+ Reply to Thread
Results 1 to 6 of 6
Thread: Problem with RBC_INT unique to this codeset...HELP!
    Mar 2009
    Colorado
    Default Problem with RBC_INT unique to this codeset...HELP!
    I have used RBC_INT many times before with no problems, but have encountered a problem with it as implemented in a unique code set that is driving me crazy.
    Here is how it is supposed to work for comparison to code I will provide below:
    1) DS1337 Real-time-clock generates an Alarm1 interrupt every minute on its _INTA pin which is connected to RB2 on my 16F886.
    2) RBC_INT is supposed to recognize _INTA signal falling edge and go to handler labled "Alarm".
    3) The ISR "Alarm" sets logflag=1 which is recognized by IF statement in main loop and calls subroutine "Logging" to log date/time stamped data.
    I have extensive LED blinking codes embedded at various places in my code so I can see what is going on at run time. I also am writing key values to EEPROM to help in post-run troubleshooting. From these test techniques I can see very clearly what is going on but can't figure out how to correct it. Here is what is happening:
    a) EEPROM entries show the clock has the correct Alarm1 time and is keeping good time and generates _INTA falling edge at correct Alarm1 time.
    b) Lack of LED flashes indicate no entry to the Alarm handler...hence RBC_INT is not recognizing the _INTA signal change.
    c) Therefore, the code in the Alarm Handler is not setting the logflag, resetting the _INTA on the RTC, or reading PortB to eliminate the mismatch.
    d) With no set of the logflage, no triggering of the Logging subroutine in the mainloop.
    d) Hence no further _INTA signals are generated by the RTC and the _INTA signal stays low as confirmed by a voltmeter.
    e) With no further _INTA signals there are no further RTC_INT actions and my code malfunctions.
    Hopefully with these code excerpts someone out there can tell me where I am going wrong and why the RBC_INT is not recognizing the _INTA. ANY HELP GREATLY APPRECIATED!!
    Here is the code that I think sets up the RBC_INT correctly...can anyone see anything wrong with this?
    '--- Setup Interrupts ----------------------------------------------------
    INT_LIST  macro      ; IntSource,        Label,  Type, ResetFlag?
            INT_Handler      RBC_INT,       _Alarm,   PBP,  yes
    ' Per DT, DT_INTS already takes care of setting INTCON register
    ' but this code doesn't work unles below registers also set as indicated:
        IOCB.2= 1           ' ENABLE IOC INERRUPT ON PORTB.2 (RB2) for Alarm1
        TRISB = %00010100   ' RB2 set as input from RTC Alarm1
                            ' PORTB.2 is also an interrupt from manual switch GND
                            ' PORTB.4 is set for input as A/D Channel 11
        WPUB = 0            ' DISABLE all PortB pull-ups
        CM1CON0 = 0         ' DISABLE COMPARATORS
        CM2CON0 = 0         ' DISABLE COMPARATORS
    Here is my mainloop code to show how things happen while waiting for RBC_INT occurence...LED blinks indicate it is operating correctly. but call to Logging subroutine is never triggered, indicated the logflag was never set in the RBC_INT handler:
    mainloop:
        ' Blink Green LED 1x short at start of mainloop as heart beat
                TOGGLE LED_GRN
                PAUSE 250
                TOGGLE LED_GRN
                PAUSE 2000
        ' Read current time/date
            I2CREAD SDA, SCL, RTCdevice, SecReg,[sec,MINs,hr,day,date,mon,yr]
            PAUSE 20
        ' Display current Date/Time if LCD installed
            IF LCD_Flag = 1 THEN ' Display only if LCD installed
                LCDOUT $fe,1 ' Clear Display
                LCDOUT $fe,Line1,HEX2 mon,"/",HEX2 date,"/", HEX2 yr
                LCDOUT $FE,Line2,HEX2 hr,":",HEX2 MINs,":",HEX2 sec
        ' Read temperature & log to EEPROM for test readout
            GOSUB Temperature
            WRITE 6, temp    'COMMENTED OUT DURING OPS TO SAVE EEPROM
        'Check to see if Alarm1 Interrupt occured and service if it did
            IF logflag = 1 THEN ' Alarm1 interrupt has occured
    ;@    INT_DISABLE   RBC_INT ' Disable RBC interrupts during routine
               GOSUB Logging    ' Log the interrupt
    ;@    INT_ENABLE   RBC_INT  ' Re-enable RBC interrupts after routine
        ' Send Email if temperature below/above threshold
            IF (temp <= $28) THEN  ' If temp <= 40 deg F send email
               GOSUB Email
            ELSEIF (temp >= $55) THEN   ' If temp >= 85 deg F send email
               GOSUB Email
            'ADCON1 = %00001110
        ' Write current temperature to EEPROM ....Uncomment FOR TEST ONLY
            WRITE 10, temp
        GOTO mainloop
    Here is my handler for the RBC_INT that is not being entered the way it should and hence actions required to reset flags and interrupts aren't happening:
    Alarm:
          ' Blink Red LED 3x at start of Alarm interrupt...Uncomment FOR TEST ONLY
          'THIS IS NEVER SEEN TELLING ME RBC_INT DIDN'T RECOGNIZE _INTA from RTC!
