;Name    : Code Example
'*  Author  : Charles Linquist
'*  Date    : 9/10/2011
'*  Version :1.0
'*  Notes  :  For the Forum
        DEFINE OSC 40
        DEFINE NO_CLRWDT 1
        DEFINE _18F8723 1
        DEFINE HSER_RCSTA 90H
        DEFINE HSER_TXSTA 20H
        DEFINE HSER_BAUD 9600
        DEFINE HSER_CLROERR 1
        DEFINE LOADER_USED 1
        TRISC = %10111111
        MaxChars var byte
        Inputstring var byte [12]
        Timeout var word
        X var byte
        CharInput var byte
        InputString_Len Var Byte
        CMD VAR BYTE
        MaxChars = 10
        InputString_Len = MaxChars
        Timeout = 9000
        BS con 8
        CR CON 13
        LF CON 10
        ESC CON 27
        SP CON 32
topp:
    Gosub GetCharInput
     Gosub ConvertToUpper
    Gosub Parseit
    goto topp
GetCharInput:
HSEROUT [CR,LF,"Input ? "]
TextIn:
        ArrayWrite InputString,[REP 0\MaxChars] ; zero out the string to start with
        X = 0
TextIn2:
        HSERIN Timeout,NoInput,[CharInput]
        IF CharInput = CR Then Goto DoneInput
        If CharInput = ESC THEN goto NoInput
           IF CharInput = BS THEN
               IF X = 0 THEN
                Goto TextIn2
                HSEROUT [BS,SP,BS]
               X = X - 1
              InputString[x] = 0 ; zero out the backspaced char
              GOTO TextIn2
InputString[X] = CharInput
        HSEROUT [CharInput]      ; Show what we got
        IF X >= MaxChars then goto DoneInput
        X = X + 1
        GOTO TextIn2
DoneInput:
NoInput:
        ArrayWrite InputString,[REP 0\MaxChars]  ; wipe everything
out
        hserout [CR,LF,"No Input!",CR,LF]
ConvertToUpper:
     For X = 0 to MaxChars
       IF InputString[X] > 96 and INputString[X] < 123 then
          InputString [X] = Inputstring[X] & %11011111
     Next X
Parseit:
Parse01: Cmd=01 : ARRAYREAD InputString,InputString_Len,Parse02,[WAIT("AGE")] : GOTO Foundit
Parse02: Cmd=02 : ARRAYREAD InputString,InputString_Len,Parse03,[WAIT("BIRTHDAY")] : GOTO Foundit
Parse03: Cmd=03 : ARRAYREAD InputString,InputString_Len,Parse04,[WAIT("CITY")] : GOTO Foundit
Parse04: Cmd=04 : ARRAYREAD InputString,InputString_Len,Parse05,[WAIT("STATE")] : GOTO Foundit
Parse05: Cmd=05 : ARRAYREAD InputString,InputString_Len,Parse06,[WAIT("COUNTRY")] : GOTO Foundit
Parse06:
Cmd=255
Foundit:
  Select Case Cmd
      Case 1
        Hserout [CR,LF,"You typed 'AGE'",CR,Lf]
      CASE 2
        Hserout [CR,LF,"You typed 'BIRTHDAY'",CR,Lf]
      CASE 3
        HSEROUT [CR,LF,"You typed 'CITY'",CR,Lf]
      CASE 4
        HSEROUT [CR,LF,"You typed 'STATE'",CR,Lf]
      CASE 5
        HSEROUT [CR,LF,"You typed 'COUNTRY'",CR,Lf]
      CASE ELSE
        HSEROUT [CR,LF,"Invalid command",CR,LF]
   END SELECT
