Vcc Vdd etc
Results 1 to 12 of 12
Thread: Vcc Vdd etc
    Default Vcc Vdd etc
    Hi all, I have no formal education with electronics.. figured I would ask this question just because its bugging me and I need to know why.
    Why are power planes named Vcc Vdd Vss etc... Do the two letters after the V mean anything in particular or is it just an arbitrary way of naming different power planes? At first I thought Vdd might have had something to do with Drain, Vss would have something to do with source how ever most of the schematics I have worked with have them the other way around... (Vdd is + and Vss is -)
    Just curious.
    Usually
    VCC, V+,B+, VDD are the same... i mean +5,+12,+15 or any + voltage
    VSS is Ground
    VEE is mostely -5,-12 or else - voltage
    BUT i don't know if there's any official name for those 'label'
    look at this link
    Usually in IC Datasheet taken as...
    Vcc - Voltage Collector Collector
    Vdd - Voltage Drain Drain
    Vee - Voltage Emitter Emitter
    Vss - Voltage Source Source
    etc
    There is another naming convention that sequentially names power rails in the system... Vaa, Vbb (usually reserved for the Battery Supply), Vcc, Vdd etc.
    AllanL5's Avatar
    AllanL5 Guest
    Yup, what Melanie said.
    Vcc -- For TTL circuitry, this is the +5 volts which sits on the collector of the bi-polar transistor output circuit.
    Vee -- For TTL circuitry, this is the GND which sits on the emitter of a bi-polar transistor output circuit.
    Vdd -- For CMOS circuitry (like the PIC) this is the +5 (or +3) voltage that sits on the 'drain' of a MOS-FET transistor output circuit.
    Vss -- For CMOS circuitry, this is the GND that sits on the 'source' of a MOS-FET transistor output circuit.
    Italy
    Positive voltages:
    Vcc- Positive supply voltage of a Bipolar Junction Transistor.
    Vdd- Positive supply voltage of A Field Effect Transistor
    Negative voltages/ground:
    Vee- Negative supply voltage of a Bipolar Junction Transistor.
    Vss- Negative supply voltage of A Field Effect Transistor.
    The letters c,d,e and s originated from the name of the legs of the transistors Collector, Drain, Emitter and Source.
    The absolute distinctions between these common supply terms has since been blurred by the interchangeable application of TTL and CMOS logic families. Most CMOS (74HC / AC, etc.) IC data sheets now use Vcc and Gnd to designate the positive and negative supply pins.
    The doubled suffix indicates that the voltage is "common", i.e. it is the supply voltage to one or more collectors (in the case of cc) and not just the voltage at a specific collector. Similarily, Vee is a common voltage for all emitters etc.
    Above text from web page:
    http://www.techpowerup.com/articles/overclocking/45
    tabarnak! zzzzzzzzzzzzzzzzzzZZZZZZZZZZzzzzzzzzzzzZZZZZZZ!!!
    anybody else have more and more details on that
    Isn't that a French-Canadian technical expression? *smiles*
    Italy
    Make no assumptions, read the datasheet first!
    Example VSS is not always wired to ground.
    (Sorry if we are boring you Steve).
    Luciano
    Talking Tranlation
    Hi Melanie,
    To further what Steve was trying to express, that's French for:
    "Thank you very much for the information folks, most graciously appreciated."
    It is common to say it the way Steve does in some EXTREMELY remote areas of Quebec, or as we say in civilized areas such as Montreal, "where the hand of man has not yet set foot"...
    :P
    Wow, Well, very good information indeed. Will certainly help me remember now what power rails go where!
    hmmm... I shall have to try it on the streets of Paris next week...
    HaHa for sure they'll not understand those Quebecers expressions. When we go there, they don't understand us. The funniest is when we ask for some butter... it isn't so complicated... 'beurre'
    bah that's just funny! I really love those francais de France
    few expressions and translations here
    and here
  1. Display Vdd
    By davesatu in forum mel PIC BASIC Pro
    Last Post: - 14th February 2010, 09:34
  2. ICSP with differents vdd level..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 16th February 2008, 03:29
  3. PIC sinking voltages higher that Vdd???
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 27th February 2007, 20:39
  4. [16F871] Power on RA4 before power on vdd?
    By Buzzz in forum Schematics
    Last Post: - 5th September 2005, 17:48
  5. switching external vref+ and vdd vref
    By alejandro_halon in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 21:13
