ADCIN giving inconsistent results
Results 1 to 14 of 14
    Jun 2011
    St. Louis, MO
    Default ADCIN giving inconsistent results
    A friend of mine had an issue with the cooling fans on one of his cars. He originally asked if I could just wire up a switch so he could turn the fans on/off with a switch. I thought this would work but what if he forgot to turn them on and the car would then overheat. So I decided to look into creating a circuit for him that would monitor the temperature of the coolant and turn the fans on/off respectively.
    The coolant sensor on his car is just a thermistor that increases in resistance as the temperature rises. The car ECU provides a voltage divider circuit that then measures the voltage at the sensor. While gathering information about thermistors i concluded that there measured resistance on a graph is non-linear. When using the thermistor in a voltage-divider circuit the graph of the measured voltage becomes more linear. There are different reasons why car cooling fans do not turn on; faulty relay's, ECU's, sensor's, fan's, wiring, etc. The particular model of car he has [2000 Chevy Malibu] is notorious for having this problem. As far as I can see no one has solved the problem directly; it seems to be a problem of the manufacturer.
    When connecting a OBDII scanner to the car I am still able to read the coolant sensors temperature. Using a voltmeter, we read the value at the sensor and noted what the temperature was on the OBDII scanner. He told me what temps he wanted the fans high/low to turn on/off. This initially seemed simple enough....so I thought.
    Back at my home I decided I would use a PIC12F675 for the project; it was small and had ADC features. I remembered a long time ago I built a circuit for a very simple voltmeter, but it was using a BS2 module. After a little more research, I found a similar example on these forums for reading the voltage on a ADC pin. After a few tests everything seemed to work as it should. The values fluctuated initially, but after I set the VREF to VDD it seemed to stop. Next I etched circuit onto a copper-clad PCB. Now the fluctuation returned.
    What I was wanting to know, is there a better way of reading the voltage using an ADC on the 16F675. Here is my code, and I also attached a picture of the schematic. The SEROUT portions will eventually be removed once develpment was complete. They were just used so I could test the circuit while at the car. The fan-relays on the car also have flyback-protection diodes.
    Also when I inserted the PICBASIC code it changed the formatting, so everything that was supposed to be capitalized is not anymore.
    Thanks, and sorry for the long-winded story.
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT ' Internal Oscillator
    Define OSCCAL_1K 1      ' Calibrate internal oscillator
    ADCON0.7 = 1        ' Right justify result
    ADCON0.6 = 0        ' set Vref to VDD
    ANSEL    = 001000  ' Set AN3 analog, rest digital
    CMCON    = 7          ' disable analog comparator
    ' Define ADCIN parameters
    Define  ADC_BITS     10   ' Set number of bits in result
    Define  ADC_CLOCK     3   ' Set clock source (3=rc)
    Define  ADC_SAMPLEUS 50   ' Set sampling time in uS
    sample_size var byte
    i                var byte
    V_in           Var Word
    V_total       var word
    TX             Var GPIO.5
    mode          VAR byte
    low_fan       var GPIO.2
    high_fan      var GPIO.1
    mode = 2        '// 2=T9600, 6=N9600
    sample_size = 50
    v_total = 0
    V_in = 0
    LOW low_fan
    LOW high_fan
    serout TX, mode, [10,10]
    serout tx, mode, [10,13,"------------------", 10, 13]
    serout tx, mode, [      "ECT Fan-Controller", 10, 13]
    serout tx, mode, [      "------------------", 10, 13]
        gosub read_v
        gosub check_v
        gosub update_display
    update_display:
         serout TX, mode, [#V_total,13]
         pause 1000           '// slight delay to lower flickering
    check_v:
        if V_total <= 201 then high  low_fan     '/ car test value 201
        if V_total <= 181 then high  high_fan    '/ car test value 191
        if V_total >= 211 then gosub fans_off    '/ turn both fans off
    fans_off:
        low low_fan
        low high_fan
    read_v:
        for i = 1 to sample_size
           pauseus 50
           ADCIN 3, v_in                ' Read channel 3 to V_in (0-1023)
           V_Total = (V_In + V_total)
        next i
        V_total = V_total/sample_size       ' average the values
        V_Total = (V_total */ 500)>>2      ' Equates to: (V_in * 500)/1024
    Last edited by triton99; - 24th September 2011 at 19:36. Reason: extra information
    "Reality is merely an illusion, albeit a very persistent one." , Albert Einstein
    Default Re: ADCIN giving inconsistent results
    I would insert a low-pass filter and buffer between the sensor and the PIC. This way, you cut the noise, avoid some spikes (if designed accordingly) and make sure you also have the maximum input impedance on the ADC. (2Kohm if my memory serves me well)
    Side note, if your unit is mounted on a breadboard... you may/will experiment all sort of behaviours, Car noise can be really nasty sometimes.
    Sep 2005
    Campbell, CA
    It doesn't look like you are clearing V_total every time before you go into your A/D routine.
    Charles Linquist
    True!
    Jun 2011
    St. Louis, MO
    I changed the code to reset V_total variable at the start of the V_read routine. I am not able to test until I get home. But i was under the assumption that if I did not reset V_Total it would then the last value would be reused in the next readings average.
    Also when implementing the low-pass filter on the voltage in what values do you think would work for the resistor and capacitor??
    What is a good cut-off frequency??
    Thanks again for all the help.
    as-is: It really depend of the source....
    assuming you want to use an opamp in between: it's a totally different thing.
    You already use some averaging thing, Try the code modification, I'm pretty confident it will solve the problem.
    You could also use the ADC in 8 bit mode instead of 10...
    Anyways, have a look at this document
    http://ww1.microchip.com/downloads/e...Doc/adn007.pdf
