Mechanical question
Results 1 to 21 of 21
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Question Mechanical question
    Has anyone got an idea where I can get a tool for knocking out holes for DB9 sockets.
    My hand skills are not too good with drills and files so I need to use a nice chassis punch.
    I did see one years ago for just this application but cannot find one anywhere. Anyone got any ideas where I can beg, borrow, steal or buy one? (this is for plastic, not metal)
    I can find plenty for round holes but not for DB9 holes.
    Peter Moritz.
    New South Wales,
    Australia.
    Dec 2005
    Default Re: Mechanical question
    I've never seen one for plastic and the ones for metal are quite costly.
    An alternative might be to have the company that supplies your plastic box machine the holes. Here in the USA, I've used Polycase, designing my board to fit one of their standard boxes and having them machine them.
    Apr 2011
    Unless you plan to do 'lots' of hole punching, be prepared to bone up your cutting-and-filing skills as the proper tool for punching holes is VERY expensive. Consider printing a template onto adhesive plastic sheet, using a craft knife to cut the hole in the sheet and placing the sheet over the 'dodgy' hole you cut. You can make some fairly professional finishes using this technique.
    Miami, Florida USA
    I might be wrong, but I don't think you can "punch" holes in a plastic enclosure. Like Dave said you can pay somebody to make the holes for you or you can buy your own CNC machine. There are a few members of this forum that might be able to guide you in the right direction in case you decide to get your own CNC machine.
    Anonymous
    Feb 2003
    I made a jig for cutting connector holes in plastic panels and boxes. Mine werent for DB9 connectors they were for SCART AV Connectors which are basically rectangular but with one end at an angle.
    I made the jig from MDF and made it larger than the hole required then using a router with a follow collar just ran it round the inside of the template.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Dec 2005
    Even a small, bench type milling machine with digital scales/readouts would be fine for low volume. There are some with retrofittable CNC controls as well as numerous DIY projects to add CNC to small milling machines and lathes.
    Pinckney, Michigan
    The common punches for doing DB-9 openings, and others, are made by Greenlee. Google them and I'm sure you'll be aghast at the prices. I once saw a knockoff DB-9 puch that was similar, and cheaper, but can't remember who made it. Perhaps your Google search will turn it up.
    In any case, I don't think they'll work on plastics either.
    The ones made for metal work just fine on plastic enclosure panels. I've used them. You just drill a hole in the end panel large enough to pass the bolt through.
    But they are expensive, and you don't need a steel punch for plastic. If you have a local machine shop, see if they will make one for you out of aluminum. I had one made 10+ years back for knocking out DB9 holes in plastic enclosure front panels for < $50, and it looked just like the $450.00+ units you see for metal from Greenlee.
    They are dirt-simple to have made in most any machine shop, and with todays economy, I'll bet you could have one made even cheaper.
    If you don't want one where the pass through nut & bolt is used, have a stamp made. Place a peice of hard wood under the plastic panel, and a few taps with a hammer will do the trick.
    If you want really cheap, gut a DB9 connector leaving just the metal shell. Place it on the plastic, and tap with a hammer. You'll have to do a bit of filing on the edges, but it works.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2011
    Guadalajara, México
    Hmm, doing the maths, a Greenlee DB9 Panel Punch cost you more than US$650 and doesn't work on plastics, a Dremel Kit cost you US$150 and you can easily make the DB9 holes and another lot of tasks...
    My English doesn't sucks, it's just fugly...
    Jun 2005
    I do have full Dremel kit but I would still need some sort of template made out of spring steel or similar to use with the routing bit. I have used the Dremel running along a stainless steel ruler for straight line cuts and it works fine. I s'pose I could use a mild steel template EG a DB9 plate from a PC as long as I can keep the cutting bit away from the steel so it doesn't get chewed up. I guess I am just gunna hafta beef up my hand metalworking skills. Sh1t, I'm getting too old to learn new stuff!!
    Peter Moritz.
    New South Wales,
    Australia.
    Dec 2005
    Quote Originally Posted by muddy0409 View Post
    At 70, I knows da feelin'. My nurse tells me the stuff falling out of my ears is earwax but I'm sure it's information overflow.
    I have, for limited volume, made hardwood jigs which control the position of the object to be machined and then cut similar things by hand with a router bit in a drill press. That way, the router bit only contacts plastic. You need a stable base with a rectangular pocket (which you can assemble rather than machine) which is bigger than the fixture (securing your plastic enclosure by the dimensions of the cutout to be made. It needs a starter hole and only works for rectangular cutouts. Corners will have the radius of the router bit. You need a sturdy drill press as well - they are not designed for lateral forces like this. You can probably buy a suitable drill press or manual milling machine for much less than the cost of the Greenlee punch. (I was somewhat taken aback by its price. Way back when DIY electronics was done with tubes (probably valves to you), I had 3-4 round Greenlee punches for making holes in a sheetmetal chassis that cost very little - IIRC about $20 each.
    Jun 2005
    You got 9 years on me, but I'm catchin' up!
    Yeah, they were valves back then and I did spend a bit of time punching out holes for the bases, with Qmax hole punches for about 20 bucks each.
    Since my last reply, I have purchased a drill press for my dremel and am looking forward to using it for this and other things.
    Peter Moritz.
    New South Wales,
    Australia.
    Jul 2005
    Palmdale, CA
    I made a DE9 connector punch on my CNC mill that works great on plastic. It is similar to the greenlee punch but designed for plastic. If anyone is interested, let me know.
    Jun 2005
    Yes, interested. You interested in selling one?
    Peter Moritz.
    New South Wales,
    Australia.
    Jul 2005
    Palmdale, CA
    Sure. It can only be used on plastic as it's not heat treated. If you give me your email address I can send you some pictures and a description.
    Jun 2005
    Peter Moritz.
    New South Wales,
    Australia.
