Trying to have ARRAYREAD read more than 255 chars and in LIB, R6, the max char counter is word and only used as byte for max parse.
Would changing the DECREMENT to 16 bit work without messing up something ?
ArrayRead in LIB 18L
Code:;**************************************************************** ;* ARRAYREAD : Read char from array * ;* * ;* Input : R5 = pointer to next char in array * ;* : R6 = number of chars left in array (timeout) * ;* Output : W * ;* * ;* Notes : C clear if timed out. * ;**************************************************************** ifdef ARRAYREADTO_USED LIST ARRAYREADTO movf R6, F ; Check for no chars left in array bcf STATUS, C ; Preset for timed out (C clear) bz arrayreaddone ; No chars left decf R6, F ; Count down the characters left and fall through to ARRAYREAD NOLIST ARRAYREAD_USED = 1 endif
Code to DECREMENT 16 bit val,
To make count up to 16bitCode:The Decrement of a 16 Bit value isn't quite so simple:
CODE movf Reg, f ;Set "Z" if LOW "Reg" == 0 btfsc STATUS, Z decf Reg + 1, f ; If Low byte is Zero, Decrement High decf Reg, f
I want to check with experts before I screw things up.Code:To make count up to 16bit
ifdef ARRAYREADTO_USED LIST ARRAYREADTO movf R6, F ; Check for no chars left in array bcf STATUS, C ; Preset for timed out (C clear) bz arrayreaddone ; No chars left movf R6, f ; Set "Z" if LOW "Reg" == 0 btfsc STATUS, Z decf R6 + 1, f ; If Low byte is Zero, Decrement High decf R6, f NOLIST ARRAYREAD_USED = 1 endif
Don
amgen
