First try at DT_INT's, I failed! help please!
THE BOOK of DT's INTERRUPTS is an organization of interrupt service routines and other works written by Darrel Taylor, RIP.
Interrupt routines are arranged per Darrel's original list. Darrel Taylor's Instant Interrupts are an extension of the work of Tim Box whom in October of 2002 wrote INT_CTRL.pbp
Many of the forum members felt this is a long overdue project.
will be a valuable resource and a tribute to Darrel Taylor the "Fanatical Contributor".
THE BOOK of DT's INTERRUPTS is located at http://dt.picbasic.co.uk/
+ Reply to Thread
Results 1 to 6 of 6
    Alabama,USA
    Default First try at DT_INT's, I failed! help please!
    Old dogs can learn new tricks, it just takes a little more effort. Can someone please tell me why the RB0 interrupt only works once on this simple routine? This is my first attempt at DT_INT’s. Once I got MPASM set up on MCSP I thought it would be easy. I’m using X1 board with 16F877A and pulsing RB0 with a wire lead. It runs the leds once then will not run again. I’ve tried everything I can think of with no success.
    define osc 20
        option_reg.6=1 'rising pulse
        wsave   var byte $70  system
        wsave1  var byte $A0  system
        wsave2  var byte $120 system
        wsave3  var byte $1A0 system
        i       var byte
        LEDS    Var PORTD   ' Alias PORTD to LEDS
        TRISD = %00000000       ' Set PORTD to all output
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
      PAUSE 1
      PortD=0
      GOTO Main
    ToggleLED1:  LEDS = 1        ' First LED on
            Pause 500       ' Delay for .5 seconds
            For i = 1 To 7  ' Go through For..Next loop 7 times
                    LEDS = LEDS << 1        ' Shift on LED one to left
            Next i
    @ INT_RETURN
    Alabama,USA
    Default Re: First try at DT_INT's, I failed! help please!
    OK, I have found out that it is returning from the interrupt. However I can not interrupt again for about ten seconds or the interrupt fails. A failure to interrupt forces another ten second delay before I can trigger again. Is there anything I can do to speed this process? On compile the program shows only 255 words long. I don’t understand this time delay before I can re enter the interrupt. Comments please…
    That's the problem.
    If you are using a wire to +5V, there's nothing to pull it back down.
    The pin will hold a charge, and will slowly drain off, allowing it to re-trigger after a few seconds.
    If you add a pull-down resistor it should work better.
    Or, you can turn on PORTB pull-ups (OPTION_REG.7 = 0), make PORTB.4 LOW so you can use SW1 pushbutton.
    Changing to OPTION_REG.6 = 0 will make it trigger on the falling edge (button press) instead of the rising edge (button release).
    Alabama,USA
    Thanks Darrel, I'll give it a try!
    Alabama,USA
    Yep! works great!
    This is funny, I did this very exercise yesterday and posted it in the Code Examples. LOL
