Two line LCD double height numbers, possible ???
Results 1 to 26 of 26
    Dec 2011
    IO93ok
    Default Two line LCD double height numbers, possible ???
    I have Melanies excellent Olympic Timer from 2004 working as a seconds stopwatch, as I need seconds not minutes for Showjumping timing. i.e 128.34 secs (Thanks Melanie)
    However I used a two line 40 character LCD and the numbers are very small.
    I seem to recall in the past I saw a two line LCD showing numbers spread over two lines (two line high) using the custom character feature.
    Anyone have any info on this ??
    Dec 2011
    IO93ok
    Default Re: Two line LCD double height numbers, possible ???
    Hmm, a search came up with this on the Arduino forum.
    http://www.arduino.cc/cgi-bin/yabb2/...num=1245352653
    Shows what can be done using just a few segments. I really need to study this one though to use the LCD.
    Does the datasheet for your LCD mention custom characters?
    As far as I remember, you need a graphic LCD to do that. A character LCD only prints characters, unless it has a custom character feature.
    Apr 2007
    Pennsylvania, USA
    Most character LCD's allow up to 8 custom characters. I have a 2x8 display on my kids aquariums showing water temp and you have to be very close to read it, this would be a neat way to make the characters larger.
    Shawn
    Miami, Florida USA
    I thought about implementing this idea some time ago, but them I got discouraged when I read somewhere that these LCD displays only allow a few custom characters like spcw1234 mentioned above. However, looking at the arduino link above it looks like it can be done.
    Anonymous
    Darrel did it a long time back, I re posted his code here:http://www.picbasic.co.uk/forum/show...hlight=bignums
    search for bignums to see other threads.
    BTW Darrel gives credit to Scott Edwards . . .
    http://www.picbasic.co.uk/forum/showthread.php?p=26736
    http://www.picbasic.co.uk/forum/showthread.php?t=9736
    Apr 2007
    Pennsylvania, USA
    This is what I came up with using DT_INTS-18 timer routine. This is with a 2x16 display.
    '*  Name    : BigDigitTimer.BAS                                 *
    '*  Author  : Shawn Newswanger                                  *
    '*  Notice  : Copyright (c) 2012                                *
    '*  Date    : 1/8/2012                                          *
    '*  Notes   : PIC18F2221 with internal OSC                      *
    OSCCON=110000            'SET TO 8 MHZ
    define OSC 08               '8MHz oscilator
    define LCD_COMMANDUS 1500   'set command delay in us
    define LCD_DATAUS 50        'set data delay in us
    define LCD_DREG PORTC       'set LCD data port
    define LCD_DBIT 4           'set LCD starting data bit
    define LCD_RSREG PORTC      'define RS port
    define LCD_RSBIT 2          'define RS bit
    define LCD_EREG PORTC       'set LCD ENABLE port
    define LCD_EBIT 3           'set LCD ENABLE bit
    define LCD_BITS 4           'set LCD bits 4 or 8
    define LCD_LINES 2          'set # of LCD rows 2 or 4
    clear
    ADCON1 = 15 'all digital
    CMCON = 7   'turns off comparators
    trisc=0
    trisb=0
    trisa=0
    nPos  var byte
    nDig  var byte
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,1
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
      LCDOUT  $FE,$40,$1F,$1F,$1F,$00,$00,$1F,$1F,$1F  ' Cust Char #0
