Post your INCLUDE files here
+ Reply to Thread
Results 1 to 5 of 5
    Default Post your INCLUDE files here
    Lester has provided a way to help document the user contributed INCLUDES.
    Please use the link below to submit your INCLUDE file.
    http://www.picbasic.co.uk/forum/misc.php?do=form&fid=1
    If you have already posted an INCLUDE here please submit it via the above link.
    Thank you.
    Default Re: Post your INCLUDE files here
    Contributed by Charles Linquist.
    Since people like INCLUDE files, here is one (KBNumberInput.bas) that some may find useful. It allows keyboard input of numbers, and unlike HSERIN [DEC x], it echoes each character and allows for backspaces to rub out errors.
    If the var ALLLOWSIGN is set to 1, it will accept a "-" or a "+" in the first position. You can also set the maximum number of chars that the user is allowed to input. If no input is received within a certain period of time (also user settable), the file exits with a RESULT of 0. The program has defaults, but can be over-ridden by setting any of them before calling the routine.
    I have included a little test program (GetNumber.bas) that explains the use.
    KBNumberInput.bas
    ; Numeric Input Routine by Charles Linquist
    ; Set MaxNum to maximum number of digits you will take (default = 5)
    ; Set KInputTimeout to the number of secs you will wait before giving up.
    ; If you will accept a sign ("+" or "-") then set AllowSign to 1 in your
    ; program it will over-ride these values
    ; RESULT is , well, the result.
            Keyin var byte
            Maxnum var byte
            YY var word
            POSN var byte
            IsNeg var bit
            AllowSign var bit
            TimedOut var bit
            KInputString var byte [10]
            KResult Var word
            KInputTimeout var Word
            XN var byte
            BS CON 8
            ESC cON 27
            LF con 10
            SP con 32
            CR con 13
            MaxNum = 5
            KInputTimeout = 10000 ; 10 sec
            AllowSign = 0
            goto OverKInput
    GetNum:
            KResult = 0
            YY = 1
            POSN=0
            IsNeg = 0
            TimedOut = 0
            ArrayWrite KInputString,[Rep $FF\8]  ; Fill with $FF
    GetMoreN:
            HSERIN KInputTimeout,DeadAtKeyboard,[Keyin]
                IF Keyin = ESC THEN ZeroNum
                If Keyin = CR THEN DunInputn
                If AllowSign then
                IF Posn = 0 THEN
                  If Keyin = "-" THEN
                      IsNeg = 1
                      Hserout ["-"]
                      goto GetMoreN
                   if Keyin = "+" then
                      Hserout ["+"]
                      goto GetMoreN
                IF Keyin = BS THEN
                   HSEROUT [BS,SP,BS]
                   IF POSN > 0 THEN
                      POSN = POSN - 1
                      KInputString [POSN] = $FF
                      GOTO GetMoreN
            iF POSN >= MaxNum THEN goto DunInputN
            IF Keyin < "0" or Keyin > "9" THEN GetMoreN
            HSEROUT [Keyin]
            KInputString [POSN] = Keyin - "0"
            POSN = POSN +1
            GOTO GetMoreN
    DunInputN:
            For xN = 7 to 0 STEP - 1
               IF KInputString[XN]= 255 THEN NoMoreNum
                KResult = KResult + (KInputString[xN]*YY)
                YY = YY *10
    NoMoreNum:
            Next XN
            If Isneg then
              If Kresult < 32768 then
                   KResult = 0 - KResult
                   hserout [CR,LF,"Error",CR,LF]
                   goto zeronum
    DeadAtKeyboard:
            TimedOut = 1
    ZeroNum:
            KResult = 0
    OverKInput:
    GetNumber.bas
    '*  Name    : Number Input routine                             *
    '*  Author  : Charles Linquist                                  *
    '*  Notice  : 2011 Charles Linquist               *
    '*  Date    : 9/13/2011                                         *
    '*  Notes   : For the forum                                     *
            DEFINE OSC 40
            DEFINE NO_CLRWDT 1
            DEFINE _18F8723 1
            DEFINE HSER_RCSTA 90H
            DEFINE HSER_TXSTA 20H
            DEFINE HSER_CLROERR 1
            define HSER_BAUD 9600
            TRISC = %10111111  ; Just for the serial port
     ;       The following vars are created by the include and may be changed before using
     ;       the structure  GOSUB GetNum
     ;       MaxNum    - default = 5
     ;       KInputTimeout  - default = 10000 = 10 sec
     ;       AllowSign   - default = 0 ("no")
     ;       The result is returned in the WORD var KRESULT
            include "kbnumberinput.bas"
    topp:
       hserout [CR,Lf,"Input a number "]
       gosub getnum
       hserout [CR,LF,"You entered "]
       IF isneg = 1 then
          Hserout [SDEC KResult,CR,LF]
          hserout [dec KResult,CR,LF]
       Goto topp
    Thank you.
