Upgraded to 2.60 ~ now it won't read pin 5, 16F876A.
Results 1 to 3 of 3
    Mar 2005
    Cocoa, Florida
    Default Upgraded to 2.60 ~ now it won't read pin 5, 16F876A.
    Here's an interesting one.
    Have 3 switches into a 16F876A; 10K pullups, 470pF slugs, active low.
    Pins are high on scope. Existing product, worked forever. Tried new PICs.
    After upgrading to 2.60, the PIC won't read one of the inputs, the PORTA.3.
    Wrote this below to find out why existing program cannot read a high on pin 5.
    Even driving from inside it doesn't see a high, but all other pins work as normal.
    It doesn't have to be debug, no way of reading this pin seems to work.
    Please tell me what I'm doing wrong.
    Ken
    Terminal output:
    PORTA.3: 0 (should be 1)
    PORTB.1: 1
    PORTA.4: 1
    Program:
    'setup:
    DEFINE OSC 20 ' set the clock speed
    DEFINE DEBUG_REG PORTC ' Set Debug pin port
    DEFINE DEBUG_BIT 6 ' Set Debug pin bit
    DEFINE DEBUG_BAUD 9600 ' Set Debug baud rate
    DEFINE DEBUG_MODE 0 ' Set Debug mode: 0=true(inv), 1=TTL
    INCLUDE "modedefs.bas" ' must be in local directory
    INPUT PORTA.3 ' set input
    TRISA.3 = 1 ' set input (again)
    test:
    debug " PORTA.3: ", dec PORTA.3, 10, 13
    debug " PORTB.1: ", dec PORTB.1, 10, 13
    debug " PORTA.4: ", dec PORTA.4, 10, 13
    debug 10, 13
    goto test
    Default Re: Upgraded to 2.60 ~ now it won't read pin 5, 16F876A.
    RA3 is analog by default until you disable it, and analog inputs read zero when trying to use as digital inputs.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2005
    Cocoa, Florida
    Bruce, once again you saved my bacon.
    The real mystery is how this input worked for the last three years... going back through the old code now.
    Ken.