      LCDOUT  $FE,$48,$1F,$1F,$1F,$00,$00,$00,$00,$00  ' Cust Char #1
      LCDOUT  $FE,$50,$00,$00,$00,$00,$00,$1F,$1F,$1F  ' Cust Char #2
      LCDOUT  $FE,$58,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F  ' Cust Char #3
      LCDOUT  $FE,$60,$00,$0E,$0A,$0E,$00,$00,$00,$00  ' Cust Char #4
      LCDOUT  $FE,$68,$00,$00,$0E,$0A,$0A,$0E,$00,$00  ' Cust Char #5
      LCDOUT  $FE,$70,$00,$00,$04,$0A,$0A,$04,$00,$00  ' Cust Char #6
      LCDOUT  $FE,$78,$00,$00,$00,$00,$00,$00,$00,$00  ' Cust Char #7
    'ELAPSED TIMER
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Elapsed_INT-18.bas"  ; Elapsed Timer Routines
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    GOSUB ResetTime           ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer          ' Start the Elapsed Timer
    lcdout $fe, CS            ' Clear screen
    MAIN:                     'Display time
      IF secondsChanged = 1 THEN
         secondsChanged = 0
        nDig=minutes dig 1 : nPos=0 : gosub displaydigit
        ndig=minutes dig 0 : npos=4 : gosub displaydigit
          npos=7 : gosub colon
        ndig=seconds dig 1 : npos=8 : gosub displaydigit
        ndig=seconds dig 0 : npos=12 : gosub displaydigit
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub one
    if ndig=2 then gosub two
    if ndig=3 then gosub three
    if ndig=4 then gosub four
    if ndig=5 then gosub five
    if ndig=6 then gosub six
    if ndig=7 then gosub seven
    if ndig=8 then gosub eight
    if ndig=9 then gosub nine
    Zero:
        LCDOUT $FE,$80+nPos,3,1,3
        LCDOUT $FE,$C0+nPos,3,2,3
    One:
        LCDOUT $FE,$80+nPos,1,3,7
        LCDOUT $FE,$C0+nPos,2,3,2
    Two:
        LCDOUT $FE,$80+nPos,0,0,3
        LCDOUT $FE,$C0+nPos,3,2,2
    Three:
        LCDOUT $FE,$80+nPos,1,0,3
        LCDOUT $FE,$C0+nPos,2,2,3
    Four:
        LCDOUT $FE,$80+nPos,3,2,3
        LCDOUT $FE,$C0+nPos,7,7,3
    Five:
        LCDOUT $FE,$80+nPos,3,0,0
    Six:
    Seven:
        LCDOUT $FE,$80+nPos,1,1,3
        LCDOUT $FE,$C0+nPos,7,3,7
    Eight:
        LCDOUT $FE,$80+nPos,3,0,3
    Nine:
    colon:
        lcdout $fe,$80+nPos,5
        lcdout $FE,$C0+nPos,5
    Shawn
    Dec 2011
    IO93ok
    That looks great Shawn for my future projects but not for my timer.
    I was incorrect about my display, I used a 2x16 as well but I need to display say, 123.45 so the thinner dual height figures are just what I want. I believe i can't use them anyway.
    Melanies code is quite 'timing' critical as it should be, so I think adding the character code lookup would cause it's timing to be incorrect. I need to study it all again when I get time as I made this a year ago. I do believe there's an 'offset' in the code I can use to bring it back to correct timing I just need to experiment.
    This is Melanies slightly modified code for seconds and hundreths, this uses a 16f628
        ' Show Jumping Timer 2011 based on Olympic Timer by Melanie Newman
    '       05/Aug/2004
    '       Topical Program demonstrates use of Interrupt
    '       Driven Background TIMER, to time events down to
    '       one one-hundredth of a Second (1/100 Sec).
    '       Bonus CALIBRATION Feature allows simple adjustments
    '       in 360mS steps per hour. This calibration adjustment
    '       range is limited to +/- 36 seconds per Hour.
    '       This program is for 4MHz clock (1uS Timer Ticks).
