Hey DT,
I've used your averaging routine on some of my non-interrupting (start timer, pause for 50mS, stop timer), relaxation oscillator, cap sensors, and it's worked great. Now I've graduated on to using the CSM module driven by an interupt. And I'm having trouble getting the same great results.
The average value does not eventually reach the present value after it drops, and sometimes it just mirrors it, and sometimes the average value spikes up.
If you could take a look at what I'm doing, I'd really appreciate it.
Code:'MPLAB 8.70, PICBASIC PRO Compiler 2.60C, Darrel Taylor Instant Interrupts-14_V110 (http://darreltaylor.com/DT_INTS-14/intro.html) 'PIC16F1823 14 PIN dip package @ __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_SWDTEN & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF @ __CONFIG _CONFIG2, _LVP_OFF DEFINE OSC 8 'tell picbasic what speed the oscillator is DEFINE DEBUG_REG PORTA ' asyncronous bit-banged RS-232 output on PORTA... DEFINE DEBUG_BIT 0 ' bit 0, which can be seen with the PICKIT2 UART tool, but you can't program this chip with the PICKIT2?!?! DEFINE DEBUG_BAUD 9600 ' 9600 Baud, DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true,like for using max232, or pickit2 DEFINE DEBUG_PACING 1000 ' 1mS delay INCLUDE "DT_INTS-14.bas" ' INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts OSCCON = %01110010 '0 = 4x PLL is disabled '1110 = 8 MHz '0 = unused '1X = Internal oscillator ANSELA = %00000000 'make port A pins digital TRISA = %00000000 'make port A pins outputs ANSELC = %00000010 'make pin 9 (RC1) (CPS5) analog TRISC = %00000010 'make pin 9 (RC1) (CPS5) input OPTION_REG = %10000111 '1 = All weak pull-ups are disabled (except MCLR, if it is enabled) '0 = Interrupt on falling edge of RB0/INT pin '(TMR0CS) 0 = Transition on RA4/T0CKI pin '0 = Increment on low-to-high transition on RA4/T0CKI pin '0 = Prescaler is assigned to the Timer0 module '111 = 1:256 Timer0 prescaler rate T1CON = %11000001 'enable timer 1 (bit 0) & source the clock from the CPS module (bit 6 & 7 =11 CPSCON0 = %10001100 'set the CPS module highest frequency availabe (for vcc mode) + timer0 clock sourced from CPS module. (BIT 1) '1 = CPS module is enabled '0 = CPS module is in the low range. Internal oscillator voltage references are used. '00 = unused '11 = Oscillator is in High Range. Charge/Discharge Current is nominally 18 µA '0 = Capacitive Sensing Oscillator Status bit (only readable) '0 = Timer0 clock source is controlled by the core/Timer0 module and is FOSC/4 CPSCON1 = %00000101 '0101 = channel 5, (CPS5) CM1CON0 = 0 ' COMPARATOR OFF CM1CON1 = 0 ' COMPARATOR OFF PAUSE 3000 DEBUG "Starting Up",13,10 VALUE var WORD AVE var WORD AvgCount CON 50 ' Number of samples to average FAspread CON 8000 ' Fast Average threshold +/- ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR0_INT, _Timer0_Int, pbp, yes endm INT_CREATE ; Creates the interrupt processor ENDASM TMR0 = 0 'clear TIMER0 @ INT_ENABLE TMR0_INT 'enable timer0 interrupts main: pause 100 @ INT_DISABLE TMR0_INT ' stop timer0 interrupts DEBUG DEC VALUE, ", ", DEC AVE, 13,10 @ INT_ENABLE TMR0_INT ' re-enable timer0 interrupt goto main '************************************************************************************************** Timer0_Int: @ INT_DISABLE TMR0_INT ' stop timer0 