Add IR remote control capabilities to your next project, easily, cheaply and effortless...
The code is somewhat crude, but it works flawlessly to me!
What do you need:
PIC12F675 (Or you can easily adapt the code to another one)
Photo IC Infrared 38KHz (you can use one from an old TV or VCR)
A cheap remote control compatible with Sony TV
That's it!
I found this keychains for less than $2:
You can implement this code in two different ways, as a standalone project or to pass IR commands to another PIC in your main project (See the comments in the code)
Ok, enough talk, here is the code, the schematic is straightforward and it's included in the code:
Enjoy!Code:'**************************************************************** '* Name : SonyIR+12F675 * '* Author : Ivan Rosales - Guadalajara, Jalisco, México * '* Notice : Copyright (c) 2011 Ivan Rosales * '* : All Rights Reserved * '* Date : 01/09/2011 * '* Version : 1.0 * '* Notes : GP0 (Pin 7) Salida Debug (Debug Exit) * '* : GP3 (Pin 4) Entrada de Pulsos (Pulse Input) * '* __________ * '* Vdd (5vdc) | 16 Ch+ | * '* + | 17 Ch- | * '* PNA4612M | | 18 Vol+ | * '* .-----. | | 19 Vol- | * '* | \ /| | | 20 Mute | * '* |1/2\3| | | 21 Power | * '* 'o-o-o' | | 54 Sleep | * '* | | | | PIC12F675 |__________| * '* | | | | ___ * '* | | '---o--o|º |o---. * '* | | -o| |o---)------> Debug Exit (RS232) * '* | | -o| |o- | * '* '-)--------o|___|o- | * '* | | 600uS 600uS * '* o------------------' ________ ____ __ * '* | | Start |__| 1 |__| 0| * '* === Sony SIRC Signal: * '* GND 2.4mS 1.2mS 600uS * '* * '* Note: If you can't find the PNA4612M use any TV IR Receiver, * '* it's almost sure to work if it's in the 38KHz-40Khz range. * '* * '* If you have troubles getting this thing to work, try adding * '* a 10K pullup to pin 4 and a .1uf cap between Vdd and Vss * '**************************************************************** @ Device PIC12F675,WDT_ON,PWRT_ON,PROTECT_OFF,MCLR_OFF,BOD_OFF ANSEL=0 'Don't use ADC's CMCON=7 'Don't use analog comparators DEFINE OSCCAL_1K 1 'Internal Clock Auto-Cal DEFINE DEBUG_REG GPIO DEFINE DEBUG_BIT 0 DEFINE DEBUG_BAUD 2400 DEFINE DEBUG_MODE 0 'Mode: 0 = true, 1 = inverted Pulse var byte[12] Start var byte Command var byte Device var byte Counter var Byte 'The PULSIN resolution is 10uS with PIC running at 4MHz WaitForStart: 'Wait for Start signal PuLSIN GPIO.3,0,start 'Check the low pulse width if start < 180 then WaitForStart 'If the Start pulse < 1.8mS repeat the loop for counter=0 to 11 'Get the 12 pulses of the signal pulsin GPIO.3,0,pulse[counter] next StoreBits: command=0 device=0 for counter=0 to 6 if pulse[counter] < 90 then 'Determine if the pulse represents 0 or 1 command.0[counter] = 0 Else command.0[counter] = 1 endif next for counter=7 to 11 if pulse[counter] < 90 then device.0[counter-7] = 0 Else device.0[counter-7] = 1 endif next '_________________________________________________________________________ 'Use something like the code in this section for STANDALONE operation, or 'comment this section, send the commands to another PIC via Debug, 'and use DEBUGIN on the receiver PIC select case command case 16 'If Ch+ is pressed then turn On X high GPIO.1 case 17 'If Ch- is pressed then turn Off X low GPIO.1 case 18 'If Vol+ is pressed then turn On Y high GPIO.2 case 19 'If Vol- is pressed then turn Off Y low GPIO.2 case 21 'If Power is pressed then turn On Z high GPIO.0 case 20,54 'If Mute or Sleep is pressed then turn Off Z low GPIO.0 end select '_________________________________________________________________________ '************************************************************************* 'Uncomment the next line to pass the commands to another PIC at 2400 Baud 8N1 'debug command '************************************************************************* pause 100 'Waste some time to ignore repeated commands '(Sony SIRC sends at least 3 times the same command) goto WaitForStart
Ivan.
