+ Reply to Thread
Results 1 to 2 of 2
Thread: Pic 16f628a running at lower than 4.5V
    Jun 2004
    Question Pic 16f628a running at lower than 4.5V
    Hello all. I have a project involving Pic16f628A. The power supply must be 3.5V. I looked in the datasheet and for that voltage I have to use a 10-14 MHz resonator. I am using 12MHz. The problem is that the pic won't start unless the power reaches 4.5V. Can anyone help me ? Thank you.
    Jun 2004
    Thumbs up I found the answer by myself
    The BrownOutReset bit was activated, and the minimum voltage that triggers BOR is 4.4V. I disabled BOR and now everything is ok.
+ Reply to Thread
  1. pic first build test board not running
    By comwarrior in forum Schematics
    Last Post: - 29th June 2009, 16:48
  2. Cant get my PIC running
    By Viberer in forum Off Topic
    Last Post: - 29th August 2008, 20:07
  3. Crystal osc running but PIC not using it
    By p15218 in forum mel PIC BASIC Pro
    Last Post: - 18th February 2007, 22:33
  4. IR-RS232 with pic 16F628A
    By aloncha in forum mel PIC BASIC Pro
    Last Post: - 13th September 2005, 17:33
    Last Post: - 11th March 2005, 23:14
