C interfaces.
    The manual expalins alot of the function for this http://pbp3.com/downloads/PBP_Reference_Manual.pdf section 5.33 & 5.34, but I'd be more than happy to answer any specific questions you may have.
    Jan 2012
    Thanks for your reply, i have tried following simple code but getting error for I2Cwrite (I2cRead is OK), please check whats wrong with this code. is there something missing......?
    Device 16F689
    Config FCMEN_ON, IESO_OFF, CPD_OFF, CP_OFF, MCLRE_ON, PWRTE_ON, WDT_OFF, INTRC_OSC_NOCLKOUT,BOR_OFF
    TRISC=%00000000
    Declare All_Digital = True
    Xtal=8
    Symbol Dpin PORTC.4
    Symbol Cpin PORTC.6
    DelayMS 100
    I2CWRITE Dpin,Cpin,$72,$80,[$3]
    I2CREAD Dpin,Cpin,$72,$80,[$3]
    This doesn't look like PBP code to me?
    EN82fn
    Nov 2008
    Agreed, not picbasic, what version of picbasic are you running?
    Jan 2012
    Sorry i made a mistake, actually it is proton code and i mixed proton with pic basic. I will try writing in picbasic and will let you know if there is any issue.