    '       PIC Defines
    '       Change these defines to suit your chosen PIC
    @ DEVICE  pic16F628, XT_OSC    ' System Clock Options
    @ DEVICE  pic16F628, WDT_ON    ' Watchdog Timer
    @ DEVICE  pic16F628, PWRT_ON   ' Power-On Timer
    @ DEVICE  pic16F628, BOD_ON    ' Brown-Out Detect
    @ DEVICE  pic16F628, LVP_OFF   ' Low-Voltage Programming
    @ DEVICE  pic16F628, CPD_OFF   ' Data Memory Code Protect
    @ DEVICE  pic16F628, PROTECT_OFF
                                   ' Program Code Protection
    @ DEVICE pic16F628, WRT_OFF    ' Flash Memory Word Enable
    '       Hardware Defines
            '       LCD Display
            '       Adjust these to suit your chosen LCD pinout
    Define LCD_DREG PORTB          ' Port for LCD Data
    Define LCD_DBIT 4              ' Use upper 4 bits of Port
    Define LCD_RSREG PORTB         ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 3             ' Port Pin for RS bit
    Define LCD_EREG PORTB          ' Port for Enable (E) bit
    Define LCD_EBIT 1              ' Port Pin for E bit
    Define LCB_BITS 4              ' Using 4-bit bus
    Define LCD_LINES 2             ' Using 2 line Display
    Define LCD_COMMANDUS 2000
                                   ' Command Delay (uS)
    Define LCD_DATAUS 50           ' Data Delay (uS)
            '      Control Buttons/Lines
    ButStart var PortA.0          ' Take this pin low momentarily to START timing
    ButStop var PortA.1           ' Take this pin low momentarily to STOP timing
    ButReset var PortA.2          ' Take this pin low momentarily to RESET clock
            '      Hold the RESET Button pressed for at least FIVE seconds
            '      to jump into CALIBRATION Mode
    '       Software Defines
    BannerOffset var BYTE         ' Variable holding start address of Banner Display
    CounterA var BYTE             ' Just a Counter
    CounterB var BYTE             ' Just a Counter
    CounterC var BYTE
    DataA var BYTE
    'Hours var BYTE
    Hundredths var BYTE
    'Minutes var BYTE
    OverflowError var BIT
    RunningFlag var BIT
    Seconds var BYTE
    SetupTimeOut var WORD         ' Timeout counter for Calibration/Set-Up Mode
    TMR1Cal var BYTE              ' Calibration Value
                  TMR1CalAR var Byte             ' Calibration 0=ADVANCE, 1=RETARD
            TMR1RunOn var WORD             ' variable holding TMR1 Run-On value
            '       EEPROM Presets
            Data @0,0                      ' Advance/Retard Indicator
            Data 0                         ' Calibration Value
            Data "Show Jumping Seconds Timer - Robert Lane 2011"
            '       Software Constants
            TMR1CalMax con 100             ' Maximum adjustment (+/-100uS per 10mS interrupt)
            TMR1Preset con $D910           ' 10mS Timer Reload value, offset by 20uS
                                           ' to allow for TMR1 Setting Calculations
            '       Start Program
                    '       Initialise Processor
            TRISA=000000
            TRISB=000111
            'TRISC=000000
            ADCON0=000000
            ADCON1=000111
            OPTION_REG.7=0                 ' Enable Pull-Up's
            RunningFlag=0                   ' Disable actual Interrupt Time-Keeping
            Pause 1000                     ' Pause for LCD to initialise
                           '        Silly Intro Banner just for Fun
            LCDOut $FE,1                   ' Clear LCD
            BannerOffset=2:Gosub DisplayBanner
            Pause 2000
            For CounterA=0 to 30
                    BannerOffset=2+CounterA
                    Gosub DisplayBanner
                    Pause 150
                    Next CounterA
            Pause 1000
                    '       Initialise TMR1 Interrupts
            Gosub SetTimer                 ' Set the Timer for next 10mS Interrupt
            On Interrupt goto TickCount
            PIE1.0=1                       ' Enable TMR1 Interrupts
            INTCON.6=1                     ' Enable all unmasked Interrupts
            INTCON.7=1                     ' Enable Global Interrupts
                    '       Following the above "On Interrupt", no Basic Command
                    '       is allowed that takes more than 10mS to execute
                    '       otherwise the 10mS Interrupt interval is compromised.
                    '       Reset Timer Variables for Start
    DisplayReset:
            Read 0,TMR1CalAR               ' Read Calibration Advance/Retard Indicator
            Read 1,TMR1Cal                 ' Read Calibration Value
            Hundredths=0                   ' Reset Timer Counter variables
            Seconds=0
            'Minutes=0
            'Hours=0
            OverflowError=0
            '       Main Program Loop
            Enable
    DisplayLoop:
            If ButStart=0 then RunningFlag=1
            If ButStop=0 then RunningFlag=0
           ' LCDOut $FE,$80,DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds,".",DEC2 Hundredths
           LCDOut $FE,$80,DEC2 Seconds,".",DEC2 Hundredths
               If OverflowError=1 then
                    If Seconds.0=1 then
                           LCDOut $FE,$8C,"ERR"
                           LCDOut $FE,$8C,"    "
            If RunningFlag=1 then goto DisplayLoop
            If ButReset=1 then goto DisplayLoop
            Disable
            '       Reset Clock
            '       Momentarily Press the Reset Button for RESET action.
