HSEROUT problem
Results 1 to 4 of 4
Thread: HSEROUT problem
    Jan 2012
    Default HSEROUT problem
    Hi:
    I'm need send some characters in RS485. When I received a string from the master, then send the characters.
    If I received next string:
    02 10 02 cf 00 02 04 00 00 00 00 a9 9b
    (code "hserin 15,PasoSerie,[b0,b1,b2,b3]"
    "hserin 15,PasoSerie,[b4,b5,b6,b7,b8,b9,b10,b11,b12]")
    then I send to the master:
    02 10 02 cf 00 02 70 7c
    (code "hserout [bs0,bs1,bs2,bs3,bs4,bs5,bs6,bs7,10]")
    All is OK.
    But if I received from the master:
    02 03 02 e3 00 01 74 77
    (code "hserin 15,PasoSerie,[b0,b1,b2,b3]")
    02 83 01 70 f0.
    (code "hserout [bs0,bs1,bs2,bs3,bs4,10]")
    The problem: the master dont received this string. The master received another string:
    0f 12 83 01 70 f0 0a
    I'm working with 18F6720 and I dont know how repair this.
    Any suggestion???
    Nov 2008
    Default Re: HSEROUT problem
    Hard to say, could you post the entire tx/rx routine and details of hardware.
    I presume your using a max485 or similer as the RS485 hardware interface to the PIC, the first thing that if this is half duplex are you seting the DE line (pin3 on the max485) high during tx ?
    Another note on this is to ensure this remains high for a period of two bytes after the HSEROUT has completed otherwise data still being transmitted bu the UART would be corupted.
    something like:
    HSERIN xx,xxxxx,[xxxxxx] 'recieve data
    DE = 1 'enable 485 tx
    HSEROUT [xxxxxxxx] 'send data
    PAUSE xxx 'wait two bytes
    DE = 0 'disable 485 tx, enable 485 rx
    Jan 2012
    the code used is
    RXTX=1
    pause 2
    CREN=0
    pause 2
    cren=1
    RXTX=0
    pause 2
    RXTX is DE in MAX485 and CREN is RCSTA1.4.
    I think the problem is in the input, i dont know the lenght of the string the master send me. When he send the string
    I read
    then I send
    bs0=b0
    bs1=b1+$80
    bs2=$01
    bs3=CRC.lowbyte
    bs4=CRC.highbyte
    RXTX=1
    pause 2
    CREN=0
    pause 2
    cren=1
    RXTX=0
    pause 2
    The master received next string:
    what's happening??
    Nov 2008
    Is there any way you can add in a DEBUG after the "hserin 15,PasoSerie,[b0,b1,b2,b3]"?
    Just to output the raw recieved bytes to monitor in a terminal.
    The other thing that you could do is to clear the RX FIFO before enabling the reciever with "cren = 1". Something like
    temp = RCREG ' clear first byte
    temp = RCREG ' clear second byte
    cren = 1
