DT_Ints w/18F26K22 stop if incorrect baud rate
Results 1 to 22 of 22
    Default DT_Ints w/18F26K22 stop if incorrect baud rate
    Has any body had an issue with DT-INTs and any of the new18F26K22 or similar devices? I have a program that compiles just fine and run's on an 18F26K22 with both comm ports active. When ever you send a character that is at the wrong baudrate the DT_INT's package stops all together. Even the timer interrupts. I found this when I would log off with a terminal program running on a particular pc which would leave the RS-232 line in what looks like an active state. I would restart the PIC and all would be good, even though the RS-232 line was still in the active state. I found this would only happen if the RX pin of the PIC went to the active state any longer than the selected baudrate character time. I also checked it at a much higher baudrate and found the same results. I looked to see if there were any ERRATA sheets for the 18F26K22 speaking of this problem, and there were none. The only ERRATA for the device is if using anything other than High Baud and 16 bit baud the usart might occasionally miss a start bit time. Any help would be greatly appreciated.....
    EN82fn
    Default Re: DT_Ints w/18F26K22 stop if incorrect baud rate
    I just did some more testing and it seems to also halt if the baudrate is incorrect on either comm port. I placed a bit toggle inside of the timer interrupt routine, another inside of each of the Usart receive interrupt routines and ALL stop if the baudrate of the incomming data on either USART is incorrect.....
    EN82fn
    Sep 2005
    Campbell, CA
    Do you have the Clear Overflow Error defined?
    (DEFINE HSER_CLROERR 1)
    Charles Linquist
    Charles, Thanks for the reply, No I have not as I have never used the commands for HSEROUT or HSERIN to do my serial activities. I ahve always used interrupts. I used to use an old set of interrupt routines originally written by Tim Box but for the last few years I have used the DT_INT routines as they seem more stable. I have as a few of the first lines in my interrupt routine a check for the overflow bit being set. There is no interrupt for the overflow bit being set. It is up to the operator to check this bit and clear it if it is set. If it IS set there will still be an interrupt generated for the RXREG having data in it. If it IS set then after reading the data in the buffer and NOT resetting it you will NOT receive any more data into the RX shift register. The problem I am having is that ALL interrupts are comming to a halt if there is an over run. It doesn't matter which USART you are using. I have the same code working on an 18F2620 with out the second USART and have NEVER had this problem.
    EN82fn
    Well as it goes, I found my problem. It seemed to me to be a possible stack issue the way it was acting. Sooooo, I took another longggggg look at the interrupt routines and much to my dismay, I found a few remnants of the OLD Tim Box style syntax. He used to use a RETURN when the interrupt was to be exited. Well I found one in each of the USART interrupt routines as an early exit I used at the time before I modified them to use the DT_INT's. So it was a stack issue after all. It only goes to show, If you are going to cut and paste, Make darn sure you look at it REAL GOOD before you use it. This is the second time in a couple of years this same thing has happened to me since I switched over to the DT_INT's but, I will never go back....
    EN82fn
    Jul 2009
    Ohio, USA
    I know this is an old thread but I am trying to get the DT_INTS to work with the 18F26k22, so far no luck with either RX1 or RX2,the program will not jump to the label in the ASM macro
            INCLUDE "modedefs.bas"
            INCLUDE"ALLDIGITAL.pbp"
            INCLUDE "HomeAutomationVars.bas"  'Open with PBP editor
            INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
            INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
        DEFINE PULSIN_MAX 1000
        DEFINE HSER_RCSTA 90h   'Hser receive status init
        DEFINE HSER_TXSTA 24h   'Hser transmit status init
        DEFINE HSER_BAUD 9600  'Hser baud rate
        DEFINE HSER_SPBRG 25
        DEFINE RX2_INT   PIR4,RC2IF, PIE4,RC2IE
        DEFINE TX2_INT   PIR4,TX2IF, PIE4,TXIE
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 0
        DEFINE DEBUG_BAUD 9600
        ' Set Debug mode: 0 = true, 1 = inverted
        DEFINE DEBUG_MODE 1
        x var word
        debug "here",cr
            INT_Handler    RX_INT,    _read_serial,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    T0CON = %10010010
    @   INT_ENABLE   RX_INT     ; enable external (RX) interrupts
        for x = 1 to 1000
         pause 1
         next x
        Goto main
    read_serial:
    Debug "got it!!",cr
    Is there a fuse bit that I need to set? I had no problems with an 18F1320
    Mike
    no config section
    no define OSC
    no version of pbp
    what osc freq do you expect the chip to be running at ?
    power on default for that chip is ?
    thats an awful lot of guessing
    A couple of things that sticks out:
    I'm fairly sure that the DEFINE HSER stuff isn't DOING anything UNTIL you actually USE a HSERIN/HSEROUT statement in your code - which you don't. Try adding a dummy HSERIN/HSEROUT - or set USART registers up yourself.
    The ISR is ending with a GOTO which is not what it's supposed to do.
    You don't want the ResetFlag option enabled since the EUSART hardware clears the flag i automatically.