            '       Continue holding the Reset Button for MORE than 5 seconds
            '       to jump into Calibration/Set-Up Mode
    ResetClock:
            LCDOut $FE,1,"Reset OK"
            Pause 1000
            Seconds=1
            While Seconds < 5
                    Pause 1000
                    If ButReset=1 then goto DisplayReset
                    Seconds=Seconds+1
                    Wend
            '       Calibration Adjustment
            '       If No Button is Pressed for 20 Seconds, then the program
            '       will automatically exit Calibration/Set-Up Mode WITHOUT saving
            '       any new values.
            SetUpTimeout=0
    Calibration:
            LCDOut $FE,1,"Calibrate: "
            While ButReset=0:Wend          ' Wait for User to release finger
    CalibrationLoop:
            LCDOut $FE,$8B
            If TMR1Cal=0 then
                    LCDOut " "
                    If TMR1CalAR=0 then
                           LCDOut "+"
                           LCDOut "-"
            LCDOut #TMR1Cal," "
                    '       Press Start Button to ADVANCE (speed-up) Clock
                    '       Press STOP Button to RETARD (slow-down) Clock
                    '       Press RESET Button to SAVE new Calibration Setting
                    '       Remember each Calibration 'tick' will advance or
                    '       retard the Timing by 1uS in every 10mS period - that's
                    '       360mS/Hour per setting. Example: A setting of +8 will
                    '       SPEED-UP the Timer by 2.88 Seconds (8 x 360mS) in an Hour.
            If TMR1CalAR=0 then
                    If ButStart=0 then Gosub CalAdvance
                    If ButStop=0 then Gosub CalRetard
                    If ButStart=0 then Gosub CalRetard
                    If ButStop=0 then Gosub CalAdvance
            If ButReset=0 then
                    Write 0,TMR1CalAR
                    Write 1,TMR1Cal
                    LCDOut $FE,1,"Bye Rob"
                    Pause 1000
                    Goto DisplayReset
            SetupTimeout=SetupTimeout+1
            If SetupTimeout>200 then goto DisplayReset
            Pause 100
            Goto CalibrationLoop
            '       Subroutine Increments Calibration Value
    CalAdvance:
            SetupTimeout=0
            If TMR1Cal=>TMR1CalMax then
                    TMR1Cal=TMR1cALmAX
                    TMR1CalAR=TMR1CalAR^1
                    TMR1Cal=TMR1Cal+1
            '       Subroutine Decrements Calibration Value
    CalRetard:
            SetupTimeout=0
            If TMR1Cal=0 then
                    TMR1Cal=1
                    TMR1Cal=TMR1Cal-1
            '       Subroutine Displays Banner Intro
    DisplayBanner:
            CounterC=BannerOffset+15
            LCDOut $FE,$80
            For CounterB=BannerOffset to CounterC
                    Read CounterB,DataA
                    LCDOut DataA
                    Next CounterB
            '       Subroutine Loads TMR1 values
    SetTimer:
            T1CON.0=0                     ' Stop the Clock
            TMR1RunOn.Highbyte=TMR1H       ' Load the Run-On (Over-Run) value (if any)
            TMR1RunOn.Lowbyte=TMR1L
            TMR1RunOn=TMR1Preset+TMR1RunOn
                                          ' Calculate the New (adjusted) value for TMR1
            If TMR1CalAR=0 then            ' Calibration ADVANCE (add) or RETARD (subtract)
                    TMR1RunOn=TMR1RunOn+TMR1Cal
                    TMR1RunOn=TMR1RunOn-TMR1Cal
            TMR1H=TMR1RunOn.Highbyte       ' Save new values to TMR1
            TMR1L=TMR1RunOn.Lowbyte
            T1CON.0=1                     ' Restart the Clock
            PIR1.0=0                      ' Reset TMR1's Interupt Flag
            '       Timer Interrupt Handler
    TickCount:
            If RunningFlag=1 then          ' If timing actually enabled... then...
