16f887 connect 4 - help needed
Results 1 to 2 of 2
    Feb 2011
    Post 16f887 connect 4 - help needed
    I am having a problem on my connect 4 game that uses a bi-color matrix. I am able to drop 1 color dot down and stack that same color until it gets to the top. The problem is with my matrix you cant have difrent color dots in the same column. So i think i would need to flash the 2 colors(Portc and portd) at different times by changing them from outputs to inputs really fast.
    I tried putting a gosub flash (flash being a loop) in different locations in my code so it would constantly flash anywhere it was in my code.
    here is my flash loop
    flash:
    trisc=%00000000
    trisd=%11111111
    pauseus 1
    trisc=%11111111
    trisd=%00000000
    pauseus 1
    The problem is when i add this it causes a red checker to be on when i power up(when it should be off). Then i try to press my drop button and it wont fall and if i click the button to select the red checker then it turns off completely. I have no problem with the green checker.
    I don't know what the problem is, i have a feeling it is very simple but i just cant figure it out any suggestions?
    If you have any problems understanding my code please ask and i will try to explain it to you.
    fall var byte
    Shift var byte
    pb1 var porta.0
    pb2 var porta.1
    pb3 var porta.2
    rowvar var byte
    b1 var byte
    b var byte
    c var byte
    c1 var byte
    c2 var byte
    c3 var byte
    c4 var byte
    d1 var byte
    d2 var byte
    d3 var byte
    d4 var byte
    d var byte
    rows var byte
    stack var byte
    row1 var byte
    row2 var byte
    row3 var byte
    row4 var byte
    row5 var byte
    row6 var byte
    row7 var byte
    shift1 var byte
    shift2 var byte
    shift3 var byte
    shift4 var byte
    shift5 var byte
    shift6 var byte
    shift7 var byte
    fall2 var byte
    fall3 var byte
    fall4 var byte
    fall5 var byte
    fall6 var byte
    fall7 var byte
    greenled var byte
    redled var byte
    down var byte
    counts var byte
    'define osc 8
    'portc=red
    'portd=green
    'osccon =%01110101
    counts=0
    ansel=0
    anselh=0
    fall = 0
    fall2=0
    fall3=0
    fall4=0
    fall5=0
    fall6=0
    fall7=0
    Shift = 7
    shift2=7
    shift3=7
    shift4=7
    shift5=7
    shift6=7
    shift7=7
    greenled=0
    redled=0
    portb=b+b1
    rows=1
    stack=1
    down=1
    trisA=%11111111
    trisb=%00000000
    trisc=%00000000
    trisd=%00000000
     b1=%11111111
        b= %01111111
    portc=%00000000
    portd=%00000000
        portb=b1+b
    looppick:
     if pb2=0 then goto red
     if pb3=0 then goto green
    gosub flash
     goto looppick
    red:
    b1=%11111111
        b= %01111111
    portc=%00000001
    portd=%00000000
     redled=redled+1
    gosub flash
    goto loopa
     green:
    b1=%11111111
       b= %01111111
    portd=%00000001
     portc=%00000000
     greenled=greenled+1
    gosub flash
    goto loopa
       loopa:
          portb=b1+b
         gosub flash
        if (pb1==0 & b.7==0) then fall=1
          if (fall==1) then
            b1.0[Shift] = 1
            b1.0[Shift - 1] = 0
            Shift = Shift - 1
          if (b1.0[stack]=0)then fall=0:goto main
          goto loopa
         gosub flash
          'fall=0
          'fall2=0
          'fall3=0
          'fall4=0
          'fall5=0
          'fall6=0
          'fall7=0
          portb=b1+b
     if down=0 then b1=%11111111 : b=%01111111
     if down = 1 then b1=%11111101 : b=%01111111
     if down = 2 then b1=%11111001 : b=%01111111
     if down = 3 then b1=%11110001 : b=%01111111
     if down = 4 then b1=%11100001 : b=%01111111
     if down = 5 then b1=%11000001 : b=%01111111
     if down = 6 then b1=%10000001 : b=%01111111
         stack=stack+1
         down=down+1
         if down=7 then down=6
     counts=counts+1
     if counts=1 then goto loopb
     if counts=2 then goto loopc
     if counts=3 then goto loopd
     if counts=4 then goto loope
     if counts=5 then goto loopf
     if counts=6 then goto loopg
       loopb:
         portb=b1+b
           gosub flash
        if (pb1==0 & b.7==0) then fall2=1
          if (fall2==1) then
            b1.0[Shift2] = 1
            b1.0[Shift2 - 1] = 0
            Shift2 = Shift2 - 1
          if (b1.0[stack]=0)then fall2=0:goto main
          goto loopb
          loopc:
         gosub flash
      portb=b1+b
        if (pb1==0 & b.7==0) then fall3=1
          if (fall3==1) then
            b1.0[Shift3] = 1
            b1.0[Shift3 - 1] = 0
            Shift3 = Shift3 - 1
          if (b1.0[stack]=0)then fall3=0:goto main
          goto loopc
              loopd:
              gosub flash
              portb=b1+b
        if (pb1==0 & b.7==0) then fall4=1
          if (fall4==1) then
            b1.0[Shift4] = 1
            b1.0[Shift4 - 1] = 0
            Shift4 = Shift4 - 1
          if (b1.0[stack]=0)then fall4=0:goto main
          goto loopd
              loope:
              gosub flash
       portb=b1+b
        if (pb1==0 & b.7==0) then fall5=1
          if (fall5==1) then
            b1.0[Shift5] = 1
            b1.0[Shift5 - 1] = 0
            Shift5 = Shift5 - 1
          if (b1.0[stack]=0)then fall5=0:goto main
          goto loope
            loopf:
            gosub flash
             portb=b1+b
        if (pb1==0 & b.7==0) then fall6=1
          if (fall6==1) then
            b1.0[Shift6] = 1
            b1.0[Shift6 - 1] = 0
            Shift6 = Shift6 - 1
          if (b1.0[stack]=0)then fall6=0:goto main
          goto loopf
          loopg:
         gosub flash
          portb=b1+b
        if (pb1==0 & b.7==0) then fall7=1
          if (fall7==1) then
            b1.0[Shift7] = 1
            b1.0[Shift7 - 1] = 0
            Shift7 = Shift7 - 1
          if (b1.0[stack]=0)then fall7=0:goto main
          goto loopg
    flash:
    trisc=%00000000
    trisd=%11111111
    pauseus 1
    trisc=%11111111
    trisd=%00000000
    pauseus 1
    Nov 2006
    Murrieta, CA
    Default Re: 16f887 connect 4 - help needed
    Try using the "PULSEOUT" or the "FREQOUT" command for flashing.
    Not quite sure how big your matrix is but standard connect 4 grid is 42 (6x7).
    Thinking more in depth to your project you could take it a step further and make it a hell of a lot easier on yourself by implementing a MAX6952 Matrix controller.
    but I like your project hope to see working video of it when complete.
