Trying to use CGRAM of LCD with PIC16F877A
Results 1 to 5 of 5
    Dec 2008
    Charlottesville, VA
    Default Trying to use CGRAM of LCD with PIC16F877A
    All,
    I am trying to find a way to create custom characters using the CGRAM of a 20x4 LCD. I've been trying to browse online and I've only located ASM examples. I can't completely understand ASM so I'd much rather write it in PBP. I have the LCD wired to PORTB of my PIC16F877A MCU. I've listed my define's as shown in the code below.
    DEFINE OSC 20               ' Define 20MHz Oscillator
    DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1          ' Set LCD Register Select bit - pin 4 of LCD
    DEFINE LCD_RWREG PORTB      ' Set LCD Read Write port
    DEFINE LCD_RWBIT 2          ' Set LCD Read Write bit - pin 5 of LCD
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 3           ' Set LCD Enable bit - pin 6 of LCD
    DEFINE LCD_DREG PORTB       ' Set LCD Data port
    DEFINE LCD_DBIT 4           ' Set starting bit (0 or 4) if 4-bit bus
    DEFINE LCD_BITS 4           ' 4-bit LCD data bus - pins 11 - 14 of LCD
    DEFINE LCD_LINES 4          ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
    DEFINE LCD_DATAUS 50        ' Set data delay time in us
    Now, I have no problem with sending messages to my LCD.
    MAIN:
        LCDOUT $FE, 1
        LCDOUT $FE, 2
        LCDOUT $FE, $0C
        LCDOUT "Testing my 20x4"
        LCDOUT $FE, $C0
        LCDOUT "LCD project."
        LCDOUT $FE, $94
        LCDOUT "Built By:"
        LCDOUT $FE, $D4
        LCDOUT "Me"
        PAUSE 3000
        GOTO MAIN
    However, I've designed a "logo", if you will, that I would like to display on the LCD. I know that I want to use the 5x8 dot format but I'm not sure how to do this in PBP. Nor am I certain of how to write to the CGRAM addresses that need to be written to in order to display the characters that I'm trying to create. Can anyone provide an example PBP code to help me with this?
    Thanks in advance....
    Morris Beasley
    Manufacturing Test Technician
    B.S. Industrial Technology (2007)
    For more information on our robotics, please visit:
    http://www.ish-electronics.webs.com
    Default Re: Trying to use CGRAM of LCD with PIC16F877A
    Dec 2008
    Charlottesville, VA
    Thank you for your response... I've looked at the two links that you posted and I understand now how to write the data to the CGRAM registers. How though, do I tell the LCD a specific location to display the created character? I've attached a jpeg of how I want to display these 5x7s. As you can see, the top left of the I starts in the 3rd character location of the first line. So I need to figure out first how to write that to CGRAM and then how to display it in that particular location. I'm hoping that I can write one location of CGRAM, display it, then overrite that location to display something different in a different location. Any thoughts? If anyone has an idea of how I can get my LCD to properly display what I have attached, I would greatly appreciate any of your help with this.
    Thanks again in advance.
    Morris Beasley
    You must not have read the whole thread.
    http://www.picbasic.co.uk/forum/show...6027#post46027
    Dec 2008
    Charlottesville, VA
    Mackrackit,
    You were right again sir... I missed that part lower down. I discovered that what I was trying to do would not work because it would require 12 locations rather than 8. So I changed it a little and had it display a spade instead. I'm posting my code below in case you want to play with it or something. Once again I thank you for your help.