                    Hundredths=Hundredths+1
                                          ' Increment 10mS Seconds Counter
                    If Hundredths>99 then
                           Hundredths=0
                           Seconds=Seconds+1
                            ' Increment the Seconds -- Show Jumping to 500
                           If Seconds>500 then
                                   Seconds=0
                        '   If Seconds>59 then
                         '          Seconds=0
                           '        Minutes=Minutes+1
                                          ' Increment the Minutes
                             '      If Minutes>59 then
                              '            Minutes=0
                                '          Hours=Hours+1
                                          ' Increment the Hours
                            ' If Hours>99 then
                             ' Handle any Overflow
                              '      Hours=0
                             '       OverFlowError=1
                              '      endif
                            ' endif
                      ' endif
    Resume
    Apr 2007
    Pennsylvania, USA
    Yes these digits are a display hog They will work well for me since I will be displaying time and temperature.
    Shawn
    Miami, Florida USA
    Quote Originally Posted by spcw1234 View Post
    clear
    trisc=0
    trisb=0
    trisa=0
    nPos  var byte
    nDig  var byte
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,1
    'ELAPSED TIMER
    MAIN:                     'Display time
         secondsChanged = 0
    displaydigit:
    Zero:
    One:
    Two:
    Three:
    Four:
    Five:
    Six:
    Seven:
    Eight:
    Nine:
    colon:
    Attachment 6218
    Nice code and well organized code structure. Thanks for sharing.
    Anonymous
    Jan 2011
    Skopje,Macedonia
    where I can find this bas files:
    INCLUDE "DT_INTS-18.bas" INCLUDE "ReEnterPBP-18.bas" INCLUDE "Elapsed_INT-18.bas"
    thanks
    Apr 2007
    Pennsylvania, USA
    Quote Originally Posted by SKOLS1 View Post
    thanks
    http://darreltaylor.com/DT_INTS-18/home.html
    Shawn
    Dec 2011
    IO93ok
    Shawn, you've copyrighted and reserved the rights. Is it all right with you that I modify it and put it on here ?
    Apr 2007
    Pennsylvania, USA
    Quote Originally Posted by tasmod View Post
    Copy all you want, most of the code was copied off of this site as it is already!
    Shawn
    Dec 2011
    IO93ok
    Thanks, it's just that normally I wouldn't add the copyright notice for anything for open source public consumption.
    I'm trying to use just the seconds and 'ticks'
    Apr 2007
    Pennsylvania, USA
    MCS adds that automatically the way I have it set up. I will change that for future posts. Thanks for pointing it out.
    Shawn
    Dec 2011
    IO93ok
    OK, I have the Dt_ints stopwatch version working on my display using the thinner characters as i.e. 123:45
    This works bar one problem.
    It will not display the Character 0 code it is just an all pixel black block. So this affects the numbers 1, 4, 7.
    The code I mean is
    LCDOUT $FE,$40,$01,$01,$01,$01,$01,$01,$01,$01
    According to the sheet that came with the display it has 16 CGRAM custom character spaces available.
    I tried using Character 8 instead . i.e. LCDOUT $FE,$80,$01,$01,$01,$01,$01,$01,$01,$01
    this produced a curled 'J' character which is not part of the inbuilt set.
    I can't figure this one out??? Any ideas please ?
    Apr 2007
    Pennsylvania, USA
    You have the LCDOUT command correct to display a '1' I don't see any problems. I feel the problem is somewhere else in your code. All the other 7 characters work fine?
    Shawn
    Dec 2011
    IO93ok
    Grrr, how come when I post the problem it immediately solves itself. I just resaved the bas file under a different name and reprogrammed the chip and it works!
    Thanks for the input Shawn.
    I now have a stopwatch that works and will have easier to read characters. :-)
    Apr 2007
    Pennsylvania, USA
    I know what you mean!
    Shawn
    Dec 2011
    IO93ok
    Ahh, I spoke to soon. It does work but not as I would want.
    I believe it's in the assembler bit of Elapsed_Int that I need to make a change but I don't know where to start. :-(
    The 3 x seconds digits rollover at 59.99 and zero again. The digits do not continue to 60, 61 etc. the first digit stays at 0 as well. I need it to continue to 3 x seconds digits probably ending at 500 but not essential. So that 129.54 would be possible say.
    Anyone give me a clue ??