interrupts Value = TMR1 IF Value = AVE Then NoChange IF ABS (Value - AVE) > FAspread OR Value < AvgCount Then FastAvg IF ABS (Value - AVE) < AvgCount Then RealClose AVE = AVE - (AVE/AvgCount) AVE = AVE + (Value/AvgCount) GoTo AVGok FastAvg: AVE = Value GoTo AVGok RealClose: AVE = AVE - (AVE/(AvgCount/4)) AVE = AVE + (Value/(AvgCount/4)) AVGok: ' Value = AVE ' Put Average back into Value NoChange: 'TMR0 = 0 'clear Timer0, interrupt occurs every 32.77mS TMR0 = 61 'preload Timer0 with 61 so the interrupt occurs every 24.96mS TMR1 = 0 ' clear TIMER1 @ INT_ENABLE TMR0_INT ' re-enable timer0 interrupt @ INT_RETURN end
here is some data that I get out
Code:14459, 14459 14457, 14456 14455, 14457 14457, 14458 14461, 14457 14458, 14462 14446, 14458 14452, 14456 14452, 14456 14453, 14456 14403, 14425 14326, 14349 14271, 14304 9743, 14028 8262, 13834 7988, 13576 7764, 13434 7694, 13180 7683, 12942 7680, 12723 7678, 12520 7677, 12333 7679, 12253 7668, 12086 7658, 11933 7649, 11790 7647, 11656 7636, 11612 7632, 11491 7634, 11379 7615, 11275 7620, 11178 7616, 11089 7624, 11078 7624, 10998 7616, 10925 7598, 10855 7596, 10788 7576, 10726 7594, 10732 7592, 10674 7583, 10621 7572, 10572 7552, 10526 7559, 10541 7555, 10495 7558, 10455 7557, 10418 7561, 10384 7547, 10349 7539, 10374 7560, 10341 7561, 10312 7567, 10286 7558, 10262 7558, 10237 7541, 10269 7549, 10243 7564, 10222 7543, 10199 7537, 10179 7522, 10213 7518, 10190 7531, 10170 7605, 10153 14074, 10402 14327, 14304 14326, 14324 14310, 14310 14295, 14302 14293, 14295 14295, 14288 14281, 14285 14262, 14273 14206, 14230 14161, 14160 14138, 14167 8625, 9013 8380, 8378 8243, 8266 8194, 8212 8159, 8163 8086, 8098 8086, 8092 8083, 8072 11679, 8448 14212, 14174 14273, 14281 14258, 14271 14237, 14243 14228, 14232 14224, 14225 14220, 14229 8940, 13727 8594, 13548 8489, 13468 8444, 13289 8424, 13120 8397, 12962 8350, 12813 8342, 12759 8333, 12621 8293, 12490 8284, 12369 8293, 12255 8247, 12149 8277, 12130 8260, 12035 8292, 11947 8285, 11868 12607, 11914 14165, 14096 14254, 14233 14248, 14253 14236, 14238 14228, 14230 14234, 14230 14211, 14227 8535, 10886 8261, 8295 8175, 8201 8101, 8119 8117, 8080 8070, 8096 8059, 8066 8015, 8041 7989, 8015 8006, 8016 8038, 8022 8064, 8042 8312, 8164 14011, 20100 14170, 14152 14204, 14199 14202, 14202 14192, 14199 14189, 14195 14183, 14186 13750, 14147 8305, 13929 8155, 13687 8021, 13450 7947, 13329 7931, 13106 7887, 12895 7880, 12701 7859, 12519 7853, 12444 7835, 12280 7833, 12129 7842, 11989 7812, 11859 7790, 11735 7772, 11698 7772, 11586 7764, 11482 7756, 11386 7753, 11297 7742, 11212 7736, 11202 7733, 11123 7741, 11050 7733, 10983 7738, 10921 7728, 10928 7726, 10870 7726, 10817 7722, 10768 7719, 10722 7713, 10679 7707, 10699 7715, 10659 7720, 10622 7716, 10587 7709, 10555 7717, 10525 7713, 10554 7719, 10525 7714, 10497 7708, 10473 7714, 10449 7707, 10484 7718, 10460 7714, 10438 7719, 10418 7724, 10398 7709, 10382 7702, 10420 7701, 10400 7715, 10383 7717, 10367 7710, 10351 7717, 10390 7711, 10374 7706, 10358 7717, 10343 7726, 10331 8966, 10350 14198, 14116 14409, 14369 14439, 14436 14437, 14432 14435, 14434 14432, 14434 14423, 14423 14433, 14428 14440, 14431 14432, 14434 14432, 14430 14426, 14431 14435, 14431 14434, 14431 14430, 14430 14429, 14425 14431, 14429 14429, 14431 14437, 14432