    '*  Name    : LCDTEST.BAS                                      *
    '*  Author  : Morris C. Beasley, Jr.                            *
    '*  Notice  : Copyright (c) 2011 Morris C. Beasley, Jr.         *
    '*  Date    : 7/30/2011                                         *
    DEFINE ADC_BITS 10          ' Defines number of adc bits (o - 255 output)
    DEFINE ADC_CLOCK 3          ' ADC clock speed
    DEFINE ADC_SAMPLEUS 1       ' How often the adc samples inputs
    PAUSE 1000
    ' List the programmable CGRAM locations.  They are commented out because they  *
    ' are used as reference only.  All should know that commands are sent to the   *
    ' LCD by sending an $FE followed by the command itself.  In this situation, the*
    ' command is going to be the CGRAM address.  For example, LCDOUT $FE, $40 is   *
    ' writing to the 0 location of CGRAM.  There are 8 locations in total (0-7).   *
    ' That command is followed by the 8 bytes representing each row in the matrix. *
    ' In a 5x8 matrix, the 3 MSB are not used, therefore, xxxLLLLL is your byte,   *
    ' where x is not used and L is the logic of which you wish that box to be.     *
    ' As an example, the following command darkens an entire matrix at the given   *
    ' location:  LCDOUT $FE,$40,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F.  The first byte   *
    ' is the top line while the last byte is the bottom line.                      *
    ' Constants are created to indicate the beginning of each line on a 20x4 LCD.  *
    'LOCATION 0 = $40 = 64
    'LOCATION 1 = $48 = 72
    'LOCATION 2 = $50 = 80
    'LOCATION 3 = $58 = 88
    'LOCATION 4 = $60 = 96
    'LOCATION 5 = $68 = 104
    'LOCATION 6 = $70 = 112
    'LOCATION 7 = $78 = 120
    ROW1 CON 128                '$80 - LINE 1
    ROW2 CON 192                '$C0 - LINE 2
    ROW3 CON 148                '$94 - LINE 3
    ROW4 CON 212                '$D4 - LINE 4
    BATVOLTAGE VAR WORD         ' Variable for battery voltage
    BAT_DIGIT VAR BYTE          ' Variable for voltage digits before decimal
    BAT_DEC VAR BYTE            ' Variable for voltage digits after decimal
    ADCON1 = %10000010          ' ADC configuration
    TRISA = %11111111           ' Configure PortA
    TRISB = %00000000           ' Configure PortB
    MAIN:
        LCDOUT $FE, 1       'Clear the display
        LCDOUT $FE, 2       'Turn the cursor off
        LCDOUT $FE,$40,$00,$00,$00,$00,$00,$04,$0E,$1F  'Writes top of spade to CGRAM address 0
        LCDOUT $FE,$48,$01,$03,$07,$0F,$1F,$1F,$1F,$1F  'Write upper left of spade to CGRAM address 1
        LCDOUT $FE,$50,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F  'Write upper center of spade to CGRAM address 2
        LCDOUT $FE,$58,$10,$18,$1C,$1E,$1F,$1F,$1F,$1F  'Write upper right of spade to CGRAM address 3
        LCDOUT $FE,$60,$1F,$0F,$07,$00,$00,$01,$03,$07  'Write lower left of spade to CGRAM address 4
        LCDOUT $FE,$68,$1F,$1F,$0E,$0E,$1F,$1F,$1F,$1F  'Write lower center of spade to CGRAM address 5
        LCDOUT $FE,$70,$1F,$1E,$1C,$00,$00,$10,$18,$1C  'Write lower right of spade to CGRAM address 6
        LCDOUT $FE, ROW1+2, 0
        LCDOUT $FE, ROW1+5, "ISH ELECTRONICS"
        LCDOUT $FE, ROW2+1, 1
        LCDOUT $FE, ROW2+2, 2
        LCDOUT $FE, ROW2+3, 3
        LCDOUT $FE, ROW2+11, "BY"
        LCDOUT $FE, ROW3+1, 4
        LCDOUT $FE, ROW3+2, 5
        LCDOUT $FE, ROW3+3, 6
        LCDOUT $FE, ROW3+9, "MORRIS"
        LCDOUT $FE, ROW4+9, "BEASLEY"
        PAUSE 2000
        GOSUB CHECK_VOLTAGE
        PAUSE 100
        GOTO MAIN
    CHECK_VOLTAGE:
        ADCIN 0, BATVOLTAGE     ' Store the 10-bit conversion in variable
        BAT_DIGIT = (BATVOLTAGE * 5) / 1000
        BAT_DEC = (BATVOLTAGE * 5) - (BAT_DIGIT * 1000)
        LCDOUT $FE, ROW1+5, "    VOLTAGE    "
        LCDOUT $FE, ROW2+5, "    MEASURED   "
        LCDOUT $FE, ROW3+5, "       AT      "
        LCDOUT $FE, ROW4+5, DEC BAT_DIGIT, ".", DEC BAT_DEC, "DC Volts"
        PAUSE 2000
    Morris Beasley
