uC Hangs after second serout command
Results 1 to 11 of 11
    Default uC Hangs after second serout command
    Hello,
    I'm using the following configuration:
    1 PIC 16F876A
    PIC Basic PRO 3 (demo)
    Why does the uC only runs this code one time. It does not loops it:
    Include     "modedefs.bas"
    Define  OSC             20
    STATUSLED           VAR         PORTC.4             ' Rode LED
    BUZZER              VAR         PORTC.7             ' Buzzer
    ReedContact         VAr         PORTC.0             ' Reed contact voor starten dot
    Power_On            VAR         PORTC.1             ' Overname contact power
    Power_XBEE          VAR         PORTB.0
    Power_RFID          VAR         PORTB.3
    XBEE_RX             VAR         PORTB.2             ' Serial data vanaf XBEE
    XBEE_TX             VAR         PORTB.1             ' Serial data naar XBEE
    RFID_RX             VAR         PORTB.4             ' Seriele data vanaf de RFID lezer
    RFID_TX             VAR         PORTB.5             ' Seriele data naar de RFID lezer
    i                   VAr         BYTE                ' Globale teller
    received_date       VAR         BYTE[16]
    x                   var         BYTE[20]
    y                   VAR         BYTE
    CRC                 VAR         BYTE                ' CRC over RFID data
    CRC_TOT             VAR         BYTE                ' CRC over totale data
    ' Init
    Init:
        HIGH Power_On
        high Power_XBEE
        for x  = 0 to 20
            serout XBEE_TX, T9600,["X2 = ",#x,13,10]    '9600 inverted
        next x
    Goto Main
    ' Main:
        HIGH STATUSLED
        Serout2 RFID_TX,16416,[$AA,$BB,$02,$20,$22]             ' Read Card Command
        SERIN2 RFID_RX,16416,100,Check_data,[received_date[0]]    ' Receive data
    Goto Main
    ' Check_Data:
    ' 1. Controle op gelezen data
    ' 2. Controle of kaart anders is dan vorige keer
    ' 3. Indien nieuwe kaart schrijf deze in Temp Card Data
    Check_Data:
        serout XBEE_TX, T9600,["CHECK DATA",13,10]    '9600 inverted
      LOW STATUSLED
    Miami, Florida USA
    Default Re: uC Hangs after second serout command
    NL2TTL,
    Probably the code is getting hung up somewhere in the program. You need to determine where it is getting hung up. There are several ways to do it. I would move the next line around in the program and see how far the program goes
    TOGGLE STATUSLED
    This is just one way to do it.
    Anonymous
    At first look I'd say you need to change the RETURN to something like GOTO Main.
    May 2008
    Italy
    Are you stating that because the status led is always on?
    If this is the case, take note that you turn off the status led only in the subroutine CHECK_DATA and there is no gosub to this sub in your code.
    Cheers
    Al.
    Hi I take notice off that.
    There are more strange things:
    After the:
    SEROUT2 XBEE_TX,84, ["Nieuwe kaart",13,10]
    The uC starts at INIT again and does not go back to the main routine.
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 17-8-2011                                         *
    Define  OSC             20
    RFID_RX             VAR         PORTB.7             ' Seriele data vanaf de RFID lezer
    Card_Temp           VAR         BYTE[4]             ' Temp serie nummer kaart
    read_try            var         byte                ' Pogin tot lezen
    x                   var         BYTE[20]
    y                   VAR         BYTE
    ' Init
    Init:
        high Power_On
        high Power_XBEE
        for x  = 0 to 30
            serout2 XBEE_TX,84,["X2 = ",#x,13,10]    '9600 inverted
        next x
    Goto Main
    ' Main:
        high Power_RFID
        High STATUSLED
        FOR i = 1 to 8
            SERIN2 RFID_RX,16416,10,Check_Data,[received_date[i]]
        NEXT i
    Goto Main
    ' Check_Data:
    Check_Data:
        CRC = received_date[2] ^ received_date[3] ^ received_date[4] ^ received_date[5] ^ received_date[6] ^ received_date[7]
        If (received_date[0] = $AA) AND (received_date[1] = $BB) AND (received_date[2] = $06) AND (received_date[8] = CRC) Then
            serout2 XBEE_TX,84,["Geldige kaart gelezen CRC := ", HEX2 CRC,13,10]
            ' Controleer of de kaart anders is dan de vorige kaart
            If (received_date[4] <> Card_Temp[4]) OR (received_date[5] <> Card_Temp[5]) OR (received_date[6] <> Card_Temp[6]) OR (received_date[7] <> Card_Temp[7]) Then
                For i = 4 to 7
                    Card_Temp[i] = received_date[I]
                NEXT I
                SEROUT2 XBEE_TX,84, ["Oude kaart",13,10]
            serout2 XBEE_TX,84,["Ongeldige / geen kaart gelezen",13,10]
    Goto Main
    In Check_Data you have RETURNs, but you're not using GOSUBs to get there, so replace the RETURNs with GOTOs to get back.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Funny in 2.47 version of the compiler the timeout lable works with returns
    I see that 3.00 does not accept the return.
    As far as I know, the timeout/label option has always used a GOTO to get to the label after the timeout period has expired. I can't say why it would have worked on an earlier version. Maybe luck...
    -Bruce
    tech at rentron.com
    time out....go sit on the bench,
    timeout only needed for serin !
    don
    amgen
    NL2TTL, The statement: Funny in 2.47 version of the compiler the timeout lable works with returns
    I see that 3.00 does not accept the return. Only makes sense if the timeout actually happened inside of a subroutine. Otherwise, where are you returning to?
    EN82fn
    could check PARITY BIT 13 in mode, manual says must=1
    don