    Dec 2011
    IO93ok
    This is the code I have :-
    '*             : PIC16F628                                      *
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    define OSC 10               'oscillator setting
    define LCD_DREG PORTB       'set LCD data port
    define LCD_RSREG PORTB      'define RS port
    define LCD_EREG PORTB       'set LCD ENABLE port
    clear
    cmcon=7
    trisb=%00000000
    trisa=%11111111
    input  porta.0
    input  porta.1
    input  porta.2
    nPos  var byte
    nDig  var byte
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,1
    'setup the custom characters
    LCDOUT  $FE,$40,$01,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #0
    LCDOUT  $FE,$48,$1F,$11,$11,$11,$11,$11,$11,$11  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$10,$10,$10,$10,$10,$10,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$01,$01,$01,$01,$01,$01,$01,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$1F,$11,$11,$11,$11,$11,$11,$1F  ' Cust Char #4
    LCDOUT  $FE,$68,$11,$11,$11,$11,$11,$11,$11,$1F  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$01,$01,$01,$01,$01,$01,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1F,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #7
    LCDOUT  $FE,$80,$01,$01,$01,$01,$01,$01,$01,$01  ' Cust Char #0
    'ELAPSED TIMER
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines
    MAIN:                     'Display time
      if porta.0 = 1 then GOSUB StartTimer     ' Start the Elapsed Timer
      if porta.1 = 1 then gosub StopTimer
      if porta.2 = 1 then GOSUB ResetTime      ' Reset Time
        nDig=seconds dig 2 : nPos=0 : gosub displaydigit   'hundreds
        nDig=seconds dig 1 : nPos=1 : gosub displaydigit   'tens
        ndig=seconds dig 0 : npos=2 : gosub displaydigit   'ones
        LCDOUT $FE,$C0+3,":"
        ndig=ticks dig 1 : npos=4 : gosub displaydigit     'tenths
        ndig=ticks dig 0 : npos=5 : gosub displaydigit     'hundreths
    displaydigit:
    if ndig=1 then gosub One
    if ndig=2 then gosub Two
    if ndig=3 then gosub Three
    if ndig=4 then gosub Four
    if ndig=5 then gosub Five
    if ndig=6 then gosub Six
    if ndig=7 then gosub Seven
    if ndig=8 then gosub Eight
    Zero:
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    Three:
    	LCDOUT $FE,$80+nPos,6
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    Apr 2007
    Pennsylvania, USA
    The timer works like a clock. when seconds roll over from 59 it will go to 00 and minutes will advance. There is no hundreds position in the seconds.
    Shawn
    Dec 2011
    IO93ok
    Hmm, yes. But it must be possible for it to continue instead of rolling over. This is what I altered in Melanies code to do this, however that was all PBP and no assembler.
    That's where I'm lost. The code in Elapsed_INT I'm sure can be modified to continue counting the seconds into the seconds byte without a rollover, but where in the code?
    You can modify the "Elapsed_INT.bas". If you open this file you will see some pbp code at "ClockCount:" . You can change the if statements for Hours, minutes, and seconds. Or you can add another varible and maintain the original code. I added the code in bold. Hope it helps.
    seconds2 var word 'place in main code
    ClockCount:
    @ RELOAD_TIMER                    ; Reload TIMER1
        Ticks = Ticks + 1
        if Ticks = 100 then
           Ticks = Ticks-100
           Seconds = Seconds + 1
    SecondsChanged = 1
    seconds2 = seconds2 + 1
     If seconds2 = 500 then ' Rollover at 500 seconds
      seconds2= 0
           if Seconds = 60 then
              Minutes = Minutes + 1
              MinutesChanged = 1
              Seconds = 0
           if Minutes = 60 then
              Hours = Hours + 1
              HoursChanged = 1
              Minutes = 0
           if Hours = 24 then
              Days = Days + 1
              DaysChanged = 1
              Hours = 0
    @ INT_RETURN                      ; Restore context and return from
    Dec 2011
    IO93ok
    Hi Mark,
    Many thanks, I was just logging in to report what an idiot I am and to say it all works.
    I had done all that and more but it still refused to work.
    Doh, turns out I was altering a spare copy of Elapsed_INT in another folder !!!
    I'm going to turn on the MCS option to show the full path so in future i won't make the same mistake again.