                FOR I = 0 TO 2
                    TOGGLE LED_RED
                    PAUSE 250
                    Toggle LED_RED
                    PAUSE 250
                NEXT
           logflag = 1    ' Set flag to log this RB2 interrupt in mainloop
           dummy = PORTB  ' Read PortB to eliminate mismatch on interrupt
           ' Clear the Alarm flags to be ready for next RTC interrupt
             ' Reset Alarm1 (INTA) interrupt by clearing STATUS register
                    I2CWRITE SDA, SCL, RTCdevice, StatusReg,[$00]
                    PAUSE 1000
           ' Resume Main Program where Interrupt happened
    @ INT_RETURN
    And here is my logging subroutine that should be executed after each interrupt causes logflag to be set in handler (which obviously isn't happening):
    Logging:
            ' Blink the RED LED 1 sec 3x
                FOR I = 0 TO 2
                      TOGGLE LED_RED
                      PAUSE 1000
                      TOGGLE LED_RED
                      PAUSE 1000
                NEXT
                PAUSE 1000
                IF J > 220 THEN  ' If EEPROM logging space is full, reset logging
                   J = 0     ' index to start of logging space.
                             ' Logging space covers time stamps for 220 interrupts
            ' Log date/time stamped temperature from LM34 sensor to EEPROM
                WRITE 16+J, hr
                WRITE 17+J, MINs
                WRITE 18+J, sec
                WRITE 19+J, temp
                J = J+4
            ' Put code here to send email of current temperature
                logflag = 0      ' Reset logflag before returning to mainloop
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
    Default Re: Problem with RBC_INT unique to this codeset...HELP!
    I do not see where PORTB.2 is set to digital.
    http://mackrackit.cambs.net/
    Mar 2009
    Colorado
    Thanks Sooo Very Much, Dave, for looking at this! I thought you had found the problem. Per your input I added the following statement to the interrupt setup thinking that would solve the problem, because as much as I studied this code I failed to see that I hadn't made RB2 a digital input in the interrupt setup:
    ANSELH.0 = 0 ' Set ANS8 (RB2) as digital pin
    However, this didn't solve the problem. _INTA on RB2 pin still doesn't go back to HIGH after the 1st _INTA occurs, and all of my above description of the problem remains the same, as if RBC_INT wasn't recognizing the _INTA transition.
    Any other ideas from you or others? This is a very frustrating problem that I have now spent over 18 hours trying to troubleshoot!!!
    I am guessing..
    Change
    to
    INT_Handler INT_INT, _Alarm, PBP, yes
    That should see any change on PORTB and being your other PORTB pins are analog, from the data sheet:
    Note 1:
    Setting a pin to an analog input automatically disables the digital input circuitry, weak pull-ups, and
    interrupt-on-change if available. The corresponding TRIS bit must be set to Input mode in order to allow
    external control of the voltage on the pin.
    John,
    One possiblility ...
    Your MainLoop is talking to the RTC on every loop to check the time.
    If an Alarm happens while the mainloop is using I2CWRITE, and it tries to use I2CWRITE to clear the status reg, it's probably going to confuse the RTC.
    Since you have 1 minute till the next Alarm INT, try clearing status in the MainLoop or Logging routine.
    Mar 2009
    Colorado
    PROBLEM SOLVED via the following process!!
    Followed Darrel's suggestion and put the following code block at the end of Logging routine instead of trying to clear status at end of handler.
    ' Clear STATUS and set CONTROL registers on RTC to prepare for
    ' next _INTA interrupt
    PAUSE 10
    I2CWRITE SDA, SCL, RTCdevice, ContReg,[%00000101]
    PAUSE 10
    Still had same problem after doing above. Dave's comment caused me to back through ALL of my code looking for anything that effect PortB.2 where I am trying to use RBC_INT. I had forgotten that the subroutine I cut/pasted into this program to take an analog temperature measurement, that I have used before to take an analog readin,g had the following statements at the end of it to reset PortB back to digital and all outputs.
    ' Disable AD and go to all digital ops
    ADCON0.0 = 0
    TRISB = 0
    Removing the above statements from my Temperature routine and making the below adjustments to the Interrupts setup at the beginning of my cod solved all the problem! Thanks so much Dave and Darrel....I wouldn't have found this for probably another 2 days or more if you hadn't cue'd me in the righ direction.
    '--- Setup PORTB Interrupts ---------------------------------------------
    TRISB.2 = 1 ' RB2 set as input from RTC Alarm1
    TRISB.4 = 1 ' PORTB.4 is set for input as A/D Channel 11
    ANSELH.0 = 0 ' Reset ANS8 (RB2) as digital pin
+ Reply to Thread
Members who have read this thread : 4
