reset_org with 16f193X ?
Results 1 to 3 of 3
    Mar 2011
    Unhappy reset_org with 16f193X ?
    hi everobody,
    I use a 16F193x with a home bootloader
    my bootloader is put between 0x0000 and 0x08FF
    I created a test program with picbasic pro 2.60c
    but when I use a routine : DEFINE RESET_ORG 0x0900
    the compilator return an error "ERROR[101] c:\pbp\pbppi14e.lib 7907 : ERROR: (library cannot exceed address 800h.)"
    I think it's because is not in the same page and picbasic pro doesn't use a PCLATH register (pagesel)
    how can I do for use my home bootloader and use picbasic pro for the software?
    thanks
    Default Re: reset_org with 16f193X ?
    Not sure how to do what you want but I do think you are going about it wrong
    From the manual:
    DEFINE RESET_ORG 0h 'Change reset address for PIC18
    Mar 2011
    Wink Re: reset_org with 16f193X ?
    hi,
    thanks for you reply
    I don't find your answer in my manual (LOL) I have the version 6/09
    It only write "DEFINE RESET_ORG 0h ‘Change reset address"
    Before I write my bootloader, RESET_ORG moved the code ;-)
    I opened the pbppli14e.lib and find this :
     ifndef USE_LINKER
          if ($ > 800h)
      LIST
     error "Library cannot exceed address 800h."
      NOLIST
    So I define USE_LINKER in my code with RESET_ORG
    and it work well
    ex : DEFINE RESET_ORG 100h only
    MEMORY USAGE MAP ('X' = Used,  '-' = Unused)
    0100 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    0140 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    0180 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXX-------
    8000 : XXXX---XX------- ---------------- ---------------- ----------------
    and with
    DEFINE RESET_ORG 900h
    DEFINE USE_LINKER 1
    0900 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    0940 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX
    0980 : XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX XXXXXXXXX-------
    thanks