    Jul 2009
    Ohio, USA
    Richard, thank you for the respose,
    PBP version is 4.0.0.0
    Henrick, I altered the code to include a hserin but still no luck
        include "ALLDIGITAL.pbp"
        include "HomeAutomationVars.bas"  'Open with PBP editor
        OSCCON = %11010010 'Internal oscillator is set to 4MHz  $D2
       'OSCTUNE = %10000000 'HFINTOSC selected; PLL disabled; Factory calibrated frequency
        ADCON0.0 = 0 'Disable ADC
       ' DEFINE RX2_INT   PIR4,RC2IF, PIE4,RC2IE
        'DEFINE TX2_INT   PIR4,TX2IF, PIE4,TXIE
        DEFINE DEBUG_BIT 0
        define HSER_SPBRG 25
        Define HSER_CLROERR 1
        DEFINE DEBUG_MODE 1
        debug "here",cr
            INT_Handler    RX1_INT,    _read_serial,   PBP,  yes
    T0CON = %10010010
    @   INT_ENABLE   RX1_INT     ; enable external (RX) interrupts
        for x = 1 to 1000
         pause 1
        next x
        Goto main
    read_serial:
    Debug "got it!!",cr
    hserin 250, timeup, [x]
    @ INT_RETURN
    timeup:
    debug "no rs232",cr
    This is the include file in the pbp folder
     INCLUDE "P18F26K22.INC"	; MPASM  Header
            __CONFIG    _CONFIG1H, _FOSC_INTIO67_1H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
            NOLIST
    Mike
    there is no pbp4
    its
    pbp2.xxx
    or
    pbp3.xxx
    NOLIST
    makes me think pbp2. something
    and
    using partial [incomplete configs] is asking for trouble those settings that are omitted revert to power on default after an erase, not even pbp defaults
    and can lead to difficult to understand mis-operation
    having an isr like this will never work properly
    read_serial:
    Debug "got it!!",cr
    @ INT_RETURN
    an isr should not :-
    have a pause
    or
    any blocking code
    or
    any lengthy {timewise} commands
    if its to work properly
    I would do it this way
    note the config section is for pbp3
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = OFF
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
            ;INCLUDE "modedefs.bas"
            ;INCLUDE"ALLDIGITAL.pbp"
            ;INCLUDE "HomeAutomationVars.bas"  'Open with PBP editor
        define OSC 8
        DEFINE DEBUG_BIT 0
        DEFINE DEBUG_MODE 1
        x var word
        rxflag   var bit
        rxchar var byte
     INT_Handler    RX1_INT ,    _read_serial,   PBP,  yes
    OSCCON = $60   ;  OSC 8
    debug "running",13,10
        debug "."
        for x = 1 to 1000
          if rxflag then
             Debug 13,10,"got !! asc chr",#rxchar,13,10
             rxflag=0
          pauseus 1000
        next x
    Goto main
    read_serial:
        rxflag = 1
        rxchar = rc1reg
    @   INT_RETURN
    Jul 2009
    Ohio, USA
    Richard, you are right, microcode studio version is 4.0.0.0, and the PicBasic Pro version is 2.6L
    and Henrik is right
    about this
      CONFIG  PLLCFG = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
        define OSC 8
        DEFINE DEBUG_BIT 0
        DEFINE DEBUG_MODE 1
        x         var  word
        rxflag   var bit
        rxchar  var byte
    hserout "running",13,10     ;dummy
        debug "."
        for x = 1 to 1000
          if rxflag then
             rxflag=0
          pauseus 1000
        next x
    Goto main
    read_serial:
        rxflag = 1
        rxchar = rc1reg
    @   INT_RETURN
    Jul 2009
    Ohio, USA
    OK, Pic Basic Pro 2.6L will compile the project
    Version 2.60A gives these errors:
    Unknown Processor(18F26k22)
    Cannot open file (Include file "Pic18F26K22.inc" not found)
    Processor type is undefined
    Etc...
    Compiler Version 3.1.0.4 gives these errors
    Warning: Unable to open INCLUDE file DT INTS-18.BAS
    Warning: unable to open INCLUDE file REENTERPBP-18.BAS
    and a whole host of ASM errors associated
    Anyone have an idea of what to do now?
    Jul 2009
    Ohio, USA
    I found that you need to point the Include to the location like,
    INCLUDE "C:\PBP\DT_INTS-18.bas"
    Mike
    OK
    Quote Originally Posted by Mike2545 View Post
    Mike
    And to think I have like over 100 copies of DT_INTS[-18] because I made sure there was one in each folder I saved code in! That was worth the time spent reading this whole thing right there. Thanks Mike.
    If the file is in the PBP folder there's no need to specify the path. If no path is specified the compiler looks for the file in the source file folder, and then in the PBP folder.
    Jul 2009
    Ohio, USA
    Henrik, apparently Pic Basic Pro 3 does not do that you need to specify the folder.
    Mike
    Mine works exactly as I describe, just tested it again....
    Place the file to be included either in source folder or in the root of the PBP3 folder and then doing INCLUDE "ThisOrThat.pbp" works just fine.
    If the file exists in BOTH locations it uses the one in the source file folder so that's where it looks first - as expected.
    ditto
    same for pbpmod files for user_commands
    Jul 2009
    Ohio, USA
    I don't know why mine needs the path specified but it does. The DT_INTS-18 is in the PBP folder but I need to tell it INCLUDE "C:\PBP\DT_INTS-18.bas" for the file to be found.
    Mike
    Just an idea, you don't happen to have multiple installations of PBP do you. If you've upgraded to PBP3 then perhaps the compiler that's actually executing resides in the PBP3 folder while you place the include file in the "old" PBP folder.
    Other than that, could it be a a "virtual folder" issue of some sort.
    found this from dt
    PBP can only find include files in either the "Working Folder" or PBP's application folder.
    MPASM can only find include files in either the "Working Folder" or MPASM's application folder.
    from
    http://support.melabs.com/forum/disc...-pbp-rev-2-50c
    post #4
